Question about HP Officejet Pro L7580 All-In-One InkJet Printer
I need a photo of the back insides. the back feeder is in pieces.
I can get you a photo of the inside of this printer.. what specifically is in pieces?
Posted on Jan 23, 2010
    Guru:
  • 224 Answers
You printer would be oow so call call up hp at 1800-474-
6836 and if ur printer shows
out of warranty in hp's
records dont worry ask the
customer representative to go
ahead and tell you the upgrade
options and go in for either
the photosmart 7280,photosmart
6380 or the photosmart 8180.
You will get it at a 50%
discounted rate.Its called a
refurbished printer but the
actual scenario is that if
wallmart purchases 100
printers and realises they
needed 99 they send one back
to hp and then our factory
test it before sending it out
to the customer but it has
never been used before.
trust me this is the best
option.I work for HP.
call in and hope you get me on
the call.If the printer is in
warranty then hp will try a
couple of troubleshooting
steps and if they dont work
then they will replace the
printer free of cost.if it is still in warranty hp will replace the broken part
Posted on Jun 16, 2009
How do I get a stuck piece of paper out of top feeder?
the top feeder is supposed to be able to open giving you complete access to the workings of the top feeder
and also when removing the paper work gently, and check to see if you removed the complete page and that a piece hasn`t torn off and is still stuck inside
Mar 04, 2014 | HP Officejet Pro 8600
Document feeder error message
did u guys ever use maginzes to scan documents with they will get jamed in there i would open it up cheak feeders closly ok thx nick
Feb 09, 2008 | Office Equipment & Supplies
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Paper wont feed
Try this trick, remove all papers in the feeder, examine the inside of the feeder, at the bottom you will notice a white plastic which is part of the bottom roller, now cut out a piece of photo paper (glossy & not too thick) just enough to cover that white part, use a double adhesive tape to hold it to position, a long tweezers or something like it will come in handy to help you position the piece of photo paper, make sure you lay it flat and smooth. Good luck!
Jan 11, 2010 | Epson Stylus C86 InkJet Printer
Where can I take my Stylus Photo RX500 for repair? The paper feeder eats the paper on one side.
you probably have a tiny tiny piece jammed in the roller on that side. sometimes it gets stuck inside and you cant see it. take it apart and use tweezers to pull it out. usually its a small piece similiar to the leftover junk you get when you rip out a page from a ring notebook.
Sep 03, 2009 | Office Equipment & Supplies
Spring from printer
it goes behind the paper feeder at the bottom you have to take out the piece of plastic that has the light grey slider on it which is fixed in place at the top you'll have to be quite firm when trying to prize the round lugs out of there holes located at either end at the top of the dark grey plastic paper feeder guide the one with lots of thin vertical lines on it top left. once out look at the back and you will see a circle with the same diameter as the spring then look inside near the bottom of the rear of the paper feeder and you will see something similar. its very tricky trying to locate the spring back into position i placed the spring into the hole on the piece i removed and then squashed it down using a metal ruler and then slid it back into position. you will know if it went back properly by putting your hand inside and pushing back against the feeder with your finger nails it should spring back and forth.
Aug 31, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
ADF Jam
It sounds like the grabbing wheels in the document feeder are losing their grip. You can take alcohol to rub down and clean the rubber tires in the document feeder. There is a possibility that a very small piece of paper is jammed in the feeder as well, which can cause the paper to jam and make a weird noise. Please let me know if this resolves your issue. Thank you.
Mar 27, 2009 | Dell Photo 964 All-In-One InkJet Printer
Jam in the document feeder
get rid of that hp piece o crust. demand your money back.
Mar 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
55 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
