Question about NAD Audio Players & Recorders
T775 Audio dropout
Audio problems with all digital and analogue sources. Front panel does not indicate a loss or change of signal to the receiver. Surround modes not playing through all speakers.
  • 9 Answers
SOURCE: Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Posted on Aug 14, 2007
SOURCE: No sound in surround modes
I just connected the front main speakers and sound well, but when i connect the speakers (2 fr, 2 rear, 1 ctr) there`s no sound in any surround mode from any source.
Posted on Feb 03, 2008
SOURCE: Philips FR965/17 Digital Audio/Video Surround Receiver
http://www.p4c.philips.com/files/f/fr965dht/fr965dht_dfu_eng.pdf im pretty resourceful
Posted on Dec 18, 2008
SOURCE: Source always PCM, can't get Dolby-D
PCM is standard when using HDMI cables, you are passing an already decoded audio signal to the receiver and it outputs the sound and does nothing more. The reciever calls this PCM, your PS3, when pressing select should show that it is decoding the dolby digital HD. There is no quality difference in the two. PCM is the same because it is un compressed audio. So when using HDMI, no matter the signal that the movie or music is playing, wether it be dolby or DTS, you will see PCM when using HDMI.
Posted on Feb 26, 2009
marketex
  • 371 Answers
SOURCE: Denon AVR-1403 receiver switched from digital to analogue.
There are three modes (Auto, DTM, and PCM) on the input mode switch, on the main unit, selected by repeatedly pressing the input mode switch.
However, if you have already depressed the Analog button in, on the main unit you have predetermined the mode as analog.
On the remote, the INPUT MODE switch combines toggles for 5 choices, [Auto, PCM, DTS, Analog,
Ext. input]
My guess is that either the input mode switch on the main unit and/or the remote are toggled to analog.
Posted on Apr 11, 2009
Can an analogue VCR be used to record from a digital signal?
If you have connected the digital source such as a DV Video camera to TV using HDMI (digital) or RCA (analouge) signal; and you have already configured your VCR with that TV, you should be able to record irrespective of the source signal type.
May 03, 2014 | Televison & Video
Tv freezes
You need to boost your signal somehow, get a better antenna. nothing is wrong with the TV, this is a typical Dropout when signal is low.
Tony
Apr 16, 2014 | LG 32LD550 32 in. LCD HDTV
I have audio but no video
This depends on the signal source. If it is digital, from a digital receiver, the audio will be either S/PDIF or Optical and the video will be a yellow RCA connector (co-axial). If analogue, the audio will be two RCA connectors (red-right and white-left) and the video will be component (green, blue, red RCA) Alternatively you may have a composite audio/video signal (yellow) which is both audio and video. Of course you must be sure to choose the inputs into which you have plugged your signal source. Cheers, Don.
Nov 25, 2013 | Denon AVR-2106 Receiver
Just bought a Yamaha RX-V371 surround sound receiver and the TV audio signal is cutting out. I am running a Samsung LED TV with a single HDMI cable (sound/picture). I tested a smaller tv with a short HDM...
Settings are not the source of intermittent problems.
"Signal loss" is indicated WHERE? So what's going on upstream at the source? ITS cables are a part of this.
My $.02... I never route any signal unnecessarily to or through a device that doesn't enhance or consume it. Hence, my BEST video from each of my several video sources goes directly to my TV/monitor and my BEST digital audio from all sources goes directly to my AVR.
No problems.
Sep 20, 2011 | Audio Players & Recorders
The vocopro 5800 is constantly losing signal strength and going in and out with movement. How do I fix this problem.
1. Check microphone(s) batteries and replace if the
charge is low.
2 Remove local sources of UHF interference, such as
lighting equipment.
3. Adjust the squelch controls on the front of the UHF-
5800 receiver.
4. Signal may be too weak. If so, reposition antennas.
If possible, move them closer to the transmitter.
5. Reposition the receiver, perform a "walkthrough",
and observe the signal strengths. If audio dropouts
persist, mark these "dead spots" in the operating
area and avoid them during the performance.
If none of these could help it is possible that the device has really some faulty operation and needed to carry it to service center.
gylacz
Mar 18, 2011 | Audio Players & Recorders
When watching sattelite tv I get what sounds like artifact sounds that come through. They are very loud, best described as a "TINK". It is very annoying listening to Tink, tink, tink tink, tink...
Not knowing the specific cabling you use and the pathing...
Everything is digital. You're probably experiencing data dropouts.
Is the problem both audible and visual? THAT would point to data loss where the video and audio coexist - upstream of the TV and audio systems. If it just the audio medium, analyze its physical sugnal path and see where you can isolate or eliminate cabling and hardware. The ONKYO has indicators that would blink upon digital signal loss. Trace it back from there.*
* I always run the BEST video from each source directly to the TV and the BEST audio directly to the electronics. Unnecessary interconnects and hops are expensive and failure prone. Optical cable should be routed with lazy curves to avoid light loss and data dropouts.
In many systems with a DVR ALL viewing is from the DVR rather than LIVE.
Observe whether a given glitch is observable and repeatable on your DVR. If it IS, the transmission was bad at that moment and the result was captured. From this point there is no way to differentiate between bad data IN or bad data from the Hard Drive, unless you can bypass the DVR entirely or watch it truly LIVE.
If you have support for the DVR, the vendor CAN log into it and examine its error log data.
Mar 15, 2011 | Onkyo TX-SR705 Receiver
I cant get my zone 2 to play the same thing as my main tv room, how do i fix the problem?
zone2 does need an analogue signal. If your tv room has an digital source, the zone2 won'tgive the same.
Check the manual, the analogue issue is described.
Rgrds,
Phil
Jan 31, 2011 | Onkyo TX-SR606 Receiver
Get intermitent audio dropouts where receiver indicates adio off untl it reads the signal.
Guessing: 'digital' audio input through an optical cable? Make sure the it's seated right and has no small-radius bends or kinks in the cable.
Or, you could provide some real details with makes and models and we'll try again.
Jan 09, 2011 | Audio Players & Recorders
Rear speakers do not work
Make sure of what audio mode you've set your receiver to, as well as what the source audio signal contains.
Some modes, such as Dolby Digital/Pro Logic will adopt the input format, and subsequently use only the front left and right speakers if there are no LFE/Center/Surround channels present. Setting the mode to Pro Logic II or IIx, on the other hand, will force a signal to be spread out to the various extra channels.
Using the Automatic Field Detect mode will usually provide the most appropriate solution for the input signal, otherwise.
Also note that if your audio source is from a PC and you are playing games, some games will, when you are using the digital output of many sound cards (most notably the Sound Blaster Live! and Audigy 1-2 and Audigy SE model cards) output only stereo as their signal, but still in a digital format. Your receiver will pick this up as a stereo specific signal and avoid using the subwoofer, center and surround channels.
Unfortunately, for those cards, there is no work-around beyond using analogue output or getting a more recent, better compatability sound card, as it is a limitation between the drivers, the card and the game in question, rather than your receiver that has the issue.
If the above doesn't help alleviate your issue and/or you could clarify on what your source audio is and whether you encounter this issue with all source-types or not, please post a follow up response.
Mar 20, 2010 | Sony STR-DE915
Loss of Digital Shows??
U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
Oct 26, 2009 | iLO V27DMBX Television
21 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
