I need Data Plate info for a Intertherm Model 30A-036K home A/C outside unit. All info except the model no. has been bleached out by the Sun. I need the compressor Amps (RLA and LRA) and the Amps, Hp, and RPM for the Condenser Fan Motor.
5 Suggested Answers
cactus bob
  • 267 Answers
SOURCE: what is the cooling btu on my BDP company division of carrier
is this unit real old ? it does not come up in my book . the btu is 30000 that is the same as 2.5 ton it may be 6,7 or 8 seer i dont think its a 10 seer because the 10 seer units are listed and yours is not . if this sounds wrong please look up the mod # again and post the ser # too ......... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 15, 2009
  • 588 Answers
SOURCE: on the unit model/serial# tag there is three
Compressor LRA ( locked rotor amps)meaning that if you hold that rotor and do not allow it to turn, it would draw that many amps.
Compressor RLA (rated load amps) meaning the amps the compressor will draw at a certain outdoor temperature usssually 95°.
Fan FLA (Full load amps) meaning that's the maximum amps the motor will run at continuosly.
Posted on Feb 10, 2010
muntejaya
  • 10421 Answers
SOURCE: My church has a roof
RLA ( rate load amps/current) is the rate of unit ( usually about 65% against Max. load current < FLA/FLC>)
LRA ( Locked rotor amp/current)
Seems your AC use Y or Delta starter, so at start the current draws will between : 3X ( 26.4 to (26.4(1 +35%). And After start up the current draws will drop to 26.4 to 26.4(1+ 35%) in normal operation.
Remember, that the current draws also depending to the condition of your ac.
Posted on Nov 03, 2010
heinzhvac
  • 229 Answers
SOURCE: I am removing a 3 ton condenser and replacing with
Yes you will have problems you can go up a 1/2 half ton on the coil but not with the condenser don't do it you will regret it even with an expansion valve.
Posted on Jun 21, 2011
Outside AC unit not coming on but indoor fan is working, replaced the start/run 5/50 capacitor but still didnt fix it, let it set allday while came home tried it and it came on and worked great, but the...
Sounds like you are on the right track. The symptom of the contactor not pulling is your clue to the solution. When you turn the thermostat down lower than the room temperature and the thermostat calls for cooling, the outside unit should start immediately. There are a few exceptions to this but generally this is correct. So if you turn the system to cool and the thermostat is calling for cool then the contactor should pull in immediately. If it does not then check for 24 volts to the contactor. If you have 24 volts to the contactor then the contactor is the problem. If you do not have 24 volt power to the contactor coil then you will have to find where the break in voltage to the contactor is happening.
There are many reasons why you may not be getting 24 volts to the contactor, so check what i stated above before you go any further. Repost if this is the solution or you need further assistance.
Important tip....the yellow wire from the thermostat carries the 24 volt power from the thermostat to the contactor.
Sep 08, 2011 | Intertherm P3RA-036K Air Conditioner
What is the tonnage on an Intertherm S3RC-0336K.
Hello, the tonnage on this unit is a 3 ton unit. Your model number tells you. The 036 is the tonnage. There are 12,000 btu's per ton, so 36 divided by 3 =12 or in this case 12,000 btu's.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Jun 05, 2011 | Intertherm P3RC-036K Air Conditioner
WHAT IS THE WARRANTY ON THE P3RA-036K? I'VE BEEN IN MY HOME FOR 4 YEARS AND 7 MONTHS. I BOUGHT MY HOME NEW BUT IT HAD BEEN SITTING FOR ABOUT A YEAR BEFORE I BOUGHT IT. EVAPORATOR COIL WAS REPLACED ON...
it should be. but you would need to check with intertherm they make that call. most unit come with a minimum of 5 year parts however who ever put it in and the dealer make final call so its to gray to say sorry if you explain your concern to intertherm they may give you an extended warranty it happens sometimes if customer feels cheated please give me a rating and vote
Sep 21, 2010 | Intertherm P3RA-036K Air Conditioner
I have a Intertherm outside AC & it was put in when the mobile home was built(1982) and I do not know what it is, I only can find the name of the manufacture, where would I find the model, & other...
mobile homes have split units, I would check the unit inside to see if it has any information. I would check all breakers inside and out, and thermostat. Hopefully it will be something simple. Good Luck Tim
Aug 09, 2010 | Intertherm P3RA-036K Air Conditioner
Where can I find a wiring diagram for a interrherm
Hi; Call Your local mobile home supply house and they can tell You how to or fax You the Info. Also the equipment will have the wiring diagrams glued to the inside covers of the outdoor unit as well the indoor unit cover. Power down the indoor unit before removing the indoor electrical cover for the schematics. Do You not have a user or install manual. Call your local mobile home supply house they can often help.. Be care full You get more bees with honey so be very nize...alpharome416
Feb 19, 2010 | Intertherm P3RA-036K Air Conditioner
Need a product manual for intertherm model p5rd-036k
http://www.nordyne.com/Literature/455a.pdf
and here ya go. check this web site for your manual.
Hope this is what you want.
Dec 26, 2009 | Intertherm P3RA-036K Air Conditioner
WONT COOL OUTSIDE UNIT DOES NOT COME ON FAN BLOWS INSIDE
if the fan outside is turning on and inside fan is blowing too, then you have a compressor problem. could be a capacitor gone bad (or needing a hard start kit) to the entire compressor failure
May 03, 2009 | Intertherm P3RA-036K Air Conditioner
Size
Greetings jdreisbaugh,
The tonnage is usually found on the name plate on the condensing unit outside. 12000 btu = 1 ton, 24000 = 2 ton and so forth. In your case the unit is 36000 btu, therefore a 3 ton.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jul 24, 2008 | Intertherm P3RA-036K Air Conditioner
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
