Question about Bosch Garden
My Bosch cordless chainsaw only peeps at me and will not operate
My Bosch cordless chainsaw will not operate and although the battery in green when I pull the trigger it only peeps at me
SOURCE: Kawasaki 19.2 cordless drill
Re: Burned trigger switch: call the number on the drill (800.590.3723) and tell them what happened. They will offer to send you a new switch or have you send the drill in for replacement of the switch--although the person I talked with said they would probably just replace the whole drill.
Posted on Apr 24, 2009
VtToolMan
  • 704 Answers
SOURCE: black and decker cordless drill trigger
Ok, first check to see if the trigger lockout has been engaged, it's a small level at the top of the trigger ( I know this sounds silly, but it happens sometimes). Flip it side to side to see if you can hear the selector moving the switch inside the drill. If the selector moves freely without engaging the switch, you'll have to disassembly the drill housing to put the selector back into the lever so it will work.
Just take out all the screws in the housing and carefully remove the one side and look at the switch lever and make sure it is inside the slide selector lever.
If that isn't the issue, I'm afraid that the electric trigger/switch has failed and this isn't a part that can be disassembled and repaired by a DIY'er. I've attempted it when mine failed and found out it's a sealed unit and wrapped in a copper heat shield that dissapates heat when the variable speed is utilized and you end up destroying the switch housing in the process.
However, any DeWalt authorized repair center can do the repair for around $20 +/-, and if your drill is under the 3 year warranty period, it should be a free, warranty repair. Just contact DeWalt's customer service or your local Authorized Service Center (listed in phone book usually), or check the link for finding one near you.
www.dewalt.com or call 1-800-4-DEWALT (1-800-433-9258
Click on the "Services/Support" tab to get info. You can also buy the replacement parts if your drill is out of warranty (call them to verify before takin it apart!) and do the repair yourself.
Hope you find this Very Helpful and best regards!
Posted on Sep 12, 2009
  • 8404 Answers
SOURCE: Chainsaw will start and idle if choke is pulled
Let it warm up first ...
Posted on Oct 05, 2009
  • 2239 Answers
SOURCE: Chain will not stop spinning
I would say it has an air leak, through a gasket or crank seal, make sure the carb is tight and sealing properly.
Posted on Jun 15, 2011
johnrossbate
SOURCE: Bosch cordless drill not working.
HI my Bosch PSB 18 LI-2 has stopped working. while it was in use I noticed a small amount of smoke come from the drill, then the drill stopped! When I pull the trigger the light comes on as does the battery charge indicator. What could be wrong? would it be the brushes?
Posted on Oct 06, 2015
I have a 18 volt nI cad Bosch charger .can I get it repaired and by who
Have you tried a tool repair service? My husband is always seeking advice from the tool professionals. Due to constant use, his chargers stop working often and, although he is a handyman himself, there are times when his own knowledge isn't sufficient. bourgetbros com
Aug 07, 2015 | Bosch Drills
My Bosch chainsaw is very temperamental. It try's to start but usually won't kick in until I have given it a few thus. Even then every time I stop the saw it will not start again. The battery is full...
My brother used to sell chainsaws to fire departments.His rule was always do two things first: 1) Get new gas -- it doesn't matter how old you think your gas is. 2) Replace the spark plug -- again, it doesn't matter how new you think it is. He says that this solves 90% of all starting problems.
Jan 12, 2014 | Bosch AKE 30 LI Cordless 36V Chainsaw with...
Replace fuse
There will be a micro switch on the hand guard, so make sure the hand guard is pulled fulley back toward the top hanle, now try again.
Feb 23, 2013 | Bosch AKE 30 LI 36 V Cordless Chainsaw...
First The model is pretty new. you need to register your tool on line. this takes you from a one year warranty to a three year warranty. They will give you a pro-vantage number. with that said it sounds like a trigger switch. Yhe trigger switch is the brain of your tool. not only does it do your variable speed but it also controlls the brake and your fuel gauge. Because of the cost I highly recomend taking it to your closes Bosch service center.
Oct 13, 2012 | Bosch Cordless Impact Driver, 18V, 1/4 Dr,...
Ryobi battery chainsaw 10" - How do I tighten the chain?
loosen the two nuts that hold the chain cover on. Once they are just loose, then use a flat blade screw driver to turn the slot that you see right next to the base of the chain. Once the chain is tight, retighten the two nuts.
May 23, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
36 volt battery won't charge
Get a voltmeter and check for the output voltage of the charger. Should be greater than 36 volts. Also make sure that the voltage is getting to the battery via connectors. Just be careful around lithium batteries - they can blow up of short circuited!!!!!
Sep 14, 2017 | Office Equipment & Supplies
NEED INSTRUCTION MANUEL
I found your saw here:
http://www.bosch.com/content/language2/html/3381.htm
it's 230v and a european model. I went to the United Kingdom and downloaded an operators manual for it here:
http://www.bosch-pt.co.uk/boptocs2-uk/modules/oragetblob.dll/42970.pdf?db=boptocs&item=OCSHEIMWPDF.m$d$lobvalues&id=42970,4248,20&filename=AKE35-18S.pdf
SURPRISE it's not in english. GL
Lou
I recommend you NOT attept to wire it for 120VAC operation.
Apr 18, 2009 | Bosch Garden
Unable to locate a replacement battery
You can get a replacement 9.6v bosch battery here
bosch battery
Mar 04, 2009 | Bosch & 9.6V Drill/Driver
Garden Logo
24 people viewed this question
Top Bosch Garden Experts
roeb
George Merkley
George Merkley
Are you a Bosch Garden Expert? Answer questions, earn points and help others
