Question about Mitsubishi WD-73732 73" Television
WD73732 Mitsubishi TV Problems with color and flickering
I purchased my WD73732 projection TV from Circuit City on May 18, 2007. This weekend on June 13, 2009, the color on the tv started acting up. The best way to describe it was the color was gone but trying to come back in. This causes the screen to flicker constantly almost like the color is trying to restart but won’t. Vague hints of colors also flashing. Behind the flickering the images are still clear (picture not otherwise distorted). If I turn the TV off for a few minutes it comes back on with good crisp color for about 30 minutes and then it goes again.
On the night of the 13th, I unplugged the TV and left it that way overnight. In the morning I turned it back on and enjoyed a good picture for most of the day. At about 3 PM on the 14th the problem came back so it appears to be a time/heat sensitive problem. This is my second Mitsubishi projection TV (my 60 inch still going strong with never a days problem after 10 years) and I am devastated to be encountering this problem after only 2 years (I already had to replace the lamp about 2 months ago).
  • 3130 Answers
SOURCE: problem with color
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
Posted on Jun 05, 2007
SOURCE: Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Posted on Nov 17, 2008
  • 146 Answers
SOURCE: Mitsubishi 1080p 73'' DLP HDTV - Color distortion
You need to replace the "light engine". This is very very difficult. You need to take it to a repair shop. But this will be very expensive. Around $1,000.00
Posted on Nov 20, 2008
  • 668 Answers
SOURCE: TV screen goes black, sometimes for hours
This model series had a odd problem that caused this. It was the Hoizonal wire connctors for the yoke. If my memory serves me right, the Yoke wire harness went from Yoke to Yoke and plugged in at the casing of each yoke. What I found is the solder connection on the small board of each Yoke was intermitent. Please be careful if you choose to tackle this. It is in a HV Area.
Hope this helps,
Posted on Jun 19, 2009
  • 60 Answers
SOURCE: Stays on for 2 seconds and switches off
The convergence amplifiers need to be replaced.
This set may have one big amplfier chip rather than two.
The chip(s) will be on a big aluminum heatsink.
There may be bad resistors related to these chips, as well as one or two fuses that are open.
I've replace many convergence amplifiers.
If you have good soldering skills and ac test fuses and resistors, you can do the repair yourself. Caution that even with the set unplugged, there could still be dangerous voltages present on some components.
Search this site for specific convergence repair related to your set.
Posted on Sep 11, 2009
Mitsubishi WD73732 Where are the fuses?
Hello, make sure that the lamp covers are replaced properly. You might want to remove them again and reinstall them again, there are switches that have to be closed before the set will operate ....tks
Sep 17, 2014 | Mitsubishi WD73732
I have a 2 year old Mitsubishi WD-73732 - 1080p 73" Medallion Series DLP HDTV - WD73732. I am getting blotches of color when there are large areas of blue color. Looks like irregular moving stains...
It will cost you probably in the area of $700.00 to replace the Light Engine. I don't think it would be a good idea to repair it. DLP sets have been out of production a few years now due to high failure rates of the light engines for all makes and models and the consumer cost for the lamp.
Nov 10, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
Hi there...I have mitsubishi WD-73927 manufacture
If your TV is DLP , Then your Light engine is Bad,when color changes and little spots appear it is light engine.
Aug 19, 2009 | Mitsubishi WD73727 73" HDTV
TV has distortion very small on top and bottom which will flicker
This tv has two common problems:
in the power supply (set does distotions and shakes a lot etc very unstable until the set cannot work at all).
powerfully color gets back with a deep clean in the reflexion area. I'm sorry this job is for a technician, The set is so intricate for those two problems that any bad movement in this precision job could send the tv straight to wherever is bad.
Apr 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
This would be the little sensor on the light wheel. Its cheap, you can get them online for around $2. You will need to take the light engine out and remove the color wheel cover and remove the color wheel and then remove the sensor. You will have to desolder the sensor and remove it to replace with the new one.
What is happening is the sensor is overheating and not tracking the color wheel properly there for the colors get messed up. Once you replace the sensor the tv should work like normal. The part is
(Sharp GP2S40 Photointerrupter). It is very difficult to find because they are not made anymore. Most major online part stores do not carry them but I found a lot of them at Wright Hobbies. Good luck.
Nov 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Needing a new remote
if you are wanting the original remote you can visit:
if you are wanting to control more than just the tv such as an entertainment center i would go to a technology store such as circuit city and purchase a harmony remote
Feb 16, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi 45" Projection TV
You may need to replace the color wheel or the power outage may have damaged the DMD board too
Jan 05, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WD-73732 73" Television Logo
179 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
