Question about Life Fitness 91Ti Treadmill
Belt keeps slipping on treadmill and belt is all the way back
Treadmill belt keeps slipping even though its as stretched as far as it can be
    New Friend:
  • 69 Answers
  • Life Fitness Master
  • 918 Answers
If you have adjusted the tension on your belt to the max, it is more than likely time to replace your running belt. The running belt naturally stretches over time. I would suggest replacing the belt and flipping your deck. If the deck has already been flipped once, then you would need to replace the deck as well. Life Fitness Treadmill Belt and Deck Replacement Video 95T
Posted on Apr 23, 2014
3 Suggested Answers
guru_fixya
  • 944 Answers
SOURCE: Problems: My Life Fitness
You must calibrate the belt with a Allen wrench 5/16 inch turn in the direction of clockwise at a speed of 1.5 to reach 4.5MPH you must turn the key gently to prove that you slide about 10 seconds walk.Use WD40 oil on the joints to make it noise free.
http://www.treadmilldoctor.com/Troubleshooting
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Feb 11, 2011
ercupa190
  • 12223 Answers
SOURCE: slipping belt
see the video and fix it. God bless you
http://www.youtube.com/watch?v=38w4PkiWIBY
Posted on Oct 18, 2012
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension a treadmill belt when it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures for how to tension a treadmill running belt.
  1. Adjust for no slippage of the treadmill walking belt on the front roller (Often referred to as the "Stomp Test")
    1. This procedure works well for a previously installed belt that is now slipping.
    2. Underside of belt should be free of any glazing/wax buildup.
    3. Rollers must also be free of wax buildup.
    4. Be sure belt tracking/centering is correct before proceeding.
    5. The most popular speed for this adjustment is 2mph to 3mph.
    6. Try to slow the belt by applying pressure with your foot against the belt movement while grasping the handrails. If the running belt slow, slips or stops (and the front roller does not) adjust BOTH adjustment bolts 1/4 turn clockwise. Test again and repeat adjustment if necessary.
  2. This procedure requires two belt gauges or calipers
    1. This procedure works well when installing a new belt.
    2. This procedure requires you to stretch the belt. Depending on the manufacturer*, this varies between .4 and .6 percent. A dial on the gauge or caliper will indicate the amount of stretch. *Consult the owner/service manual for proper tension.
    3. If you are working on a previously tensioned belt you will need to release the tension before attaching the gauges or calipers.
  3. Gauges or Calipers unavailable
    1. Release the tension on the belt.
    2. Using a yard stick or tape measure, place two marks on the left and right edges of the belt and deck 36 inches apart (or 50 inches if you prefer).
    3. Adjust the left and right tensioning bolts until both sides measure 36 3/16 inches (or 50 1/4). This is equal to .5% of stretch.
    4. Test for proper tracking and tension, adjust if necessary.
How to Tension Treadmill Walking Belt that Slips
Apr 01, 2014 | Life Fitness 91Ti Treadmill
Tip
Treadmill belt slipping
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Why Your Treadmill Belt Maybe Slipping
With a treadmill, one of the most common issues people experience is a belt that's slipping. There are a few reasons this might happen. Luckily, there are also a number of fairly simple ways to fix this issue that you can do on your own, without calling anyone to service the machine.
Why Your Belt Might Be Slipping
There are actually two belts on a treadmill - there's the belt most commonly talked about which is the walking / running surface of your treadmill. And then there's the drive belt which connects from the motor to the front rollers. In this case, we're discussing the walking surface of your treadmill.
There may be a few reasons why your belt is slipping. Before trying to figure it out on your own, or even with general instructions like these, you want to check the manual produced by the manufacturer of your machine.
This is especially important if your machine is newer or still under warranty because the warranty may limit what repairs you can do yourself. Many warranties specify that only a repair service authorized by the manufacturer can perform certain repairs, so that's something to keep in mind before moving forward.
  • Too Much Friction. In some cases, the belt may need to be lubricated because the friction may be causing the belt to slip. Be sure to check your owner's manual for the compatible lubrication.
  • Tension. Most often this is just a case of needing to adjust the tension of the belt. With use and age, the belt can naturally stretch, losing some of the tension and causing the belt to slip. There are a number of methods to correct this which we'll discuss in detail below.
  • Drive Belt. In some cases, the running belt may be stopping because the drive belt needs to be tightened on some models. This can be performed at home, though you'll want to check your manual. This type of repair will usually void the warranty if there is one.
Adjusting the Tension in Your Running Belt
If your belt is slipping, it's usually a matter of adjusting the tension. There are three different methods to repair this issue, which work on new belt installations as well as repairing existing running belts.
Stomp Test on Front Roller
The stomp test is a great way to test the retention on your running belt and repair an existing belt that's slipping.
  1. Check the rollers and underneath the belt to make sure there is no debris or wax buildup.
  2. Verify that belt centering is correct or true.
  3. Stand on machine and set to 3 mph.
  4. Attempt to stop the running belt from moving by bracing your feet on the running belt and your hands on the bar.
  5. If the belt slows or slips and the rollers are still moving, your tension needs to be adjusted. To do this, turn the adjustment tools on both sides of the rear roller to tighten, about a quarter of a turn to start.
  6. Repeat test and adjust until the rollers stop moving when you stop the belt.
Using Belt Gauges
For most belt replacements, using calipers would be a preferred method. It can be done without gauges, though this does make the process slightly simpler. Gauges can also be used to adjust machines with existing belts.
  1. Using belt gauges or calipers, you're going to stretch the belt according to the manufacturer's specifications.
  2. This method is usually used on a new belt but can be performed on a machine where the tension just needs to be adjusted. In the case of an existing belt, you need to release the current tension before applying the gauges.
Without Using Calipers
  1. In the case of an existing belt, release the current tension before proceeding.
  2. Using a tape measure, put two marks on each side of the belt, 36 inches apart in the length.
  3. Then adjust the side bolts on both sides to 36 and 3/16 inches.
  4. Test the machine and adjust if needed.
There are a few reasons that your treadmill belt might start slipping. It could be a simple matter of age and use. A lot of activity on the machine or heavy running can also cause the belt to stretch faster than moderate use might. Armed with this information, you should be able to diagnose the issue. Some repairs may be more advanced than what we've detailed here and it's always advisable to check the manufacturer's manual before attempting any repairs.
Additional Resources:
Treadmill Running Belts
Sportsmith Blog
on Jul 27, 2016 | Exercise & Fitness
New running belt tracks to thr left
Feb 04, 2014 | Precor C962i Treadmill 220V
Walking belt alignment how to
Jan 07, 2014 | Precor Treadmill Belt 9.10, 9.2 Treadbelt...
How do I tighten drive belt on precor 956i
Jan 04, 2014 | Precor 956i Experience Series Treadmill...
Walking belt slipping
Dec 22, 2013 | Precor Exercise & Fitness
Adjust belt side
Dec 19, 2013 | Precor 9.21 Treadmill
How do you adjusting the running belt on precor 9.1 treadmill
Mar 13, 2013 | Precor Exercise & Fitness
Precor c944 treadmill belt slipping
Feb 05, 2013 | Precor C944 120 Vac Version 1 Treadmill...
My Nordic Track C2000 walking belt keeps slipping while I stand on it, what are some possible solutions?
Could be out of adjustment. Belts will stretch with time and there should be a mechanism for keeping the tension, but if you've exceeded the limit, it might slip.
Feb 23, 2010 | Exercise & Fitness
Life Fitness 91Ti Treadmill  Logo
368 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
