Question about Royal EZ-Vue Calculator
Replacement Printer Cover
The little plastic cover on my print cover is broken, is there a place that sells replacement parts?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Yes. A funeral home!
Posted on Dec 04, 2014
Hinge is broken on my lexmark X6500 so cover won't close
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
Jul 23, 2011 | Lexmark X6570 InkJet Printer
How do i clean the rollers
Introduction Your printer requires minimum routine maintenance. This chapter explains the following tasks
  • Cleaning the printer
  • The toner cartridge
  • Extending toner cartridge life
  • Clearing a TONER LOW message
  • Replacing printer parts
Cleaning the printer To maintain print quality, thoroughly clean your printer:
  • Every time you change the toner cartridge
  • After printing approximately 6,000 pages
  • Whenever print quality problems occur
Clean the outside of the printer with a lightly water-dampened cloth. Clean the inside with only a dry,lint-free cloth. Observe the warnings and cautions that follow the cleaning tasks on the following pages. Caution To avoid permanent damage to the toner cartridge, do not use ammonia-based cleaners on or around your printer.
Printer Cleaning Tasks Before you begin these steps, turn the printer OFF and unplug the power cord. Caution Do not touch the transfer roller (black sponge-rubber roller) with your fingers. Skin oils on the roller can cause print quality problems.
If toner gets on your clothes, wipe it off with a dry cloth and wash your clothes in cold water. Hot water sets toner into fabric.
Warning Avoid touching the adjacent fusing area. It may be HOT
  1. OPen the printer's top cover and remove the toner cartridge
  2. with a dry lint-free cloth, wipe any residue off the Paper Access Cover (it has a green handle) and the adjacent silver metal strip.
  3. Wipe any dust or dirt off the black plastic Paper Feed Guide with a dry, lint-free cloth.
The Toner Cartridge see the printed book pending update of this page Extending Toner Cartridge Life see the printed book pending update of this page Clearing the TONER LOW Message see the printed book pending update of this page User-Replaceable Parts Some worn parts can be replaced by the owner. See Chapter 8, "Solving Printer Problems", for descriptions of the difficulties that can indicate when to replace a part. Warning Switch OFF and unplug the printer before replacing parts. Failure to do so may result in personal injury or damage to the printer. After switching the printer OFF and unplugging the power cord, allow the printer to cool for 30 minutes before replacing the parts.
Unless specifically noted, replacement is the reverse of removal. Always carefully observe the position and alignment of the part you are removing; this is your best guide to replacement. User Replaceable Parts Part Name Part Number Remarks Multi-Purpose (MP) Tray Pickup Roller RB1-2127-000CN Replace both the MP Tray Pickup Roller and the MP Separation Pad at the same time. Multi-Purpose (MP) Tray Separation Pad RF5-0343-000CN Replace both the MP Tray Pickup Roller and the MP Separation Pad at the same time. Paper Cassette Pickup Roller RB1-2204-000CN See Chapter 8 for replacement conditions. Transfer Roller RF5-0349-000CN See Chapter 8 for replacement conditions. Fusing Assembly RG5-0880-000CN 220-240 Volts Cleaning Brush RB1-2260-000CN n/a Optional LC Pickup Roller RB1-2650-000CN See Chapter 8 for replacement conditions. Ordering Information User replaceable parts are available from the authorized HP dealer or from Hewlett-Packard. To order parts, see this information Multi-Purpose (MP) Tray Paper Pickup Roller and Separation Pad Before you begin these steps, turn the printer OFF and unplug th power cord.
  1. Open the Multi-Purpose (MP) Tray.
  2. Grasp the black plastic Envelope Feed Access Cover as shown, and pull it downward and toward you to remove it.
  3. Read all of this step before proceeding. Remove the pickup roller by pushing down on the plastic retaining clip with your right index finger (see inset A) while sliding the roller to the right with your left index finger. When the roller is partway to th right, push in on the small plastic tab (see inset B) behind the right end of the roller and fully remove it.
  4. Insert a flat-blade screwdriver into th indentation at the front of the separation pad and twist the screwdriver blade gently to loosen the pad see (inset). When loose, gently lift pad from its seat.
  5. To install a new separation pad, place it over the opening and press it down firmly with your forefinger to seat it. Be sure the metal edge is toward the front of the printer. To install a new Multi-Purpose (MP) Tray Paper Pickup Roller, slide it over the shaft, then rotate it so that the flat side of the new roller is aligned with the flat side of the shaft. Then slide th roller to the left until it clicks into place.
  6. Reinstall the black plastic Envelope Feeder Access Cover and discard the used roller and pad.
Paper Cassette Pickup Roller Before you begin these steps, turn the printer OFF and unplug th power cord.
  1. Remove the toner cartridge.
  2. Remove the Paper Cassette.
  3. place the printer on its left side so that the bottom of the printer is easily accessible.
  4. Remove the pickup roller by pinching the release clip and sliding the roller off the shaft (the new roller will be installed in the reverse order). Slip the new roller over the shaft and rotate it until properly aligned. Slide the roller along the shaft until it clicks into place.
  5. Place the printer upright, then place the toner cartridge, Paper Cassette, and power cord. Switch the printer ON.
Transfer Roller see the printed book pending update of this page Fusing Assembly see the printed book pending update of this page Lower Cassette Pickup Roller Not applicable to HP printers at ING
Please rate my solution! :)) Thanks for asking me :)
Apr 13, 2011 | HP LaserJet 4 Printer
Mess. saying cover open i cant seem to close the top down. the top cover seem to be off track or broken
Feb 05, 2011 | Lexmark X6570 InkJet Printer
Hp laserjet 1320 printing blank pages
check printer door, there is a small plastic piece wich pushed down (to open) lasser scaner cover. if this piece is broken you can get blank page
Jun 30, 2009 | HP LaserJet 1320 Printer
Console fell and now front cover is broken and apart
no you cant fix it you have toget a new one
Dec 28, 2008 | Nintendo Wii Console
Motor switch not activating on a dfp-14ts
Is the cover assembly engaged and locked into place? If you can't lock the cover into place, it's possible that part of the plastic on the cover assembly is broken and not engaging the white rod inside the bowl. Determine which part is at fault (either the bowl or the cover assembly) and replace it.
Dec 19, 2008 | Cuisinart DFP-14BC Custom Food Processor
Replacement parts???
Here is a site that sells parts. - LINK
Dec 09, 2008 | Xerox Phaser 8500/DN Printer
Printer cover
Jul 28, 2008 | Lexmark X1270 All-In-One InkJet Printer
X3470
my printer keeps saying cover opened and won't swcith off or nothing can u please help me
Jul 03, 2008 | Lexmark X3470 All-In-One InkJet Printer
Cover open Error message
I'd say maybe the switchs is broken and your machine reminds me of a lexmark fault. Look for the cover switch, under lid on base, at rear, small hole, find the switch that get's activated when openning and closing the top, maybe it is missing, or broken.
link to lexmark fault, that I think you will find your answer.
Feb 06, 2008 | Canon MultiPASS MP360 All-In-One InkJet...
Royal EZ-Vue Calculator Logo
103 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
