Question about Refrigerators
Hi I have a daewoo fridge with water and ice model FRN-Y22D2W and am having problem with water dispencer got to shove plastic dispencer hard for water to come out this never happend before can you help thanks
2 Suggested Answers
SOURCE: ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Posted on Feb 24, 2010
I have a Daewoo FRN U20DA type american fridge freezer. The Ice maker has sropped working. There is no water getting into it. There is water getting through to the water dispenser in the front door. the...
The water filter should be changed every six months, not two years.
The water lines may still be frozen even though you turned the unit off, but most likely you are not getting water flow due to a clogged filter. Change it.
Feb 26, 2011 | Daewoo Freezers
The freezer compartment of my daewoo FRN-U20DA is not cold enough and the ice is melting. The fan does not come on and there is no fault indicated on the display panel.
when the fan is not working. you cannot expect an ice cause the fan is to drive the cold to become an ice and to maintain the coldness.
Jun 23, 2010 | Freezers
No wate coming out the dispeser
The plastic water resivoir in the fridge compartment is frozen. Need to locate the resivoir which is at the bottom of the fridge and by using a hairdrier, warm the plastic resivoir for about 6 minuites. Suggest you turn the fridge off while doing this. retry and dispence water.
Jun 06, 2010 | Samsung 26.1 Cu. Ft. Side-by-Side...
Ice cube maker on daewoo american fridge freezer
Jul 19, 2009 | Daewoo Refrigerators
How to make ice cubes ?
Just fill pure water in the ice tray and allow it to cool for an hour your ice cubes will be ready. DO NOT OPEN IN THE MIDDLE TO SEE THE ICE FORMATION!
Jul 06, 2009 | Refrigerators
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Whirlpool Refrigerator Model # ET21PKXGN00
HI thanks for your question. the problem is with the drain tube, from freezer to the drain pan ,located at the back, by the compressor. to repair. turn fridge off, for 24 hrs. pull fridge away from the wall. clean all the coils. locate the drain tube, by the drain tray. get a small plastic hose, shove the plastic hose up the drain tube. and blow, to dislodge any debris clean the tube thanks the appliance doc.
Oct 15, 2008 | Whirlpool Refrigerators
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
