Question about Wharfedale Titan 12 ACTIVE 12" 2-Way Powered Speaker
No sound from base speaker
Just shut off sound
Both mini speakers are playing, but not getting any sound from the base box.... what might be happening?
The mini sub woofer's amplifier is not working but the other amps powering the left and right channels are ok.
Nov 28, 2013 | Klip Xtreme KSS-710 2.1 Stereo Speaker...
Bad sound quality on base speakerphone/answering machine
Hi , mostly in this case , the speaker in the base unit is defective . change the speaker.
Jul 09, 2012 | Panasonic KX TC1743B Cordless Phone
I WANT TO CONNECT HEADPHONES TO 1/4 INCH PHONE JACK ON TECHNICS AMPLIFIER IN A WAY THAT WILL CUT OFF SPEAKERS SO THAT AUDIO IS SOLELY THROUGH THE HEADPHONE. HOW DO I WIRE THIS USING THE PHONE JACK ON THE...
Please plug/ connect this wireless headphone base unit in Line Out jacks at back of amplifier to get sound in headphone and turn down amplifier volume control to shut off its speaker sound.
Thanks.
Aug 11, 2011 | Technics DJ Headphones
Need more volume on computer speakers
Buy yourself some stand alone speakers, a base & two side speakers, they cheap these days, base speaker has buit in amplifier & plugs into mains, or get surround sound 5speakers & a base, again mains powered, loud enough to annoy neighbours on full. Built in monitor speakers are renowned feeble tinny sounds. Right click speaker icon, bottom right, on your desktop toolbar, open volume control, ensure volume sliders set to max.
Oct 02, 2009 | ViewSonic VX910 19" LCD Monitor
JBL Creature Speakers have very low volume
use another device like your i pod to make your jbl sounds louder and then plugged it to your pc without turning it off. after plugging try to test it if works.
Apr 02, 2009 | JBL CREATURE II Computer Speakers
Speakers emitting a buzzing sound too frequently to ignore
There may be some sort of electrical device like a mobile phone or something that is near the base unit of the speakerset... try clearing the space around them.. or else it might be cuz of a loose connection... check n reseat all the cables & hopfully the problem will sort out...
Feb 11, 2009 | Inland ProSound 2000 Computer Speakers
03 chev silverado radio on but no sound
studying the radio schematics , i'm seeing a radio amp fuse under the hood ,in the main fuse box under hood , 30 amp , check that for starters , if the amp was out you would only lose sound , would like to get a fix ya vote , comment back because i have other thoughts on your schematics , and do you know if its the base model or premium sound , with or without cd ? , thanks .
Jan 11, 2009 | Car Audio & Video
Subwoofer works - sound goes away after some time
POSSIBLY A BREAK IN THE SPEAKER SUPPLY LEADS TO THE ACTUAL BASE UNIT
WE HAD THIS AND IT WAS NOT THE SPEAKER BUT THE BOLT ON CONNECTION UNDER THE SPADE TERMINAL ON THE BACK OF THE BASS UNIT
Dec 16, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Uniden BC248CLT BASE SCANNER
If it seems to be locking on a channel like someone is talking but no sound, it's possible that the speaker quit working. Simply plug in an external speaker into the plugin on the back. I have a BC 860 that the speaker recently quit. That's what I did and it sounds better. Good luck Mechanic
Jan 14, 2008 | Uniden BC248CLT Base Scanner
Speakers shut off
This may be due to a short in the wire or and lose wire in side. The reason the base stay on,it plug to the wall and the speakers our plug to it.
Jun 16, 2007 | Creative Labs Gigaworks S750 Computer...
Wharfedale Titan 12 ACTIVE 12" 2-Way Powered Speaker Logo
35 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
jason
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
