Question about Canon Cameras
Card write protect switch to lock of canon 600d camera
Card writer protect is swicth to lock how to open? why is it lock?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Oct 07, 2014
  • 919 Answers
SOURCE: olympus 840, writers protect
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup- Select Format - You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Posted on Mar 16, 2009
t00nz
  • 4738 Answers
SOURCE: Camera says SD Card is locked but card is open;
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Posted on Jul 11, 2009
t00nz
  • 4738 Answers
SOURCE: Canon a590 Card (not really) Locked
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Posted on Jul 23, 2009
  • 10 Answers
SOURCE: card write protected
Check if the card is truly write protected (check the little slider on the SD card). Its possible it slid into lock position accidentally
Posted on Nov 25, 2009
Testimonial: "very helpful, i overcome the wrtie protected problem. thanks"
  • 11967 Answers
SOURCE: Canon Rebel eos is locked on Card protected. How
Does the card contain pictures shot on another camera? If so, that could be your problem. Download those and format the card in your camera.
Posted on Jan 16, 2010
CARD write selection switch is set to lock...how to unlock it??
Feb 26, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Unlock memory cardcard write prot
Feb 08, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Card write protected
Jan 31, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Jan 19, 2014 | Canon EOS 600D Rebel T3i Digital Camera
L can not copy anything to SD card it says remove writer protection
Take your memory card out of the camera and switch the position of the "lock" tab. One position is for "locked" (i.e., "Write Protected") and the other position will allow the card to be written to (unlocked). Some cameras have image protection built into the on-camera software and you may need to configure this there.
Nov 08, 2013 | SanDisk 2GB microSD Memory Card
Card cannot create folder
Make sure that the card is not "write protected" or "locked". This is determined by the position of the tab on the long-edge on the left side of the card as shown below:
Make sure the tab is positioned as shown in the image - not back in the direction of the "LOCK" arrow.
If it still will not work, try formating in a card reader attached to your computer. This will ERASE all content on the card. Then reinsert into camera and reformat once more. You should be ready to take pictures again.
May 29, 2013 | Canon EOS 600D Rebel T3i Digital Camera
My canon eos 600d won't take pics anymore is there a lock or something that could be released
Are you getting an error message or any other indication from the camera? Have you checked the memory card to see whether it's write-protected? What exposure mode(s)? What shutter release mode(s)?
Mar 19, 2013 | Canon EOS 600D Rebel T3i Digital Camera
Card write protect switch is set to lock
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 10, 2012 | Canon EOS 600D Rebel T3i Digital Camera
Can't open my canon camera, says Card Locked.
SD cards have a small switch on one side that can get slid to a "locked" position, which will prevent the card from being erased. Just slide it back to the other position. It may have a padlock symbol on it right next to the switch.
Feb 11, 2011 | Canon PowerShot SD1100 IS Digital Camera
PNY Optima 2gb SD Card Write-Protection Problem
Ur right it has a physical problem. Try to format it using dos and then give it a try.
Thankyou
Jul 31, 2009 | Electronics - Others
Cameras Logo
83 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
