Question about Baxter Ovens
Baxter pc151m38 Humidity says "lo" all the time
I have a Baxter ov310e oven a customer asked me to check on. Of course while there had no issues at all. She said when they were using it earlier in the day the temp diplay started flashing. It was near...
SAFETY ALARM (STANDARD FEATURE, NO PARAMETER SETUP REQUIRED)If the temperature at the probe is in range of 570 to 600°F for 10 seconds, the unit will do the following:1. Shut off all features.2. Sound an alarm.3. Flash the OVEN TEMP display (actual temperature is displayed).4. Display the letters 'SHdn' in the BAKE TIMER display.Disconnect the electrical power to the oven and follow lockout / tagout procedures.There may be multiple circuits. Be sure all circuits are disconnected.
Troubleshooting - Baxter OV310E Operation Manual [Page 29] https://www.manualslib.com/manual/1248539/Baxter-Ov310e.html?_e_pi_=7%2CPAGE_ID10%2C4341941345 -- shared by UC Mini
Jan 19, 2018 | Baxter Ovens
I need wiring digram for baxter oven ov300e
Request the wiring diagram directly from Baxter.
Feb 23, 2017 | Baxter Ovens
I need owners manual for a baxter model pb200 m90
YOU CAN PROBABLY FIND ON ON LINE. TYPE IN BAXTEDR MODEL PB200M90 MANUAL OR MANUAL FOR BAXTER MODEL PB200N90
Jan 28, 2015 | Baxter Ovens
Pilot light either won't light or won't stay on
Check for a draft first that is randomly blowing this thing out and second check the gas regulator.
Mar 12, 2014 | Baxter Ovens
Baxter oven not working
Hobart owns Baxter. You'll have to call Hobart.
Feb 14, 2014 | Baxter Ovens
Wich is the power supply 120v, 208 1 phasse or 208v 3 phase.
Most Baxter BXA ovens have separate power supplies, usually 120v for the controls and lights, a 120v output on a circuit breaker for the roof fan, and a 208VAC 3 phase supply for your convection motor. Older Baxter ovens may have a 3 phase service disconnect inside the electrical/burner compartment, if I recall correctly the BXA models do not and the only way to shut it off is via the 3 pole breaker at the service panel.
Feb 04, 2011 | Baxter BXA2G Stainless Steel Gas Single...
Need to set clock for daylight time on baxter oven ov300e
With the oven on hold the time up or down arrows until the time begins to change.
Nov 07, 2010 | Baxter OV300E Stainless Steel Electric...
Ovens Logo
24 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
ray gallant
Are you a Baxter Oven Expert? Answer questions, earn points and help others
