Question about HP L1706 17" LCD Monitor
HP L1706 monitor
I have a thin vertical line running from top to bottom on my monitor.  It fades in and out at times and seems to flicker, but it is staying there. Appeared out of nowhere.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
Re: HP L1706 monitor
Your monitor is getting ready to kick the bucket.
Posted on Nov 01, 2007
0 characters
3 Points
Thin black horizontal lines across bottom of screen
Hi there.
I suggest you see my tip on how to fix the lines on your monitor. The fix for horizontal lines is the same for vertical lines. You can read my tip here:
Jul 20, 2011 | HP w17e Monitor
HP L1706 vertical lines
Check that the connection from the graphics card to the monitor is good and that the graphics card itself is in working condition by testing the computer on another monitor.
If the problem persists, the issue is with the monitor and possibly a connection to the display internally which will require a competent electrician to check out
Jan 08, 2011 | HP L1706 17" LCD Monitor
How do i open my hpl706 monitor. i need to replace a capacitor
Reomove the base and all the screws in the back, use thin flat blade screw driver to crack open at the bottom edge of the monitor and then work your way around, you should ahve the monitor face down on a flat soft surface.
See example here:
Capacitors kit: he can make you a set of caps for you.
Sep 02, 2010 | HP L1706 17" LCD Monitor
Green Line
Well, there nothing you can do.... You've got a busted panel.
Aug 06, 2008 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Thin yellow line on the right of the LCD Screen
all those sounding intelligent and saying that replacing lcd hardware will fix the problem probably didnt have the problem themseleves . i had exactly same problem with samsung syncmaster 2043swx monitor . i just restarted and booted into safe mode ( by pressing F8 key at startup ) tried changing reolution in display settings . rebooted in normal mode and asll lines are gone and never appear again . i am uisng windows Vista . so i think it is probably a driver glitch something .
Jul 07, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
If it's a straight line from top to bottom panel could be defective.Not much you can do as cost of panel will compare with a new monitor.
Jun 08, 2008 | Gateway FPD1975W 19" LCD Monitor
Flickers and Lines
you have the vertical circuit "closed" you have to repair it checking
transistors and capacitors . if you can  it this work may be at low cost - few dollars
Mar 21, 2008 | Dell UltraSharp 2000FP 20.1" Flat Panel...
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
HP L1706 17" LCD Monitor Logo
227 people viewed this question
Top HP Computer Monitors Experts
Ivan Bernal
Level 1 Expert
Tony Isted
Level 1 Expert
Elizabeth Mescall
Level 1 Expert
Are you a HP Computer Monitor Expert? Answer questions, earn points and help others
