Question about Kenmore Washing Machines
Fault code f-24 kenmore front-loading automatic washer model 110.4751
Model 110.4751 fault code f-24
SOURCE: Kenmore Front Load Washer Problem
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
Posted on Nov 02, 2007
Krazytech
  • 725 Answers
SOURCE: Fault F24 on kenmore front
F24 error code a water temperature sensor error or enought hot water to the washer.
check to see you have both valves are turned on. Also, the water inlet valve on the washer has a screen and it is known to get clogged and restrict water flow. Turn off the hot water valve. Pull the hot water hose off where it attaches to the back of the washer.
Even if you are getting good hot water flow, inadequate water temperature can cause an F24 error code. Check the temperature setting on your hot water heater. It should be set at 120 F. You should reach this hot water temperature at your washer within about 1 minute.
If you are getting a good hot water flow, you may one of the following failures:
1 loose or dirty connection at the temperature sensor or control board.
2 The temperature sensor could be out of range. Bad or shorted sensor
3 Control board failure.
The temperature sensor should have a resistance reading of 6.6k ohms at 104 degrees F and should drop in Ohms as temperature rises,
The temperature sensor is located at the back lower section of the tub with 2 small black wires. It would require a ohm meter to measure the resistance of the sensor. .
Posted on Apr 20, 2008
  • 1028 Answers
SOURCE: Kenmore front loading automatic washer is flashing the f-01 error code.
new control bd
Posted on May 06, 2008
jyackle5
  • 8197 Answers
SOURCE: error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Posted on Dec 18, 2008
bschilz
  • 2049 Answers
SOURCE: FDL fault code on kenmore elite washer
F DL
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Posted on Nov 08, 2009
Testimonial: "Very quick answer.......even better was it solved the problem. Thanks"
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Kenmore front load model 40272900 e codes (control Error)
If the washer's full model number is 79640272900, then the unit was made by LG. Looking up LG front-load washing machine error codes will give the available codes. Here is one listing: http://www.appliancefactoryparts.com/blog/2010/02/washing-machine-fault-codes/#LG . Some of these codes are also available in the manual in the Trouble-shooting section. Manage My Life has the manual as a PDF here: http://www.managemylife.com/mmh/owner_manuals/17952/KENMORE-Residential-Washers-L0910072?brand_name_search=79640272900 .
I hope this helps.
Sep 21, 2013 | Computers & Internet
Error code f 02
I think it's a slow drain fault. But would need full model number to say for sure. Still it wouldn't hurt to check the drain pump for crud. Here are some vids that might help. Don't worry too much about brand specifics. Many brands share identical and similar parts.
http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Kenmore Elite 45986 Front Load Washer
I have a model #110.47561601, Kenmore HE2t Front load washer Type 832. I am getting a code of F-24, when I try to start the cylce. What is the problem that prompts a F-24?
Hello
F-24 is a water temp snsor error.Try running the machine in spin and drain.Once empty unplug machine for 3 min.Then try load of wash again.This time use cold water until error clears.
Aug 27, 2011 | Kenmore HE2 Plus Front Load Washer
My front load kenmore he2plus is showing a f-24 code what does this mean model#11047532600
Hi
Error F-24 means water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). This is caused by a failed temperature sensor. It can also be caused due to a wiring failure or a failed electronic control board could also cause this fault code. Unplug the washer & remove the kick panel in the front. Use a multimeter to check the resistance of the temperature sensor. To remove the bottom front service panel, take out the screws at the very bottom of the panel and then pull it out and down to remove it from the washer. With the panel removed, you should be able to pull the wires off of the temperature sensor at the bottom front of the washer tub. Measure the resistance across the leads of the temperature sensor. It should read around 10K ohms (10,000 ohms) of resistance at room temperature. If the reading is less than 7500 ohms then you would need to replace the sensor. If the resistance reading of the temperature sensor is fine, then the issue is with wiring failure or a bad control board. Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Kenmore HE2 Plus Front Load Washer
Fault codes meanings for kenmore front load washer model 110.47512600
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208540259.pdf
Aug 25, 2010 | Kenmore HE2 Plus Front Load Washer
Error code f17
Sears are a department store not a manufacturer, they contract other manufacturers to build the appliances for them and these are then sold under the Sears/ Kenmore brand.
To find who made your appliance, check the first three digits of your model number against the list below and this will give you the manufacturer of your appliance.
There is a site to help identify you washers "real" maker
The Link is here to cross reference it.then look up f17 and f25 on that make and model for better results
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
the Sears/Kenmore part is almost in the middle of the page. Then keep me posted by adding comments if you have any other questions
I hope this helps you out
8-)
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
EFO displayed on my machine while running and beeped.
EFO is not a Kenmore Error Code.
Zanussi & AEG EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2009 | Kenmore 44102 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer Kenmore Model 417.44072300 Front load washer.
The drum is loose. I pulled the back panel off and the nut is tight behind the drum? could it be the bearing? do I need to change the whole drum? is this a common problem or was this do to abuse.
Jul 28, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
