Question about Epson Computers & Internet
Printer prints page 12345x pjl and wont stop what can I do?
I have unistalled the printer from my computer, turned the printer off at the socket for over half an hour, emptied the spool folder and when I turn the printer on again it still prints this PJL gobbldeygook... Help please
2 Suggested Answers
SOURCE: OKIDATA 490 printers started printing the
We had this same problem and discovered that some vendor installed a program called "Print Track" which discovered every printer on the network using port 9100 and sent a query for how many pages were printed. Removing this software from the offending PC resolved this issue. We used the "job log" from one of the Okidata printers to find the IP address of the PC that was causing this.
Posted on Jul 09, 2009
Does ExtentNet 100x support Zebra printer language ZPL2?
It doesn't support it directly, but it shouldn't prevent it from working. However it might be sending extraneous PJL commands between print jobs (example @PJL -12345X) which could mess up a label. ZPL is basically ASCII, the ExtendNet shouldn't prevent ASCII delivery.
Feb 14, 2011 | Extended Systems ExtendNet 100X Print...
The printer first prints - -12345X@PJL JOB NAME = “WindowsNT” befor it prints anything els
Have you tried reinstalling the driver?
I think this sounds more like a driver or compatibility issue, I would say uninstall the printer then reinstall it, If you are not comfortable doing it we can help,
We can remote login and help you if need be. Just let us know
Oct 06, 2010 | OKI C5400 Laser Printer
OKIDATA 490 printers started printing the following and there were no changes made to any software/network/hardware. The emulation is and has always been Epson LQ - ''12345X@PJL @PJL INFO PAGECOUNT...
Jul 07, 2009 | Computers & Internet
Printer wont print
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 26, 2009 | HP DeskJet F380 All-In-One Printer
The printer is printing an addition page each time a page is sent
Are you using a custom written language application or are you using an application such as Word?
It appears that you are using a PJL wrapper around the print job. Please create a print to file (off of the driver screen) and send it to me at janddgasrepair@verizon.net. I'll be able to look at the job and see what ie happening.
Right now I suspect that you are not clearing out the PJL properly.
Don
Apr 04, 2009 | Lexmark T520 Laser Printer
How to change the density of the printer HP LaserJet 5p
I'm afraid this won't be of much help to the original poster, who asked the question a year ago, but anyway - others may be looking for this too, just like I did...
To change the print density, a simple command must be sent to the printer. This is done in two steps:
  1. Create a file, containing the command
  2. Send it to the printer ("copy" it to the printer, in a DOS shell)
The command is:
<ESC>%-12345X@PJL DEFAULT DENSITY=4
where <ESC> represents the "Escape" character (character code 27). There are several ways to generate the Escape character (which cannot be directly entered in a text editor): E.g. substitute the character with any other, save the command and then replace the first character with 0x1b using a hex editor.
Or:
  • Open a DOS window
  • Enter:
    copy con density.txt <Enter>
  • Hold the <Alt> key
  • type 27 on the numeric keypad
  • Release the <Alt> key - the Esc. char. is shown as ^[
  • Type the rest of the command (e.g. %-12345X@PJL DEFAULT DENSITY=4) - adjust the density value to the one you actually want to set.
  • press <Enter> <ctrl-Z> <Enter> to write the file
When you have successfully created the command file, send it to the printer. In the DOS window, enter:
copy density.txt LPT1
(assuming that your printer is connected to LPT1)
That's it!
To verify that the density has actually been set, print a printer status page.
The printer remembers this setting, so this needs to be done only once.
Mar 31, 2009 | HP LaserJet 5p Printer
HP LaserJet 3330 prints a configuration page after each print job
If you scroll through the menu functions to service, you can restore factory defaults. If you use the fax function you'll need to run the AiO assistant again. It may take care of it. I didn't see anything on the config page or the menu structure page that would indicate an option to require a print report after each document.
Mar 23, 2009 | HP LaserJet 3330 All-In-One Printer
LaerJet 5p Extra page prints with code
check all your application.(word, Excel) by going into print preview, you might have a single black page at the begining. ( this happens when you save the templete with a blank page.)
if that is not, let me know. got to go one step at atime.
Oct 28, 2008 | HP LaserJet 5p Printer
Computers & Internet Logo
602 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
