Question about Sewing Machines
My brother ve2200 has acode TC-PM
Whole sewing my thread got jammed and I broke a needle. Fixed everything and then tried to resum sewing then the machine was making a horible sound and a code TC-PM came up my needle is in a down locked position I cant raise the needle or the pressure fooot.
SOURCE: bobbin thread getting jammed
kyoungblood4
Are you making sure that your pressure foot is up when you thread the upper thread? If it isn't then your thread is not seating correctly in the tension disks. It will then be loose and make a birds nest(mess) under what you are trying to sew. The other thing to check is which way you are putting the bobbin into the bobbin case, different machines do it different ways. Some want the thread to come out of the case in the same direction as the slot on the case and some want it to come off in the opposite direction.
Guest,
Probably when your son broke the needle he knocked it out of time. You will need to have a sewing machine technician to repair that.
Hope this has been helpful for you bothl Liz M
Posted on Aug 08, 2008
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
SOURCE: Brother CS-6000 Sewing Machine - Jam
I had the same problem.. I think the bobbin used in this machine is no good I replaced mine.. It cost alot too.. but now I do not have any problems.. good luck
Posted on Aug 20, 2008
SOURCE: not sewing - jamming
Could it be that the feed dogs are down? I also have the 15358 and when I opened the bobbin area to clean it, I had this problem. Apparently, when you open the clips around the outside of the casing, it pushes the lever that adjusts the feed dogs to the right (lowering them). I didn't even realize it at first. Check your manual for adjusting this lever to raise the feed dogs. That might solve your problem.
Posted on Feb 15, 2009
SOURCE: Juki TL98Q needle thread breakage
Use a thread stand and rethread.
Posted on May 23, 2010
Machine is jamming. Top thread broke so re threaded and re did the bobbin,but it is still jamming every time i try to sew
just found this on the internet...
Fabric jamming in your machine may be caused by the feed dogs. The feed dogs are those tiny teeth along the sewing machineunderneath the presser foot as those teeth pull the fabric through when the needle is making stitches.24 Feb 2016
Why Does My Sewing Machine Keep Jamming?•Sewing Made Simple
sewingmadesimple.net/why-does-my-sewing-machine-keep-jamming/..
or go to this link..
sewing machine is jamming Google Search
Oct 27, 2017 | Sewing Machines
How do I get my machine to start sewing and stop beeping?
try rethreading the machine--use EVERY thread guide
make sure the needle is inserted up into the needle holder and turned the right direction
make sure the bobbin is inserted correctly into the bobbin case and turned the right direction
clean under the needle plate and in the bobbin area for loose thread or lint
make sure thread has not come off the thread take up lever
also the jam could have caused the machine to jump time and needs a timing or a adjustment
Jun 06, 2015 | Singer 7436 - INGENUITY
My sewing machine will not stich. i have tryed everything i can find on this problem but nothings working
Make sure nothing has either gotten stuck/caught/jammed somewhere inside it. Insure that the thread stays attached to the needle. Or the material you are trying to sew/stitch may be too thick.
Nov 17, 2012 | Singer Sewing Machines
I was sewing some thick cloth and my needle broke. Now it want sew a good stitch. It keeps unthreading from the needle like its not feeding the thread right. I have to retrhead after I try a stich. It...
Hi, make sure there are no needle parts stuck in the bobbin/feed dog area. Also,make sure there is no lint in the same area. In my sewing experience, lint jams up smooth operation of all sewing machines.I would take apart the bobbin case, clean it and reinsert. Also, make sure that it has been oiled according to the instructions in your manual. Another issue which sewers forget about is changing needles....if there is a burr on a needle, threads break, don't feed properly, create more fuzz and eventually break. I hope this help you.
Happy Sewing.
Jul 15, 2011 | Singer 3116 Simple
The tension wheel 0-9 does not work. How can I repair this problem. Ginette
start by making sure nothing is jamming it oen, like a thread
Sep 09, 2010 | Sewing Machines
On my Singer Scholastic, the thread jams in the bobbin area
It sounds like it is not threaded properly through the tension disc. Try rethreading and make sure the presser foot lever is in the up position. If it continues, once threaded and with the presser foot down, pull on the thread through the needle. If it has resistance, it is threaded properly. If it pulls easily then there is a problem in the tension area. Check to see if there are peices of thread broke off in between the tension disc.
Feb 06, 2009 | Singer Sewing Machines
Thread jams in bobbin area
well i have done the same thing , all u need to do is if you see the screws that hold the bobbin area you un screwq thoes and get you a pair of scisors and cut around the knoted mess and all you do is work with it until it is all out and you dont realy want to pull on it to much you know just work it around so it gets lose so that you can cut it out thin you put it back together and try it out.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Bobbin thread getting jammed
kyoungblood4
Guest,
Aug 07, 2008 | Sewing Machines
Lower loop broke- do I have to start from step one?
yes, take all threads out, and re=thread according to the diagram, following the threading order.
Mar 02, 2008 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
55 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
