Sansui qrx5500 blue fuse
I have a vintage Sansui qrx5500, everything lights up, the meters show that the preamp is processing a signal but there is no sound, not even through headphones
The problem is something to do with the power amp board. You need to determine if it is going power to it, from the power supply section. If it is it would indicate the main power amp has gone. Does it have an IC power amp? If it does then it's gone! Otherwise I am puzzzelled why both channels are down on a device with two seperate transistors stages.
Jan 13, 2013 | Audio Players & Recorders
Repais tv
Sounds like a shorted picture tube. Or it could be a blue drive problem. Hard to say. Thanks for using fixya.
Mar 03, 2010 | Sansui 27" TV
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Aug 28, 2009 | Televison & Video
Blows fuse when turned on
this is a normal behavior if one of the power supply transistors have blown. take the unit to an enlectronics repair. they can either change the transistors affected (usually more than one) or replace the power supply board.
May 29, 2009 | Sansui DTV3200 32" TV
Sansui 3618 tv
that seems to be a 3.15amp fuse. if it blolws then there is a short circuit
Mar 03, 2008 | Televison & Video
Unlock childlock sansui sv-t21pa2s
hi
how to open child lock for this sansui tv
Feb 29, 2008 | Sansui DTV2760 27" TV
Fuse size
I have one of these for parts, fuses look ok, but doesn't power on..do you know where your fuse is on the board?jerrye@rock.com
Jan 03, 2008 | Audio Players & Recorders
No picture
hi, the problem is in the vertical ossilation.. let me know
Dec 18, 2007 | Sansui DTV2760 27" TV
13 people viewed this question
 Grubhead
Grubhead
