Question about Building Materials
Trying to program garage door opener in a 2014 Bently to a Hurmann opener with no luck
  • 118 Answers
SOURCE: jag xj6 1996 97 programming the garage door openers
1. For first time training, press and hold the two outer HomeLink buttons, releasing only when the HomeLink indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink buttons.) 2. Position the hand-held transmitter 1-3 inches away from the HomeLink surface (located on your visor), keeping the HomeLink indicator light in view.
3. Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.)
property_damage_symbol_sm.gif Note: Some garage door openers may require you to replace step 3 with the “cycling” procedure noted in the “View Canadian Instructions” section.
4. Press and hold the trained HomeLink button and observe the indicator light.
  • If the indicator light is solid/continuous, training is complete and your device should activate when the HomeLink button is pressed and released.
  • If the indicator light blinks rapidly for 2 seconds and then turns a solid/continuous light, proceed with the following training instructions for a rolling code device. A second person may make the following steps quicker and easier. Please use a ladder or other device. Do not stand on your vehicle to perform the next steps.
5. At the garage door opener receiver (motorhead unit) in the garage, locate the “learn” or “smart” button (usually near where the hanging antenna wire is attached to the unit). If there is difficulty locating the training button, reference the garage door opener’s manual or contact us. 6. Press and release the “learn” or “smart” button (the name and color of the button may vary by manufacturer). NOTE: Once the button is pressed, there are 30 seconds in which to initiate the next step. 7. Return to the vehicle and firmly press and hold the trained HomeLink button for two seconds and release. Repeat the “press/hold/release” sequence up to 3 times to complete the training process.
Posted on Jan 30, 2009
  • 1348 Answers
SOURCE: programming garage door opener
there are three buttons on the opener.hold the 2 outside ones down for 25 to 30 seconds to erase the program. once the light (if equipped)flash rate changes,let go.
then push any one of the the three buttons and hold it in. and then push your remote. when the flash rate changes,the code is now in the homelink transmitter.the slt and slt plus had that feature.
Posted on May 14, 2009
turo1000
  • 18 Answers
SOURCE: program instruction garage door opener in 2005 chrysler pacifica
if your garage motor have rolling codes you need to put your car inside garage near the motor leave ignition on go to the motor locate learn button press it then quickly go to the car and press and hold one of the buttons for approximately 30 sec or until it start blinking rapidly, if you have a regular motor take one hand held opener go inside car ignition on same time press open button on handheld remote and on the car button 30 sec and it should be programmed.
Posted on May 18, 2009
  • 9 Answers
SOURCE: program a garage door opener in 2004 buick rendezvous
I cannot find the 2004, but you can buy it from the dealer. You can download the 2003 and 2005 from this link. http://www.extendedgmwarranty.com/owners-manual/buick_owner_manuals.html
Posted on May 22, 2009
  • 3197 Answers
SOURCE: 2006 Honda Accord Garage door Homelink Program with Chamberlain
useful info.
Posted on Sep 14, 2009
Starts with the remote but shuts off when a door is opened
Garage Door Opener Troubleshooting step by step - YouTube
? 3:41
https://www.youtube.com/watch?v=b8w2w5ZAc1I
Feb 5, 2014 - Uploaded by Andrew Hill
How to Fix A Garage Door Opener - the opener shown is the Craftsman 1/2 HP ... First start with the obvious and easy to check problems. ... opener button on the wall will open the garage door but not your remote or keypad, ...
Auto Start Engine Shuts Off When open door -
The Top 10 Reasons Your Garage Door Won't Work
customoverheaddoors.net/reasons-your-garage-door-wont-work/
Jun 5, 2014 - To help you troubleshoot your garage door issues, here are the top 10 ...Garage Door Closes Part Way, Then Opens Again ... Automatic Garage Door Opener Runs for a Few Seconds then Turns Off but Door Doesn't Move
Jan 05, 2016 | Building Materials
Need to program car remote control with garage opener
your owners manual has a description in it about how to do this. the controls on the opener can be set with the controller from the manufacturer, then the car. need to read the manual
Feb 24, 2015 | 2014 Ford Escape
How do I program the garage door opener receiver on the garage after programming the garage door openner on the vehicle?
after you do the programing for the car you have to go back to the opener and press your learn button once. Then go back to your car and press and HOLD the button you just programmed your should see your light bulb blink on your opener after about a second or two.
Jan 27, 2015 | Building Materials
Programming remote and in car garage door openers to the Craftsman AssureLink Garage Door opener - Model - 139.3043
The opener radio is not compatible with your homelink system. You need to buy a homelink repeater. Note: liftmaster and chaimberlain are the same, so if you see a reference to one of those names when searching for the repeater, dont worry, it'll work. As far as the second remote, check batteries. Then try programing again, using yellow button on the opener. Lastly, you can reset the programming and start over if all else fails. Hold down yellow button until light on button turns off. Good luck.
Nov 02, 2014 | Craftsman AssureLink Garage Door Opener...
How doI program my Universal Garage door opener on my new 2014 GMC Sierra if I don't have the original hand held unit
contact the opener manufactures/ distributors and get the operating frequency of the receiver unit . You may need the services of a radio technician to adjust the sender ( remote) to that frequency
Aug 30, 2014 | 2014 GMC Sierra 1500
Setting garage door opener
Most openers are programmed the same. You normally program the house garage opener to accept the new remote. Your garage opener will have a button to press to add in a new remote. Normally you press this and then press the remote in the car and hold until your lights on your opener flash or the garage door closes. (check your manual on your garage door opener)
Mar 27, 2009 | 2005 Chevrolet TrailBlazer
Building Materials Logo
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
