Question about RCA Televison & Video
New rca mobile disc player DRC697 will not open
Brand new rca dvd mobile player will not open to allow insertion of disc
The Marv
  • 72 Answers
SOURCE: Bad disc or insert disc problem
If you are using a copied disc try a real one. But this model of DVD Player is made so cheap. it sound like the laser assembly is bad or the motor that spins the disc is stuck or going out. If you are good at electroninics you could take the lid off load a disc and see if it spins if not give it a spin clockwise and see if it takes off. You probably should replace unit for price of a new one.
Posted on Jan 06, 2007
  • 4102 Answers
SOURCE: Unit won't open compact disc door
hi your problem sounds like the flap has come off the runners or become jammed if you remove the case by undoing all the screws if you cant get to the dvd with the case off then plug it in and it will open as the flap will be conected to the case the screws should be located down either side might be 2 or 3 screws running down either side towards the bottom also on the back their might be a couple of screws also but look first in case their isnt you should see the screww going through the outer casing.
Once you have removed all the screws then the case will either lift off by pulling upwards or some of them will slide off if it dont lift off the hold the case either side and pull the case towards you from the front not the back it should slide of forwards let me know how you get on ok or if you need further assistance
Posted on Feb 01, 2008
SOURCE: DVD recorder DMR-E55
You can try a factory reset (reboot).Here are the steps..
The following will set your recorder to the Factory defaults.
(Will not format HD on DMRE80).
With power off (stand-by mode/CLOCK DISPLAY SHOWING):
1)Press and hold [skip reverse] [Time Slip] [Eject] buttons for about 10 sec
2)Display will show 'L1 TEST'
3)Now power off DURING TEST
4)Clock should be fashing 12:00
5)Turn power on and language menu will be displayed on TV
Use for
DMRE50
DMRE55
DMRE85
For the DMRE75V press both [dub] buttons and [eject].
Hope this helps.
Posted on May 02, 2008
  • 6 Answers
SOURCE: Recording on DVD-R with Samsung DVD-R155
Heating issue. If you remove the cover and touch the processor chip - you will not be able to keep your finger there for more than a second (that is if your really want to use this crude method to test the temp).
I have taken measurement and its around 50C. Thats a lot for no heatsink or cooling fan.
If you have the unit in a cabinet with no air flow - you will not be able to use this unit for more than 3 months and up to a year. Best to have it on top of a cabinet or in one with an open front and back to allow some airflow - or just anywhere where its in the open.
Samsung has another unit - the AR650, which I believe is discontinued - which for some strange reason has realized this concern. My guess its a whole different team of designers (or at least some folks with some brains) and added a cooling fan into the unit. Its the same exact case and motherboard as the 135, and 155. There are absolutely no issues with it rejecting disc's - even after a year of use for some users.
In Summary:
Solution 1 - Place it in the open
Solution 2 - Remove case and drill holes to the topside
Solution 3 - Remove case and add a fan
Solution 4 - Remove case and add a heatsink over proc (will still need to drill holes over heatsink..
Solution 5 - We can all complain to Samsung and have them recall the units
Posted on Aug 22, 2008
VOTIT
  • 2071 Answers
SOURCE: APEX AD-1115 DVD PLAYER
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 25, 2008
Rca dvd player movies freeze up
Have you been using this DVD player for several years? If so, there may just be residue on the lens inside, which keeps it from reading a DVD and causes it to freeze. Have you tried running a cleaning disc through it to see if that fixes the problem? Worth a try. ;)
Nov 28, 2012 | RCA Televison & Video
I put the dvd in the slot and the machine takes a very long time loading and the the it says no disc. I also noticed one time it said ps off
Tries it with many other DVD discs,If u have the same result the DVD player Laser eye is having problems and it dying,not reading Data's from the DVD disc anymore.If not,that only DVD disc,that have problems,than check DVD disc for smushes,grims and cracks on the DVD disc itself.If it is the DVD player having problems with it Laser eye and it dying.The DVD player is junk not worth repairing.The DVD player sell really cheap these days,like $40 for a brand new one.
Nov 15, 2010 | RCA DRC247N DVD Player
Will not play a dvd. When a dvd is inserted the screen says disc loading for a few (5-10) seconds then the disc is ejected. We had an identical unit that did the same thing about 7 months ago so we...
good day, regardless of the brand it maybe an optic lens problem but i suggest that you buy something branded, much better and worry free. hope this helps
Feb 11, 2010 | Legacy LDVD74 - - Mobile Hi-Fi Stereo...
RCA DRC 8052NB will not read discs
This sound like a problem with the laser read circuits and it may be solved with a simple cleaning and using compressed air to clear the unit of debris .To do this you must take off the top cover of your unit by taking out the screws and lifting the top off. To clean the laser head you should use cotton swabs and isopropyl alcohol. put a small amount on the cotton swab and rub the swab gently back and forth over the head, until it seems bright and shiny.Check the transport carriage for dust and debris and also the gears. all these must be clean for proper operation. You may want to put a little lithium grease on the gears and guide rails for smooth operation. All this should be done in minute amounts so you do not over do it and cause more problems. If all this fails to allow you to use you disc player, Then you probably have a worn out laser sensor and will have to have it replaced. If under warranty send it in and if not try to find the part number and order it and either take in to a service center for repairs or do it yourself. Hope this helps you with your problem.
May 15, 2009 | RCA DRC8052N DVD Recorder
DVD player cannot read DVD disc.
Have you tried other DVD's in this unit and they work? If so it might be just an incompatibility issue with that DVD in your TV.
Nov 16, 2008 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Rd5240p dvd player(RCA)
laser
time for a new machine
Dec 28, 2007 | RCA RC5240P
My RCA 8310 DVD+R/+RW -VCR Combo will not format and record on a +R disc
I purchased this RCA 8310 about 2 years ago. I have recoreded hundreds of dvd's. If I try to use anything but a Imation brand DVD+R, 8+ speed, I get the same error. It will not work with a 16+ dvd.
May 23, 2007 | RCA DRC8300N (DRC8300NWITHREBATE) Burner
Televison & Video Logo
11 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
