Question about Fasco 7190-2285 25309101 1/15hp 20-230 50-60Hz 1550rpm OEM Direct Replacement Motor D1123
Need wiring diagram for fasco d1127 to wire for 115v
No wiring diagram on motor for 115v or 230v
3 Suggested Answers
SOURCE: I need a wiring diagram for Fasco model #659
Yellow wire is light. Blue is vent. Red is heat element and fan after going through a circuit breaker and thermostat. Brown is night light. White is common to ventilator housing. Black is power to switch cluster.
Posted on Feb 10, 2010
SOURCE: Electrical information about Fasco A2540T in wall heater
go to google and then type inA2540T in wall heater" "electrical information about Fasco it will show you some results and then youi can click on any one you like.
Posted on Sep 29, 2012
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
I have a AO smith ST1152 and red black and green wires. How do I wire it
Verify the voltage to the pump. These days motors and pumps largely are set to run on 230v out of the box (for in ground pools). If your supply voltage is 115v, the motor will run at half speed. This would cause poor suction. If this is the case, do this:
On the side of the motor there is a diagram on how to convert the wiring from 230v to 115v so it will run on the correct voltage. Most of the time, that's the issue. Flip the breaker off before working on it.
Nov 30, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
Changeing 115volt to 230 volt
Most power Flo pumps run above ground pools and run on 115v only.You can look at the wiring diagram on the motor label to see if it is convertible, it will show wiring configurations and amps for both 115v and 230v. If not, it is a 115v motor only.
Sep 11, 2013 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
Wiring diagram 3/4 hp boat lift motor
It will be dependent upon the line voltage and switching mechanism...
Please advise drum switch or relays?
115V or 230V
Remote control present?
If a drum switch, is it a 6 or 12 terminal model or some other configuration?
Make and model of the switch?
There may be more questions depending on the answers to these...do you have a wiring diagram for the control? Are you replacing a motor and have the old and new motor schematics?
John
Apr 10, 2011 | AO Smith A O Smith Motors Century 1hp 115v...
Just installed a new pump. After one minute of operation it shuts down. Why?
The pump is capable of 115V or 230V operation.
Most likely what is causing your pump to shut down is the thermal overload.
Possible causes of thermal overload:
1. 230 V winding powered by 115V
2. 115V winding powered by 230V
Recheck your connections per the diagram either in the owners manual OR on the label of the motor.
When a NEW pump has issues almost every time the problem is in the connecting wiring either from the main power supply or on the motor terminal lugs.
Just look closely at the wires.. IF your absolutely sure that it is connected correctly. Go to the main power panel.. Push the CB for the pump to OFF hard and then back to on. (This resets the breakers) If it repeats... the symptoms... I need to know what wires you have connected up on the motor to what terminals by LABEL of each terminal.
Kelly
Jun 29, 2010 | Polaris Pb4 - 60 Booster Pump
Change wiring from 230v to 115v
There should be a wiring diagram on the name plate of the motor, or inside the wiring compartment or on that cover . Would be something with dots and HI , LO, and wire numbers.. or just a notation of 120 , 220 volts.
How is it wired now?
May 10, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
My motor is wired for 230v and I need it to be 115v
It should be. Look closely at the motor nameplate and you should see a small diagram telling how to connect the motor for 115v or 230v. Most newer pumps have a small selector of some sorts. Either a plug that pulls off a couple post the include an idicator arrow for where to set the plug for either voltage, or a dial you turn to show it. Either way, you should be able to set the motor for 115 rather easily.
Jun 14, 2009 | Pentair Whisperflo 3/4 Hp 115/230v
Got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside.
Good Luck
Kurt
Mar 18, 2009 | Waterway Champion 1 1/2 Hp 230v Energy...
Fasco 7190-2285 25309101 1/15hp 20-230 50-60Hz 1550rpm OEM Direct Replacement Motor D1123 Logo
220 people viewed this question
Top Fasco Plumbing Experts
Donni Steen
Tom Chichester
Are you a Fasco Plumbing Expert? Answer questions, earn points and help others
