Question about Life Fitness 91Ti Treadmill
Lifefitness treadmill belt sticks even though wax bag is full
I have a lifefitness 91ti treadmill, the wax bag is full and the belt sticks when my clients use it. What is going on?
  • Life Fitness Master
  • 918 Answers
It may not be sticking, but instead slipping on the front roller. You can resolve this by simply tightening the running belt. This adjustment will be done by using the rear roller.
Posted on Aug 26, 2014
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Treadmill 91ti lifefitness is making high pitch noise as belt starts. Is anything wrong.? Should I use the the treadmill with this nose.
No do not use, until YOU LUBE. This happen because you must do it every 5 hours aprox of use, The machine protect itself the electronic system and shut down.Maybe the deck belt is worn.
2) LUBE the rollers bearing very i
3) test the drive belt, and test too the bearint of main motor and fix it.
God bless you
Posted on Nov 19, 2012
Belt keeps slipping on treadmill
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension a treadmill belt when it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures for how to tension a treadmill running belt.
  1. Adjust for no slippage of the treadmill walking belt on the front roller (Often referred to as the "Stomp Test")
    1. This procedure works well for a previously installed belt that is now slipping.
    2. Underside of belt should be free of any glazing/wax buildup.
    3. Rollers must also be free of wax buildup.
    4. Be sure belt tracking/centering is correct before proceeding.
    5. The most popular speed for this adjustment is 2mph to 3mph.
    6. Try to slow the belt by applying pressure with your foot against the belt movement while grasping the handrails. If the running belt slow, slips or stops (and the front roller does not) adjust BOTH adjustment bolts 1/4 turn clockwise. Test again and repeat adjustment if necessary.
  2. This procedure requires two belt gauges or calipers
    1. This procedure works well when installing a new belt.
    2. This procedure requires you to stretch the belt. Depending on the manufacturer*, this varies between .4 and .6 percent. A dial on the gauge or caliper will indicate the amount of stretch. *Consult the owner/service manual for proper tension.
    3. If you are working on a previously tensioned belt you will need to release the tension before attaching the gauges or calipers.
  3. Gauges or Calipers unavailable
    1. Release the tension on the belt.
    2. Using a yard stick or tape measure, place two marks on the left and right edges of the belt and deck 36 inches apart (or 50 inches if you prefer).
    3. Adjust the left and right tensioning bolts until both sides measure 36 3/16 inches (or 50 1/4). This is equal to .5% of stretch.
    4. Test for proper tracking and tension, adjust if necessary.
How to Tension Treadmill Walking Belt that Slips
Apr 01, 2014 | Life Fitness 91Ti Treadmill
Lifefitness treadmill belt sticks even though wax bag is fulll
alot of times you have to remove the wax spray nozel and clean as the wax hardens over it
Wax bag change
you need to add wax to treadmill belt lubrication system
Oct 26, 2013 | Life Fitness 95te Commercial Club...
Treadmill says fill with wax
Diagnostics is entered by holding the 'PAUSE' key when power is applied or by holding the
'PAUSE' key and pressing the 'CLEAR' key twice from any state.
The unit will take approx. 3 to 4 seconds to enter Diagnostics.
On entry to this state, the message:
USE ARROW KEY TO SCROLL THROUGH LIST till show on ddisplay the option "MAINTENANCE"
USE ARROW KEY TO SCROLL THROUGH LIST when display show the message "replace wax bag" press enter
the display show "repair logged" and exit press the key "clear"
Feb 05, 2013 | Life Fitness 91Ti Treadmill
Treadmiill keeps saying waxer needs filled after filling it
please see the cause and remedy and fix it. Please read carefully your section of troubleshooting instr. manual or download
Inspect spray pattern between 8" (200mm) and
16" (400mm).
If not, verify wax nozzle is clean, hoses are not
kinked, wax bag is not empty, or wax is
contaminated.
http://www.sportsmith.net/images/product_support/lifefitness/Treadmills/TR9100/9100 Treadmill Manuals/Service/m05100k
God bless you
Nov 29, 2012 | Treadmill Doctor LifeFitness 9100...
God bless you
Nov 19, 2012 | Life Fitness 95Ti Treadmill 95 Ti
How do i reset the waxer on a 9100 lifefitness treadmill?
Press these buttons:
101–ENTER–
HILL–RANDOM–
FIT TEST.
Program lights come on. Display will scroll toWAX DELAY OFF.
Press speed "UP" or "DOWN"
to toggle to
WAX DELAY ON or OFF.
May 13, 2010 | Treadmill Doctor LifeFitness 9100...
Treadmill get stop with a jrk whn power gets a cut..
Sounds like the wax lubrication has finally boiled off the belt the easiest way eliminate this problem is to rewax the deck. You may purchase this @ http://www.gympart.com/ or call them 1-800-496-7278 I would recommend what is call WAX BLAST they come in 3oz or 6oz bottles.
Now the fun part to apply this product you must first get the treadmill and walk on it for about 5min to heat up the deck, then stop the unit with your product go to upper third of the belt lift edge of the belt stick the nozzle between the belt and deck squeeze the bottle approx. amount 1 tbs of wax to the center then get back on the treadmill and walk for 10 min this is to heat up the wax so that belt will act like a wick to absorb wax! This should be done every 3 months or so. Their a catch if this does fix the problem you may be investing in a new belt and possible and new deck. Hope this take of it!!
Feb 02, 2010 | Precor 9.21 Treadmill
We have changing the wax bag and it'snot operate
You have to remove the spray nozzle and heat it with a torch to clear the hardened wax. The nozzle twists off.
Jan 15, 2010 | Life Fitness 91Ti Treadmill
Life Fitness 91Ti Treadmill  Logo
118 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
