Question about Dual XD-6200 CD Player
How to use the aux
I don't know how to hook up the aux
I have a marantz 2238b receiver and a magnasonic dvd 824-2. . where do I connect the cable to watch movies?
To play audio from your DVD player through the 2238b, you will need to hook the RCA left an right outputs from the DVD to the Aux IN on the back of the 2238b. Then you will need to power on the 2238b and place the selector switch to the Aux position. Lastly, adjust the volume to a level you are comfortable with and that should be it.
Thanks
www.back2lifeelectronics.com
Dec 09, 2013 | Marantz 2238 B Stereo Receiver Classic...
I have a denon avr 2000 dsp and want a manual which nobody has and I want to hook up my ipod classic. There isn't any AUX front or rear and I don't have a dock.
To hook up your ipod, get a 3.5mm to rca cable and use your ipod's headphone jack. Just don't turn the volume way up on the ipod otherwise the input signal may to at too high a level for the receiver.
Apr 08, 2013 | Audio Players & Recorders
Where is the auxiliary port in a 2000 Jimmy? It has an aux button but I don't know where the jack is??
hi,
If the car audio player have AUX input selction then there will be a port (stereo RCA) behind the player. Will be named as AUX IN.
ok
Sep 11, 2011 | Car Audio & Video
I have a 99 K2500 Suburban with a dual (isolated) battery system. I don't want the accessories to drain the starting battery.. Can't i just move the accessory feeds (from the starter or main...
I don't know how whatever accessories you have are hooked up but,
When I would run two batteries for my stereo in my car I had it connected to the auxilary battery. The isolators kinda **** because they are to send more power from the charging system to the battery that needs the most charge. They do not "isolate" as in makeing the system use one battery while not draining the other.
What I did was to hook a solenoid (mine was aftermarket but I think the old style Ford starter solenoids that bolted to a fender will do the same) inline of the battery cable so when my key was off one battery would be cut off from the other. That way I could play the sterio without draining the battery that started the car (the radio was on a rocker switch for when I needed to kill power).
Sep 03, 2011 | 1999 Chevrolet K2500
I have a small Sanyo television hooked up to a dvd player for my daughter....problem is I can't get it to go to the AUX channel. Don't have the remote that went with it, but do have a Sanyo FXMG...
Hello
Your sanyo TV has no menu button on its front panel control. Without its original remote, it is immpossible to get ito its AUX. OK.
Jun 13, 2011 | Sanyo DS13204 TV
I can not figure out how to get the audio from my tv/PS3 through my Sony MHC-65200. Is it possible and if it is possible what do i need to do?
Usually the way to do it is to connect audio out (Phono connectors) on the TV to audio/aux in on the stereo (phono connectors) Of course to do this, both of the pieces of equipment have to have the right connections.
Jul 15, 2010 | Sony MHC-771 Shelf System
Want to connect IPOD or Aux Device to my Blaupunkt
It really depends on the company who produced the radio. I know with certain types such as Kenwood, you have to get an auxiliary module that hooks into a pin-out on the back of the radio. However, if it is selecting Aux already, you may have a powered connection, so I would try hooking into the back if there is a spot, and see if it works.
Sep 29, 2009 | Car Audio & Video
How to hook up mp3
cant open the manual off pioneer.com i wanted to hook my ipod up does anyone know what the aux port is? for a pioneer deh-3500
Apr 22, 2008 | Pioneer DEH-P3500 CD Player
Dual XD-6200 CD Player Logo
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
