Question about Xerox Office Equipment & Supplies
How replace the Xerox WorkCentre 7132 7232 7242 2nd Btr Unit CRU 008R13026?
SOURCE: xerox PE16 cru fuse problem
mr jaiku thank you
Posted on Aug 16, 2008
SOURCE: Is there a Mac workaround driver for the Xerox WorkCentre PE16
Recently I had to configure a 17" Aluminum PowerBook and a Xerox Workcentre PE 16. That multifunction laser monochrome printer is not supported by MacOS X, but I tried all the same.... and no glue for that, until I went on the Samsung webpage and noticed their SCX-4216F printer. This machine is the same as the PE 16.
So I downloaded the lastest drivers from Samsung's download centre (drivers for Tiger too), installed the drivers on the PowerBook (running 10.3.4), connected the printer and when I selected the printer ... tada! It automatically selected the Samsung driver, so I clicked on OK and started printing. Everything was OK!
But it doesn't end here: even the Lexmark X215 MPF has the same chassis as the Xerox and Samsung. Yet, on Lexmark's website there are no Mac OS X drivers, but Samsung's drivers work just the same. I hope this hint will help others...
Posted on Jan 26, 2009
SOURCE: Xerox workcentre 265 waste toner full msg
Clean the sensor where the waste toner bottle goes in and just turn the copier off for a couple of minutes then turn it back on. The system needs to reset.
Posted on Oct 20, 2009
  • 24 Answers
SOURCE: I have a Xerox WorkCentre 5638. How do I save
You cannot save the e-mail addresses on this unit except by creating a .CSV file and uploading it via CWIS under Properties>Services>E-Mail>Public Address Book. A link to the instructions is below:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=195,E=0000000001733361539,K=3118,Sxi=11,Case=obj(10395)
Posted on Oct 25, 2009
  • 111 Answers
SOURCE: Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Posted on Apr 01, 2010
009-349 key to reset
There's no reset for that error, the error indicates that the 1st BTR did not reach the retract position. Try clean the 1st BTR Retract Sensor and look for damage. Also check the gears for breakage.
Jul 28, 2015 | Xerox WorkCentre 7328 Multifunction laser...
Xerox 7345 009 343 error code
Check out the Xerox.com website for more upto date information.
.Good luck.
Oct 20, 2014 | Xerox WorkCenter Office Equipment &...
XEROX PE 16 problem cru fuse error on display what is this
Remove copy cartridge. On left top of cartridge there is a glass fuse. replace it with proper rating. it is meant for cart existence
Jan 29, 2011 | Xerox WorkCentre PE16 All-In-One Laser...
Please i need technical help and be able to speak to a live perosn via phone to help with a xerox workcentre 24 color machine. will pay a fee of course. Does anyone have the XEROX software to tell the...
You have to have a fully configured laptop with several levels of Xerox software.
Once that is accessed though you can change those numbers to max them out for the life of the machine.
Where do you live? Maybe I can find someone to do it for you.
Aug 02, 2010 | Xerox WorkCentre M-24 Color Copier
Display messge cru fuse error
Normally that means the fuser module has failed.
You can order and replace it yourself, I believe they are about $100.
That's what I paid for the last one I replaced.
You can call 1-800-835-6100 and order one.
All you have to do is remove the 4 screws that hold the back cover on, then remove 2 or 4 screws that hold the fuser in. Unplug a couple of plugs and slide in the new fuser. It is really an easy replacement.
Mar 31, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
The door on the left side of the machine keeps reading as being open when it is not.
The tab for the interlock actuator either broke off or the interlock switch itself has come out of position.
Feb 16, 2010 | Xerox WorkCentre M-24 Color Copier
Xerox workcentre m24 code error 009-910 Drum CRU type Mismatch K
it is the problem with the crum on the drum unit by replacing the crum problem can be solved, even you can check with replacung the crum with another drum unit working in the machine.
Aug 19, 2009 | Office Equipment & Supplies
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox xc1020
is it a printer/copier?
yes....do both prints and copies off the glass come out black?
yes...probably a problem in the drum/ CRU area
No- prints OK but copies black lift the lid and watch the exposure lamp...does it light up? does it move? Both of these scenarios would usually bring up a fault code, so I would still be inclined towards the drum unit.Pull the unit out and make sure no paper has sneaked up between the drum and the exposure slot, or even into the drum unit. another cause could be a broken corotron wire (very thin wire close to the drum usually behind a grid (charge grid) If it is a customer replacement drum unit (CRU) the charge grid will be built into the unit and will require the whole thing replacing.......
Dec 27, 2007 | Xerox CopyCentre C20 Black and White...
27 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
