Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
Burning smell while running, smells like burning plastic
  • 6 Answers
SOURCE: LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Posted on Dec 28, 2008
SOURCE: MAGNAVOX TV BURNING SMELL TV WENT POP AND WENT OFF
Well that pop had something to do with the power components inside the TV frying. I would have to say there is nothing you can do to repair it as its dangerous to work on such things.
I wouln't waste my time bringing it to a repair shop they will probably tell you to just buy a new one.
Posted on Jan 05, 2009
Sea Breeze
  • 4655 Answers
SOURCE: smell like burning plastic in fridge
Your refigerator is on recall or is a health and safety issue. I will bee right back. Sea Breeze
Posted on Nov 19, 2009
  • 3 Answers
SOURCE: LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Posted on Dec 31, 2009
Andriod Man
  • 271 Answers
SOURCE: Dryer smelled like burning plastic. It then
remove the lint screen and with a flashlight check if you see something at the blower fan. if you dont chances are the motor went out. do the dryer come on?, do you see any light on?. check you breaker and make sure you have power in the outlet. good luck to you.
Posted on Feb 07, 2011
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
When dryer running there is a burning smell
Clean the lint trap and make sure you have good fan operation. Check your outside vent for good air flow. Could your burning smell be electrical wiring? Does it smell like plastic burning or lint burning?
These are things one needs to know in order to locate the trouble.
Feb 03, 2016 | Whirlpool GEW9250 Electric Dryer
Burning smell
If it smells like burning a burning plastic/ceramic then your brakes are locking up and burning. Next time it does it, see if the smell is coming from the rear tire. if so, its time for a brake job
Nov 11, 2013 | Acura Cars & Trucks
Plastic smell
Overheat catalytic converter during your drive??????
Sep 10, 2017 | Fiat Cars & Trucks
Engine died burning smell
If the smell is like burning oil or really hot coolant. you may have killed the motor. If it smells like burning plastic ,look for shorthing wires around the exhaust manifold battery, alternator or place that a wire could be burnt. If a rubber smell check for belt failure.
Jan 19, 2013 | Toyota 4Runner Cars & Trucks
Burning plastic smell from under hood
You will need to check where the liquid is coming from, It may be anything from Air Con, Fuel, Transmission Fluid etc..
The fact you smell burning plastic could be 3 things..
1, Brake pads could smell and burn down if they are on too tight (Had this problem with a trailer). Hence when you apply the brakes it could be squirting brake fluid out due to too much pressure.
- Check brake fluid
2, If the smell and liquid is inside the car (front pass side) it could be the air ducts. Under the dashboard you have air ducts etc for the fans and in car cooling (brother had issue with this)
3, Whatever the fluid is, it could possibly drip onto something hot, unusual for liquid to smell like plastic though, Auto transmission oil smells like fish.
Best bet would be the brakes. Next time you smell it just smell in the wheel mag and see if you can smell it, check the engine fluids often and dont use A/C (Air Con) as that does drip fluid (normal). If it is the brakes smelling you will need to have the lines bled out, tyre places may be able to do this, and possibly new brake pads
Good luck
Oct 20, 2012 | 2007 Suzuki XL-7
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Dryer stoped running
Your drive belt may have broken if it smelled like rubber burning. If that is the case then your motor bearing are worn out or something has been lodged between your dryer drum and the dryer housing. If the smell was the odor of burning plastic, then your motor is probably burned up.
Feb 24, 2009 | Maytag Dryers
Gateway laptop burning plastic smell
Hiya .. can you hear your fan running... would suggest your laptop not cooling properly... need to get it looked at or you'll kiss goodbye to your processor!
Regards Faggly
Mar 26, 2008 | Computers & Internet
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
21 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
