Question about Clarity Hugo Lightweight Rolling Walker with Seat
Broken brake cable on hugo walker P/N 00044HU-02, Rev 2.5 0603-4005
2 Suggested Answers
SOURCE: Interested in availability and price on Hugo walker w/seat
I bought one of these for my husband a couple of years ago and I bought it at Costco. Hope this helps.
Posted on Mar 21, 2009
I have a Chevrolet Cavalier year 2000, 2.2 OHV engine. I have to splice 38 broken wires that run to the PCM. I have found two purple wires and I do not know which ones I have to join. I need to have t
Hey Hugo, found this info. purple wire. I hope you don't need help with all 38 wires? autozone.com has free wiring diagrams, just register your vehicle and click on vehicle repair guides, find the link for wiring.
C1 is blue connector, c2 is black connector
c1-35 goes to brake switch
c2-61 goes to vss, vehicle speed sensor
c1-59 goes to datalink connector
c2-22 goes to pre converter 02 sensor
Jan 14, 2015 | Chevrolet Cars & Trucks
How to adjust brakes on an Essential Medical Supply Free Spirit Knee and Leg Walker
I would thing that it is much like a bike brake, there should be two options, first and easiest is at the hand brake there should be a screw thread with a nut on it, undo this nut a small amount and unscrew the threaded section the amount will depend on how loose the brake is start with a couple of turns try the brake and do more as needed, until your brakes are working properly again, if that is not an option (there is not threaded bar or the bar is full unscrewed) then you will need to follow the brake cable to the other end, there should be a screw holder that holds the internal metal cable loosen the screw / nut and with a pair of pliers pull the metal cable tight and tighten the screw / nut again, test brakes and adjust as needed.
this (if it is still hear when you look) is a great video guide to adjusting bike brakes, the principle is just the same., if the link is no longer active search youtube for "How to adjust bike brakes bike maintenance"
http://www.youtube.com/watch?v=hg6s596PPRY
I hope that helps, and if so please click on "yes"
Jun 01, 2014 | HD Smith Essential Medical Supply Free...
My toyota vitz 2007 cannot pick up speed, it cant even rev, whats the matter?
Accelerator cable broken or disconnected
Brakes need more brake fluid or pads are very low
Jan 30, 2013 | Air Ride Management 2006-2007 Toyota...
How to adjust parking brake on winnie lite 3 wheel rollator
For openers "LOCKING" handles)...
Very GENTLY would be the first caution..
Unlike the brakes on those long ago bicycles we used to have... these WALKER BRAKES are pretty cheesy plastic...
None of the ones I've been compelled to work with have
interchangeable parts... SO BE GENTLE.
Look at both ends of the cable of the first wheel you want to adjust...
You are looking for a threaded sleeve with a nut on it...
If the brakes are too tight you will want to shorten the sleeve...
Too loose you will want to lengthen it (tightening the cable).
DO NOT overtighten...
These are all plastic... cheaply constructed... but EXPENSIVE to replace.
I have had to hand craft REPLACEMENT PARTS to repair these things (nothing is STANDARD (but the careless attitudes).
When you do break'em... AMAZON had the greatest selection...
(knowing the mounting diameter, and cable length is imperative
(sold in PAIRS)).
Carnac the Magnificent
Jun 20, 2012 | Drive Winnie Lite Supreme 3 Wheel Rollator...
The brakes on a clever lite rolling walker will not engage when the grips are squeezed
There are adjusters on the brake cables that are designed to solve this problem. The cables for the brakes run inside a flexible housing. When you squeeze the handle, the cable should engage the brake. The problem is that the cables inside the housing stretch over time and do not work as well. There is a threaded adjuster at the handle where the housing of the cable goes into the handle. If you turn this adjuster counterclockwise it will, in effect, make the housing longer and the brake cable tighter (shorter). This should engage the brakes better. It make take some trial and error, turning the threaded adjusters clockwise and counter-clockwise to get the proper setting for your strength and comfort. Hope this helps.
Nov 09, 2010 | Drive Medical Winnie Walker, Mimi Lite...
Broken brake cable.Where do I get a replacement?
Hi. I repair walkers wheelchairs and mobility scooters. I sometimes get asked to repair broken brake cables on walkers and wheelchairs. I get new cables from the local bicycle repair shop. Take in your old cable so they can measure its lenght, and find one the same. They only cost a few dollars.
Good luck. Neil.
Jun 07, 2010 | Medline MDS808210AB ExcelT Deluxe Aluminum...
Erratic idle/stalling
the erratic idlling is probably caused by your TPS.
Jun 04, 2010 | Volvo 740 Cars & Trucks
How much will cost repairs of my hugo boss watches
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Apr 01, 2010 | Hugo Boss Metropolis Maxx Watch
Mar 02, 2009 | Clarity Hugo Lightweight Rolling Walker...
676 people viewed this question
Top Clarity Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Clarity Office Equipment and Supply Expert? Answer questions, earn points and help others
