Question about Metra 72-4568 2005 - 2008 BUICK LACROSSE CXS Car Audio Radio Wire Harness
How to reset the service engine lite for a mass air flow sensor
How do you reset the code after cleaning the mass air flow sensor
    Sergeant:
  • 182 Answers
It can be reset by a code reader or autozone, dealership, any car repair garage.
Posted on Nov 16, 2014
03 Nissan Altima showing codes P0304,P0102,P0154,P0113 what are they and how do i repair the problems.
Hi Chris.
p0304 = Number 4 Cylinder Misfire Detected
Faulty spark plug 4
Clogged or faulty fuel injector 4
Faulty ignition coil 4
Fuel injector 4 harness is open or shorted
Fuel injector 4 circuit poor electrical connection
Ignition coil 4 harness is open or shorted
Ignition coil 4 circuit poor electrical connection
Insufficient cylinder 4 compression
Incorrect fuel pressure
Intake air leak
The P0304 code means that the cylinder 4 is misfiring or is randomly misfiring. Start by checking for intake leaks an if no leaks are found the next step is to replace the spark plugs on cylinder 4.
p0102 = Mass or Volume Air Flow Circuit Low Input
Faulty mass air flow sensor
Intake air leaks
Dirty mass air flow sensor
Dirty mass air filter
Mass air flow sensor harness is open or shorted
Mass air flow sensor circuit poor electrical connection
Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner.
Reset code and drive vehicle.
If the code comes back, it may be necessary to replaced the mass air flow sensor.
p0154 = O2 Sensor Circuit No Activity Detected Sensor 1 Bank 2
Faulty Front Heated Oxygen Sensor Bank 2
Front Heated Oxygen Sensor Bank 2 harness is open or shorted
Front Heated Oxygen Sensor Bank 2 circuit poor electrical connection
Inappropriate fuel pressure
Faulty fuel injectors
Intake air leaks may be faulty
Exhaust gas leaks
Replacing the Front Heated Oxygen Sensor Bank 2 usually takes care of the problem.
p0113 = Intake Air Temperature Sensor Circuit High
Faulty Intake Air Temperature (IAT) sensor
Dirty air filter
Intake Air Temperature (IAT) sensor harness is open or shorted
Intake Air Temperature (IAT) sensor circuit poor electrical connection
The Intake Air Temperature (IAT) sensor is built into mass air flow sensor or in some vehicles mounted to the air filter duct housing. The sensor detects intake air temperature and transmits a signal to the Engine Control Module (ECM).The temperature sensing unit uses a thermistor which is sensitive to the change in temperature. Electrical resistance of the thermistor decreases in response to the temperature rise. The Intake Air Temperature signal is used as an input for various systems in the vehicle.
Hope this helps
FYT
http://www.autocodes.com/make/nissan
Mar 26, 2017 | Nissan Cars & Trucks
Symptoms of faulty air flow sensor
  • How to Detect and Clean a Faulty Mass Airflow Sensor ... www.carsdirect.com > Car Repair > Engine Repair 2012-02-24 · Symptoms of a Faulty Mass Air Flow Sensor ... Here are some of the most common symptoms of a faulty mass airflow sensor: ... CARSDIRECT IS AN ...
  • Mass Airflow Sensor: An Easy Fix for Big Problems from a ... www.airtexproducts.com/news-blog-mass-airflow-sensor-an-easy-fix... news,blog,mass,airflow,sensor,an,easy,fix,for,big,problems,from,a,little,instrument. ... Mass Airflow Sensor: ... What Are the Symptoms of a Faulty Mass Air Flow Sensor?
  • Signs & Symptoms of a Faulty Mass Air Flow Sensor www.geeksofcars.com/list_5794328_signs-mass-air-flow-sensor.html Signs & Symptoms of a Faulty Mass Air Flow Sensor. The Mass Air Flow Sensor is a device used on many fuel injected automobile engines to measure the density of air ...
  • See Bad Mass Airflow Sensor Symptoms on YouFixCars.com www.youfixcars.com/mass-airflow-sensor.html Video embedded · Mass airflow sensor problems can turn on the check engine light. They can also cause a variety of other symptoms before the ... How to clean mass air flow sensor ...
  • How to ' Tell If You Really Need a Mass Air Flow Sensor ... www.youtube.com/watch?v=aDlHCjgYf8s
    • BY AUTO REPAIR QUESTIONS ANSWERED BY WESLEY HARRISON
    • 4 MIN
    2011-08-22 · Video embedded · ... How To Clean a Mass Air Flow Meter and Tell if you really need ... Mass Air Flow Sensor ' Auto Repair ' Wesley Harrison ... Sensor Symptoms ...
  • Videos too.,
  • Go to Bing homepage
    Jul 09, 2016 | Cars & Trucks
    2003 Nissan Altima 2.5L Service Engine Soon Light is on, Auto Zone says codes are for MAF and O2 Sensors. Car hard to start after driving a while but when starts appears to run smooth. Auto Zone thi
    ok lets start with the codes they say your getting. P??? which 1's and how many. there are few o2 sensors, are they next to the Exhaust next to the converter? MASS AIR FLOW -MAF use this, for now i am guessing, until i see the correct codes your are getting. this could be the 1 you may have below, please read it........
    • P0103
      Mass Air Flow Sensor Circuit High Input
    • Possible causes
    • Faulty mass air flow sensor
      - Intake air leaks
      - Dirty mass air flow sensor
      - Dirty mass air filter
      - Mass air flow sensor harness is open or shorted
      - Mass air flow sensor circuit poor electrical connection
    • Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. If the code comes back, it may be necessary to replaced the mass air flow sensor.
    • possible symptoms Engine Light ON (or Service Engine Soon Warning Light)
      - Engine stall
      - Engine running rough
      - Excessive fuel consumption
      - Excessive smoke
    • the code is generated when An excessively high voltage from the sensor is sent to Engine Control Module (ECM).
    2003 NISSAN Altima Sedan OBDII Codes List
    Oct 22, 2014 | 2003 Nissan Altima
    2008 Chevy Kodiak c4500 duramax desiel code reader (Innova 3100 Can OBD2) shows P0102, what does it mean
    P0102 Chevrolet - Mass or Volume Air Flow Circuit Low Input
    Read more: http://engine-codes.com/p0102_chevrolet.html#ixzz38p5k1ZD8
    Possible causes - Faulty mass air flow sensor
    - Intake air leaks
    Read more: http://engine-codes.com/p0102_chevrolet.html#ixzz38p5tpWZk
    Jul 28, 2014 | Cars & Trucks
    Po101 code
    Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. Check for air leaks on or around any intake pipework using a good spraying of carb cleaner, if the engine surges then that's the leak. Check wiring to Maf and if the inside is dirty, again use carb cleaner liberally...NOTE: do not use Wd40... If the code comes back, it may be necessary to replaced the mass air flow sensor.
    Jun 04, 2014 | 2000 BMW 3 Series
    System lean
    intake tube has leak or mass air flow sensor is bad. check the bottom of intake tube for cracks. use only a dealer mass air flow sensor if no leaks are found. pep boys mass air will kick the same code
    Nov 28, 2013 | Hyundai Cars & Trucks
    2003 Grand Am Has P0102
    It is not an ECM/PCM problem.
    P0102 - Mass or Volume Air Flow Circuit Low Input
    Possible causes- Faulty mass air flow sensor
    - Dirty air filter
    - Mass air flow sensor electrical circuit poor connection
    - Intake air leaks Tech notes Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. If the code comes back, it may be necessary to replaced the mass air flow sensor
    Sep 27, 2012 | 2003 Pontiac Grand Am
    Spare part 12(po100)
    P0100 NISSAN - Mass Air Flow Sensor Circuit Range/Performance Error
    Possible causes- Dirty mass air flow sensor
    - Intake air leaks
    Tech notes Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. If the code comes back, it may be necessary to replaced the mass air flow sensor.
    Sep 25, 2012 | 1997 Nissan Pickup
    ISUZU TROOPER 3.2 V6 CODE P0101
    P0101 ISUZU - Mass Air Flow Circuit Performancexicon.jpghttp://engine-codes.com/p0101_isuzu.htmlForum CodePossible causes- Dirty mass air flow sensor
    - Intake air leaks
    Jul 04, 2012 | 2001 Isuzu Trooper
    Metra 72-4568 2005 - 2008 BUICK LACROSSE CXS Car Audio Radio Wire Harness Logo
    53 people viewed this question
    Top Metra Car Audio & Video Experts
    xxxxxx xxx
    Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
