Question about Dell Optiplex 755 Desktop Desktop Computer
Why does my desktop DELL Optiplex 1700L just flash YELLOW and refuse to come on, motherboard light is on
Machine was on for about 5 minutes, shut off and now the yellow flashing light.
  • Dell Master
  • 998 Answers
An Amber (Yellow) blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Posted on May 18, 2014
tom19511
  • 1601 Answers
SOURCE: powerbutton flashing yellow
If the main power button LED is flashing or solid yellow, this could indicate a hardware problem.
Was it running good before?
Are the diagnostic LED lights all green?
Here is what dell says:
If the power light is blinking amber  —
 The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Do you remember what the BSOD said?
Posted on Oct 23, 2007
IB4G2008
  • 3587 Answers
SOURCE: pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Posted on Feb 15, 2008
MDoe
  • 156 Answers
SOURCE: Dell Optiplex GX260 Tower flashing yellow power button
Hi
Power up the Optiplex GX260 and check the QUAD Pack Diagnostics LEDs (located at the back). Compare the LED pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1167139 for more info.
Ideally, to troubleshoot and resolve the issues, try removing all PCI devices, disconnect all external devices/peripherals including keyboard and mouse. You may leave the Monitor connected. Power up the PC and check for successful Power On Self Test (POST). If POST completes (generally fails on "Keyboard not present"), shutdown, connect keyboard and try POST again.
If all goes well, install PCI devices one at a time and test successful POST. This will help identity a failing device.
If issue persists, after removing all devices, remove the CMOS battery for about 90 seconds and try POST again. If same, remove all DIMMs (Memory) and check for beep codes. Compare beep pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1176760.
NB: Ensure to remove power lead and press power button briefly to use up flea power before working in the system.
If the system beeps, it suggests that the CPU and systemboard are "likely" fine. Install one DIMM at a time and test successful POST. If there no beeps then the systemboard and/or CU is/are at fault.
Regards
Mike
Posted on Mar 27, 2008
SOURCE: start button flashes yellow - will not turn on
I have found that if the CMOS battery is removed and the unit unpluged for 5 mins (reseting the unit to default config) It will restart. The battery should not be replaced thus to maintain your date and time settings, it shoud not be unpluged for long periods.
Posted on May 20, 2009
  • 1684 Answers
SOURCE: I powered off my Dell
This model has been having problems with the motherboard that can cause that exact problem, Not powering up, Flashing yellow light or locking up right after booting up. The first thing to check is parts called capacitors on the motherboard. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/dell-optiplex-745-repair/ that has detailed pictures and information about this issue. The pictures are of the tower case Optilpex 745 but the board is the same for your unit. Check it out and see if your board has this issue. If you can solder then you should be able to fix it yourself for less than $15.00 If your board does not have the bad capacitors then the blinking yellow light is a failure in the power supply unit.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Sep 15, 2010
Dell optiplex gx520 flashing yellow light on motherboard
According to the information you gave it seems it can still be the RAM. I've had a few PC's unable to startup due to bad memory.
Either that or the the front panel conectors are wrongly connected. Sometimes they do have a color code, but it's best to reference the manual. Can be the button . . .
If this is no help, I'd like to know more.
Apr 24, 2012 | Dell OptiPlex GX520 PC Desktop
Dell OptiPlex GX620 show orange light and refuse to boot up
  • Turn the machine off and unplug from power.
  • Locate and remove the CMOS battery.
  • Disconnect the hard disk from power
  • Leave it like that for a few minutes and the connect everything.
  • Start the machine now.
Worked for me,hope it does for you.Thank you!
Sep 28, 2011 | Dell OptiPlex GX620 PC Desktop
I powered off my Dell Optiplex 745 as normal one night before bed. The next morning I went to turn it on and it just displayed a yellow flashing light where it normally displays a green light. The fan did...
CCL_Tech
Corporate Computer
www.ccl-la.com
Aug 28, 2010 | Dell OPTIPLEX 745 PC Desktop
The light at the power nod has turned yellow and
buy a new computer, sorry but dell sucks
they are made to work for a certain amount of time not forever i worked at dell and yeah ............. i leave it that
May 08, 2010 | Dell OptiPlex GX620 PC Desktop
Dell? OptiPlex? SX280 blinking yellow what is that
blinking yellow light on the power button of a Dell system is a possible power supply issue. press the eject button on the dvd drive while the power button flashes yellow light. if the disc trays wont come out, you need to replace the power supply. hope it helps. good day.
Jan 07, 2010 | Dell OptiPlex SX280 PC Desktop
Yello power light, dell
1st remove all PCI cards, see if anything changes.  If no change\:
If the power LED is solid AMBER, replace the motherboard
If Flashing AMber, replace the power supply
Sep 08, 2008 | Dell OptiPlex GX260 PC Desktop
An old Dell Optiplex gx260 just won't turn on
Possible failures are:
  1. Powersupply failure
  2. Motherboard failure (Check the capacitors for popped ones)
  3. Front I/O Panel
Sep 01, 2008 | Dell OptiPlex GX260 PC Desktop
Gx260 pc wont start
Have you checked the post lights located in the back of the system by where the keyboard plugs in? There are is a row of 4 lights; either yellow or green. If the systems gets stuck at a particular post location, the lights will tell where. Good luck
Aug 16, 2007 | Dell OptiPlex GX260 PC Desktop
Dell Optiplex 755 Desktop Desktop Computer  Logo
136 people viewed this question
Alun Cox
