Question about GE GTS22WCP Top Freezer Refrigerator
Defrost timer location on GE refridge
Refridge freezes if not used for several weeks
  • 126 Answers
SOURCE: Frozen Freezer Coils
all of the above the heater is on the coil you will seethe wires the therm. is on the top of coils timer could be at lower back of refrig.
Posted on Dec 14, 2007
MNTECH
  • 1543 Answers
SOURCE: freezer freeze up
Your model TFX20JRBKWWW uses a defrost timer part number WR9X489 located behind the light shield in the fresh foods compartment. (top back area). Just in case you need to know, the defrost heater is a part number WR51X10101 located behind the back wall of the freezer.
Posted on Dec 26, 2008
MNfisherman
  • 11896 Answers
SOURCE: Ge Profile Top freezer-not cooling/not freezing
Evaporator fan motor inside the freezer is working? Any frost on the freezer back wall?
This is the fan inside the freezer section, it will circulate the cold air around in the freezer and blow the cold air from the freezer into the fresh food section, it also sucks the warm air from the fresh food section back into the freezer to be re-cooled.
Hot condensor coils ( under the refrigerator ) been cleaned recently?
**GSS25LGMA**
That is part of a full model#.
00082692.jpgEvaporator fan motor
Posted on Jan 21, 2009
peyton32034
  • 410 Answers
SOURCE: Where is the defrost timer located on a GE model
The defrost contrlol is located behind the light lens cover in the fresh food section. it is to the far right side of the control console.
Posted on Mar 01, 2009
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
Ge side by side ref.
no,its more than likely the defrost heater located just under the coil thats freezing up,check this heater for continuity,if its o.k. then test the defrost thermostat thats clipped onto the same coil near the top of the coil,note,the defrost thermostat needs to be below 15 degrees to check good as its a thermal switch,then if still problems then check the main board in the back of the unit behind a panel this is where the defrost circuit gets its power,but i will likely say its the heater thats open because i replace about 5 per week with the same issue as yours
May 22, 2012 | GE Refrigerators
After unplugging and defrosting my ge tfx20nw it
Good day,
The defrost system has failed. It is made up of a timer, defrost thermostat, and defrost heaters.
The timer is located behind the light guard in the fridge compartment.
The heaters and defrost thermostat are located in the freezer compartment, behind the back wall.
To test,
1. With the machine running, in the fridge compartment, pull off the thermostat knob, and then unclip the light guard.
The timer is behind the panel exposed, but has a hole to insert a small screw driver to advance the timer.
Turn the timer clockwise until the machine shuts off. Wait 45 plus minutes. If the machine turns itself back on the timer is good.
If not, remove the panel, and install a new timer.
2. If the timer is O.K. then the problems are in the panel on the rear of the freezer compartment.
Unplug the machine, and remove the rear panel. Allow it to defrost.
There are two quartz radiant heaters, one located on the bottom of the evaporator coil, and one half way up. There is also a defrost thermostat clipped to the top of the evaporator. It is a round disk about an inch in diameter.
Purchase and replace all 3. You may need wire nuts to splice wires together so purchase them as well, when getting the other parts.
Go slow, the heaters are easily damaged or broken if handled roughly.
Dec 15, 2009 | GE Refrigerators
My GE refridge model GSS20DBMB WW freezer coils keep freezing up! I have replaced the door seals as an appliance center recommended. However, It did stop it from freezing up! we have to use a hair dryer...
Something has gone wrong with the defrost system. It could involve the defrost timer, the evaporator heater, or some of the wiring.
This problem would take some troubleshooting that most do-it-yourselfers would likely not be able to do.
Oct 18, 2009 | GE GSS20DBM Side by Side Refrigerator
GE Model # DSS25PFMD WW, lights and fan are working not cooling
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 21, 2009 | GE GSS25JEM Side by Side Refrigerator
GE side by side. The freezer will freeze up with
Replace the defrost heater, located at the bottom of the cooling coils, behind the back wall of the freezer.
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
Jun 12, 2009 | GE PSC23NHN Side by Side Refrigerator
Replaced defrost heater lights are working but no motor is coming
timers are top right on refridge or bottom left beside compresser or you have a circut board that would ge a ge
Apr 16, 2009 | Refrigerators
Freezer freeze up
Dec 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Nov 15, 2007 | GE GSS25JEMWW Side by Side
GE GTS22WCP Top Freezer Refrigerator Logo
44 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
