Question about HP Color LaserJet 9500HDN Printer
50.6 fuser eror
Have a problem 50.6 fuser eror how can it solve
Colour Xerox Machine problem
its a problem with the fuser unit ,its overheating .two ways to solve it first check if the sticker paper is supported by your printer ,2nd you may need to replace the fuser unit
Oct 02, 2014 | Xerox DocuColor 242-252-260 PS
HP CP4025N 59 CO EROR
Hi
probably this fuser unit is faulty, the other issue this machine uses the electric current 110 v or 220v
Jun 13, 2014 | HEWLETT-PACKARD 110v Fuser Kit Fuser Unit...
Canon ir 4570
Fuser unit / fixing unit problem check whether fuser sleeve is damaged if yes change it or apply fuser oil and white grease on it for smooth rotation....
Jun 24, 2013 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Eror 202
The left "trip" switch on the back side of the printer (fuser unit) is stuck or bad. Unplug from the fuser and test. Will need to replace unit or replace fuser.
Nov 17, 2010 | Lexmark T630 Laser Printer
Digital Copier AR 5316E error code H4 indicating
An H4 code denotes a low temperature or temperature sensor failure problem with the fuser (the device that provides heat and pressure to bond the toner to paper). There may be a peice of paper or part of a peice jammed up inside the fuser that's blocking the sensor, or the fuser is defective and needs to be replaced.
Sep 18, 2009 | Office Equipment & Supplies
How to fix eror 000 on canon np 6650 II
This problem take a part? then the fusers lamp is wrong or disconnect. Please, be shore, that the connections of fuser lamp, it's on fusers part of the copiers, is on work?, The second, tes please the thermistor section, if the thermistor dous notwork, the eror 000 will be the same. And then, u mast test the thermo fuze, this own, and all about I told u is situated in fusers part and remooved very easy. Weel, then u test will be finished your copier dous not started, u must push the buttom wich is on ander the back cover in to the right and down place near the controller of DC. Than u push it, u can starting the copier. My email goodgold@inbox.ru Good lark
Sep 12, 2009 | Canon NP 6050 Copier
EROR- NOT RESPOND
h4 errors usually accur due to a problem with the fuser it may be it over heated or the thermistor has a build up of toner on it causing irregular temp reading check to see if it is heating up by turning it on and feel the heat from the fuser unit at the back.
Jun 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
Have a cru fuse eror?
Your description is not clear. Replacing a fuse does not repairs the fuser. But if you replaced the whole fuser with a brand new one (not refurbished) then you have a bad power supply board. Unfortunately, you need to get a new copier.
Mar 10, 2008 | Samsung SCX-4216F All-In-One Laser Printer
HP Color LaserJet 9500HDN Printer Logo
Seeker5211
Seeker5211
