Question about True Freezers
Compressor never comes on
Unit runs but compressor never comes on once it tripped the breaker feeding it
    Director Badge:
    Uploaded 100 video answers.
  • True Master
  • 488 Answers
I made video how to replace compressor on true air beer cooler, should be the same for most of prep tables and etc. Hope That helps someone. REPLACING COMPRESSOR TRUE AIR BEER COOLER R134A
Posted on Jan 26, 2015
    Novelist:
    Scholar:
  • 187 Answers
Sounds like a wiring or compressor problem. With the unit unplugged carefully look for burnt wiring. That's the best answer I can give without any information.
Posted on Nov 04, 2014
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Tripping the breaker
Check the start relay. If it is OK the compressor is bad.
Posted on May 12, 2009
bobicehouse
  • 1524 Answers
SOURCE: Everything works fine, except when the compressor kicks in the panel breaker trips.
Most likely a short in the compressor electrical components (relay, overload,capacitor) Supco makes a 3 in 1 that you could use. If this works fine, if not "bad compressor".
Posted on May 28, 2009
heatman101
  • 43501 Answers
SOURCE: freezer light comes on and dim when compressor
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 23, 2010
  • 1078 Answers
SOURCE: Is it possible for a
I would look to see if it is tripping during the defrost cycle. One of the heater elements my be faulty. Never heard of a bad TXV causing a breaker tripping, but I guess it's possible. I would adjust the superheat so that it is about 6 to 8 degrees just prior to unit reaching temp and shutting off. I'd start there.
Posted on Apr 13, 2011
Not cooling
is the freezer plugged into a gfi outlet? outlet may have tripped.
if there is power to the unit: (light on, fan running, etc.)
a large clump of frost around the lines/ top shelf, means it could be a leaker and will need to be replaced.
a clicking, humming noise repeating every few minutes could be a compressor start relay.
if the freezer has tripped the breaker, the compressor has developed an internal short and again would have to be replaced
Oct 31, 2013 | Freezers
I have summit commercial freezer with embraco emi 60her when turn the power on, fan start run then compressor start run about 30 second the trip the compressor. ans i can not see any run or start...
The start relay should be on the side of the compressor and attached to the three prongs that wiring attaches to on the compressor.Is the problem causing the breaker to trip in the circuit breaker box? Sea Breeze
You can have someone match the start relay and the run capacitor at a refrigeration supply store near you or you can contact Summit
HERE
http://summitappliance.com/support
Apr 02, 2013 | Freezers
Is it possible for a delfield freezer 6151 XL-S to trip a breaker every 2-3 hours if the TXV valve was faulty letting liquid get to compressor. This unit has had controller and relay start assembly...
Apr 01, 2011 | Delfield Freezer 6151XLSR Stainless steel
Freezer begun tripping our 20 amp breaker for some reason
ok hi there i viewed the specs for this freezer
http://www.truemfg.com/catalog/servlet/com.apsiva.servlet.HomeServlet
this unit must be plugged into a 120v outlet with a 15amp circuit breaker dedicated (nothing else should on this circuit) so all by itself. you have to check the voltage outlet where you plug in. you must have at least 115v or better (125v the most) if you have less then 115v it will cause damage. ok you went and checked all this out and everything is 15amp with 115v or better and it still trips breaker.
ok the running amps is 6.8 amps so to blow the circuit you need 15 amp which is too high.
i suggest you call a refrigeration guy because he will be able to determine if the problem is the compressor (which has a 4 year warranty with truemfg.com only in the USA) or something else. Usually but not 100% what would make a freezer like yours to blow the fuse is the compressor. if it overheats it will do this, if there is a sudden high pressure within the system it will do it, if you have a condenser fan that is not running at proper speed it will do this...
the problem cannot be pin pointed understand please... you have to babysit it, watch for changes in the refrigeration system and the running compressor amps, voltage drops ( this will cause high amps) etc...
Refrigeration is not easy and alot of tech stay away... so those who stick it out make money cause you have 2 choices: buy another one and pay big bucks to get it fixed. at least see if you can find someone to come over (for like $40 - $60) and tell you exactly whats wrong with it... whew... hope this was helpful and not confusing...sorry
Apr 03, 2010 | True 19 cu. ft. / 538 liter Commercial...
Tripping breaker
Hi, this is not a good sign when a unit trips a breaker. I can tell you whats causing this without having you check every thing on the unit. The compressor has gone out and drawing what we call locked rotor amps. This is what happens when one fails, it is the only part on the unit to draw enough amperage to trip a breaker. To confirm this, you can pull the unit away from the wall and unplug it. Remove the lower panel that will expose the condenser fan motor and coil, and the problem compressor. On the side of the compressor where the wires go into it, you will see a metal strap that is hooked around a black terminal cover. Remove it by using a screw driver lifting one end off. Now the cap will pull straight off. You will see a small round overload relay there and it just sets there with a metal clip that holds it on. Remove it also and it will have a blk wire attached to a compressor terminal, that is marked C for common. You will have 2 more for the other terminals, R for run, and S for start. Just pull them off. Tape the ends of the wires up so they don't touch anything and don't worry where they go as this compressor will be done. After you have done this, Plug it in and set the control to cool. Everything now should work as far as light and fans, and the breaker will not trip with the faulty compressor out of the circuit. It would be much cheaper to buy a new or good used unit then to replace this compressor. This has to be done by an expert on this kind of unit. It was probably shorted to ground a internal burn out. Sorry to give this news to you, but this happens. Keep me posted on what you have done.
Sincerely,
Shastalaker7
Mar 14, 2010 | Freezers
Actually, its a True T-72 refrigerator. After running for a few weeks, the unit trips the breaker and continues to do it unless I leave it off for a few days and then re-plug it in, at which point it runs...
some manufacturers use a heater in a pan for the condensate water that is generated from the defrost cycle. It is usually located near the evap and compressor area. I've even seen them under the condenser coil. Look for a heated pan. You may have a bad heater. When it goes into defrost, water enters the pan and trips the breaker as the heater may be open and water enters it shorting it to ground. Waiting a few day allows the water to evaporate out. And the process starts all over again.
I would look for this first. If this does not pan out, let me know and we can dig alittle deeper. But try to have more details.
Dec 29, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Condensing unit terns off but won't come back on kicks off breaker
If it runs, turns off, then tries to restart and kicks breaker, look for bad start components. Check start relay, start capacitor. It may be trying to restart too quickly and the compressor over amps and breaker trips. The system needs to have at least 3 minutes of off time before trying to restart. This allows the pressures in the system to balance enough so the compressor can overcome the high side pressure and start. I've seen where people turn the control up and down very quickly causing the compressor to over amp and trip breakers and over loads.
Hope this gets it for you.
Oct 22, 2009 | True 19 cu. ft. / 538 liter Commercial...
Kenmore upright freezer model 29238 keeps tripping switch
If the compressor actually runs for more than a second or two its likely the compressor is bad. Some models had a 5 year warranty and some ten years on the compressor only. The replacement of the compressor is likely beyond your abilities unless you are a service technician.
A typical cost for such a repair can be more than the freezer may have cost you if nothing is under warranty. Good Luck.
Aug 31, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
May 12, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Once in awhile, Circuit Breaker Trips
Your compressor start relay contacts may be getting loose or worn, resulting in a delayed start on the compressor.
If the start device includes a capacitor, it could be getting weak.
GFCI are not good receptacles for devices with high starting torque.
Apr 22, 2009 | Frigidaire Freezers
Freezers Logo
157 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
