Question about LG Radio Communications
Mt65xx headphones icon stay on after disconnect
Always on
My levono C460 system sound is off so no sound what can i do?
Hi
3 possible solutions:-
• Adjust the Windows volume control - select the speaker icon from the Settings Charm or click the arrow on taskbar to show the hidden icons in Windows desktop mode, then click the speaker icon. Ensure that the volume is turned up and the sound is not muted. Adjust the volume, bass, or treble controls to eliminate distortion.
• Reinstall the audio driver.
• Disconnect any headphones from the headphone connector - sound from the speakers is automatically disabled when headphones are connected to the computer's side-panel headphone connector.
I also give a link below to a page from which you can download the full manual for future reference.
Desktops and all in ones Lenovo Series all in ones Lenovo C460 All in One...
Cheers
Oct 26, 2014 | Computers & Internet
My speakers haven't been working properly for a while and I was wondering how to fix this. They sometimes work (very rarely) but then they just cut off, the music will still be playing but I won't be
If it always works with headphone - without fail - then it is likely the fault is within the headphone socket. You'll appreciate that when you plug in headphone, the speakers in the laptop are cut off - which is a mechanical break in connection caused by the plug. Sadly, it sounds like it is staying disconnected.
Nov 24, 2013 | Computers & Internet
Pc headphone volume driver
3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it or you might have to depending on your operating system
Click start Control Pannel
Click on Hardware and Sound
Click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
Feb 18, 2013 | HP/Compaq P4 System - WinXP Pro/Office...
Headphones for a laptop not working
The Laptop has 3 Ports on the side- Pink,Green,Black
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
click on Hardware and Sound
click on Sound
select that!!
hope this helps
Sep 02, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
Just one of the ear peacies work
Hello its most likely a disconnect wire in one ear piece. Bring it back to the place you bought it ( remember the receipt ) for replacement or refund. Good luck
Mar 07, 2010 | Skull Candy Icon Consumer Headphones
Internal speakers stay on even after headphones are plugged in
You can open up your machine an physicaly disconnect them.
Jan 23, 2009 | Acer Aspire 5050-3242 Notebook
Cursor Will Not Stay Put
Try uninstalling the drivers from the device manager, then do a hardware search. It will automatically find the touch pad and reinstall the drivers. If this doesn't work, then check the connector under the keyboard. Disconnect it and reconnect it, they sometimes work loose. If these don't correct the problem, then you have a faulty touch pad and you'll have to replace it.
Jun 20, 2008 | Toshiba Satellite A45-S250 Notebook
Sound Problem
ok paola! the problem is the headphone connector inside the TV.. maybe did not turn back the switch to speaker mode. check the headphone connector (at inside the tv). small problem goodluck paola!!!
Sep 14, 2007 | Samsung LN-S4051D 40 in. LCD Television
Headphone icon
in mobile there is network problem
Jan 07, 2007 | Nokia 6680 Handheld
Radio Communications Logo
15 people viewed this question
Top LG Radio Communications Experts
TO Lady
Computer Repairing
Computer Repairing
Michael Vincent Cruz
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
