Question about Pavilion g7-1219wm Notebook PC
Screen flickering on off
Powers on then off over and over
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 189 Answers
You may have a loose or bad video cable - you can often remove the top cover to check the connections or the condition of the cable/s. Or a repair shop can do it it easily.
Posted on Feb 08, 2015
Flickering light and screen
The power supply may be failing.
Mar 19, 2014 | KDS Computers & Internet
Screen flickering, flashing colors,
Disconnect the power cord and battery. Hold down the power button for a minute and then connect only power cord.
If not fixed:
Please scan your computer with free version of superantispyware:
http://www.superantispyware.com/
IF not fixed: It is a screen hardware issue.
Jul 09, 2013 | Dell Latitude D630 PC Notebook
I can only add 2Gig of Ram on my Acer Aspire t180 XP. The screen flickers when I add more. Help
The usual cause of screen flicker is a lack of power getting to the graphics card. The best way to check this is to remove another component to see if the flicker stops. If it does stop you need to upgrade the power supply.
Upgrading the power supply is a simple job. Let me know if you need more information on replacing the power supply.
Dec 27, 2010 | Acer Aspire™ T180 PC Desktop
My laptop screen flickers when I connect the power adapter to it.
Hi
And it still flickers? Have you tried attaching a secondary monitor? If the external monitor is not flickering then the problem is the inverter for the laptops screen. If you see the flickering there then the problem is on the laptops mother board, maybe power regulation or video processing. If this is the case it will mean a mother board chip replacement.
Mar 29, 2010 | Gateway M305CRV Notebook
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Screen display is not stable.screen flickers
CHECK IN BIOS. If the screen is flickering in BIOS then it is hardare issue.
1.Please power ON the notebook, Keep tapping F10 as soon as you power it ON.
2.Press the F9 key to reset the BIOS defaults, it will ask to restore defaults. Hit Yes.
3.Press F10 and save the changes.
In BIOS please check if you can see the flickering. If the screen is same in BIOS then it is hardware issue. If you do not see the screen flickering in the BIOS then please update the BIOS and graphics driver
Feb 09, 2010 | HP Computers & Internet
THE SCREEN FLICKERS ALL THE TIME, HOW CAN I FIX IT
The screen flickering could be the screen inverter starting to fail. The inverter sits under the screen behind the bezel, it takes the low voltage DC power from the power adapter and converts it to high voltage for the screens backlight. If the inverter starts to fail, you either get a dim display that finally goes dark or get flickering like you see in some store lighting fixtures when the flourescent bulbs are failing.
Jan 15, 2010 | Acer Aspire One AOA150-1570 Notebook PC
DS Lite wont power up, just flickers and goes out
ur problem with top screen.the strip may be damaged change the top screen .
Aug 29, 2009 | Nintendo DS Lite Console
Flickering monitor
Flickering screen display
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
  • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
    • a TV set
    • a laser printer
    • another monitor
    • fluorescent lights
    • hidden power lines
  • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
  • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
  • The number of devices using power from the same electrical line. Are you overloading the plug?
  • Monitor placed on an unstable surface.
  • Improper video drivers, this is a software problem, see section B
  • An improperly configured or a defective video card.
Sep 30, 2008 | E-Machines E17T 17" Flat Panel LCD Monitor
Screen flickers upon power up
Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
Cheers!
IrishDruid
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Pavilion g7-1219wm Notebook PC Logo
18 people viewed this question
Top Pavilion Computers & Internet Experts
Donna Sander
Josh Whitehead
Josh Whitehead
Are you a Pavilion Computer and Internet Expert? Answer questions, earn points and help others
