Question about LG 42LC2D 42 in. LCD HDTV
Avol 42 wont channel scan
When it turn ,ask for channel auto scan, but doent pick up any channel, hook up to dish box
4 Suggested Answers
SOURCE: Cnannel scan detects no channels
Kingscott,
Make sure the cable connection from the dish to the tv is
connected to the antenna/cable input and not the digital
input. Turn on the satellite receiver then auto program the
set with the receiver still on. If this fails to lock in channel
3 your suspicion regarding a faulty tuner could be correct.
A good way to check the tuner operation would be to hook
up another product such as a VCR with the rear switch set
for channel 3 and see if you can receive a picture from this
device. If it works the tuner is OK.
You can bypass the tuner by connecting an S-Video cable
and (or) a set of A/V (yellow,red & white) cables from the
output of the satellite receiver to the video 1 input on the tv.
You'll then have to switch the tv source mode to video 1.
Hope this of some help,
Caseybee
Posted on Mar 20, 2008
  • 362 Answers
SOURCE: LG 32LB9D is not picking up all channels
You must have the tuning band set to Cable not Air. From the video menu choose cable, you may have to options for cable, try both.
Let me know if this helps.
lone99star
Posted on Jan 09, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: my tv wont pick up any channels
have you switch the broadcast to Air from Cable using the remote go to this and also let it scan for channels auto...hopefully this will do the trick
Posted on Jul 26, 2010
Customersupport
The first question is, how do you connect the Dish Sat to the TV?
If by coax cable, then let the TV scan and find the output channel of the receiver (ie. Channel 3). If you are using HDMI or other Input Input ports, you should be able to skip the auto scan and just choose the corrent input port. If all else fails, hook an antenna or coax cable to the TV and allow Auto Scan to complete its processes. You should then be back normal and can then select the input port.
Nov 22, 2013 | Element Televison & Video
My Vizio LCD HDTV isn't pickup up all of the cable channels, but my other older TVs are?
Did you retry a working TV again on the same input, as it looks like a case of loose contacts in the RC Jack, cable or connectors or some strands of the cable touching the ground. Then check whether your Vizio TV supports the system/format of the cable. If your cable is licensed to be used only with the other TVs, like sensing the identity of the PC used, it could also be a problem
Aug 22, 2012 | Televison & Video
I have a RCA LCD TV model no. RLC3708A and when hooking it up when I took it out of box, I got to
I think you are confusing the channel on the tv and the channel of the cable company that is not something that you can pick up with the scan tv, scan tv is good for picking up local channel meaning air channel that we get with a antenna only not the cable chanel
Jun 24, 2012 | RCA Televison & Video
I have an AVol TV and need the Dish Network remote control codes
Hi, my name is Cheri Torres and I am with DISH Network Customer Service. I tried looking up all of our possible remote codes and I was not able to locate any codes for an AVol TV. Instead of using codes to address your DISH remote to your TV you will need to try a power scan. A power scan will normally find the code that works best for your TV for you. I will list here for you the instructions for performing a power scan. I hope you find this information useful. :)
Instructions for performing a power scan
  1. Turn the Television On.
  2. Press and hold the TV mode button until all mode lights light up red.
  3. Press and release the big red power button once.
  4. Press and release the channel Up Arrow on the remote until the television turns off.
  5. After the television turns off, press and release the pound(#) button once.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Sep 09, 2011 | DISH Network IR Remote Control
How do you scan the channels on the PDH42L40? I need to go to a certain channel on the TV to get my Dish Network to work. It is not hooked directly into a box, it is on a secondary receiver. Please...
hello and good day to you!!!!
if you wish to scan your TV to go for a certain channels..
you need to reset auto scan on your TV...
this are the procedure on how to reset auto scan...
  1. Get your remote control..
  2. press the menu button on your remote
  3. go to the settings..
  4. try to find the auto search.
  5. after you find the auto search press enter to scan the channels.
Note: Please complete the 100% scan for better results..
Jul 12, 2011 | Televison & Video
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
Hi, my Phillips was hooked up and working fine directly to the DISH receiver using the HDMI 1. I moved and had to put the DISH receiver in another room and ran a coax cable to where the TV is now using...
Hey murphypat321,
Sounds like the TV may need to be on ch 73 cable rather than 60 air. Try switching the TV to 73, if it goes to 69 then put back on 60, if goes to 73 good. Once you have that set go to your TV1 and bring up the menu. Go to System Setup (6) -> Installation (1) -> Modulator Setup (5) and change the TV2 setup to either cable if on 73 or air if on 60 and the picture should come in if everything's hooked up.
Hope that helped! You can email me at thomas.faust@dishnetwork.com if the problem persists.
Tommy Faust
DISH Network
Mar 09, 2011 | Philips 42PFL5332D 42 in. LCD Television
I am in Afghanistan, Kabul Area. I have an ALT2260M Avol tv. when I use the autotune for channels, All I get are the local channels. We are hooked into the AFN Network cable and it does not pull those...
try going into the autotune then select us then cable select the auto acan then change from auto to irc or std then scan should do the trick.
Dec 06, 2010 | Televison & Video
My tv wont pick up any channels i have a 42 inch lg tv and its connected to the household antenna but wont pick up any channels i have tried other ariels and still have the same problem?
Jul 26, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Kingscott,
Caseybee
Mar 13, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
35 people viewed this question
Computer Repairing
Computer Repairing
