Question about KitchenAid KSM150PS Artisan Series Stand Mixer
My Kitchenaid Mixer Attachments will not come off?
My attachment is complete stuck, when I try to push the attachment up so I can turn it off it will not push up. I'm moving to Hawaii at the end of the week and want to fix it before I leave. Please help :<
SOURCE: attachments fall off
Excerpt from: http://www.bamix-usa.com/
It can happen that the attachments fall off the shaft as they have in time become loose. In this case simply press the spring blades lightly together with a pair of pliers
Posted on Apr 26, 2008
SOURCE: kenwood chef mixer attachments
attachment for mixer model no. KM-230
  1.      sausages maker and mincer      2.     grinder and blender
Posted on Aug 10, 2008
ricardok45
  • 135 Answers
SOURCE: KitchenAid KSM5PSGR Stand Mixer - attachments not turning
Hi Gail. Kitchenaid no longer has a Parts List for your model. This means that they consider it obsolete. Do an Internet search for parts. You may get lucky. Good luck!
If this solution has assisted you, please rate it. ricardok45
Posted on Apr 04, 2009
  • 145 Answers
SOURCE: Are attachments for a KitchenAid K5 compatible with the K55?
Kitchenaid stand mixer attachments are considered universal, which means compatible with all mixers. However, all Hobart attachments pre-date the new motors of Kitchenaid and would not be compatible with Kitchenaid mixers.
Posted on Jul 08, 2009
SOURCE: Attachments are touching the bottom of the mixer
There's a video on Youtube that will help: ">
Posted on Dec 21, 2010
I found a 2004 kitchen mixer KSMC50S it says no attachments for this model although it has the gear and it spins. Any help appreciated.
The reason for the sticker is that the mixer is NSF certified.
The attachments are not rated for commercial or restaurant use, hence the sticker.
Of course, the attachments will work perfectly well with your mixer as they do with my KitchenAid KSMC50.
Dec 04, 2017 | Food Mixers
How to replace kitchenaid stand mixer gears
If you go here and download the parts it may assist you with the dismantling and should show you what parts are separate and what parts are only available as an assembly. Some of the gearboxes are complete units only.
http://www.kitchenaid.com/webapp/wcs/stores/servlet/WHRORNAjaxCatalogSearchView?storeId=10202&catalogId=10552&langId=-1&beginIndex=0&searchTerm=KG25H3XSL
Oct 03, 2015 | KitchenAid Used KG25H3XSL Household 5QT...
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
How do i get my kitchenaid attachment off it seems to be stuck
pour a little cooking oil where the attachments go in and wiggle around
Nov 01, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Whisk is stuck..can't be removed. what can i do? mixer is kitchen aid c 4. thanks for any suggestions!!
We had this same issue with our KitchenAid Mixer. Whether it is the whisk attachment or the paddle, the problem is that stuff (most likely sugar based) got into the attachment connection area and dried. It seems like a little sugar couldn't possibly glue the attachments to the stand mixer, but it does.
The solution is to turn the mixer on it's side and pour a kettle or two of boiling water on the section that joins the mixer to the attachments. Pour slowly to allow boiling water to penetrate grooves. Wiggle a little, pour more water, repeat... that should allow you to get it off.
In the future make sure to soak the attachments in boiling water every once and a while to allow all the gook to loose. And let it fully dry before reattaching to mixer.
Jul 13, 2009 | KitchenAid K45SS Classic Stand Mixer
Apr 02, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
That would be incorrect. If the attachment is for a hobart kitchenaid mixer then it will fit all models of kitchenaid mixers including the brand new pro series because the attachment port and drive gear has not been changes since 1925 or 6 when it was first introduce by the Hobart company.
Apr 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
I have a KitchenAid Model K4-B without attachments.
http://www.marbeck.com/mixers_kitchenaid_beaters.html
Here you can order any and all parts for this machine
Feb 08, 2009 | KitchenAid K45SS Classic Stand Mixer
Attachments won't turn
most likely a stripped worm gear if the motor still runs but the attachments/planetary gear won't turn.
Did this happen when mixing a big batch of dough or when something fell in the bowl that shouldn't have?
Dec 16, 2007 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
258 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
