Question about Refrigerators
Replacing a water elbow in a Fridgidare model FRS26ZRFW1. Can't pull old plastic elbow off the existing tubing. Do I need to cut and push in? The tube is coming into the ice maker/water dispenser from the bottom of the freezer door and then through the elbow and up to the water dispenser. currently water is leaking out of the top of the elbow.
I went to Lowes and bought a new Elbow (2.49) and cut the lower tube right at base of elbow. Upper tube slid out. Pulled a little on bottom tube and replaces easily.
Posted on Aug 22, 2009
`fix tubing that has leaked
The heat from the light bulb dried out the plastic hose on the dispenser. the tubing is 1/4 in and I used a brass compression fitting brass insert . I cut off the head of the insert so the tube was round and could be used to join a short piece of plastic tubing to the existing plastic tube in the door. Cut off the damaged section of tubing in the door and replace that length with new plastic tube. Push the brass insert halfway into the new plastic tube and then into the existing tube in the door. Route the tube into the original metal part on the door and it's done.
Sep 23, 2014 | Refrigerators
3800series2/engine cooling system
That plastic tube/elbow is a very common issue with these vehicles. To replace it you have to remove that whole bracket which houses the tensioner.
May 10, 2012 | 2002 Buick Park Avenue
Instructions for installation of amana water inlet valve 12544001
I know that seems like the incorrect part but it replaces the water valve that had 2 outlet hoses connected to it. To replace that;
Turn off house water supply to old valve and disconnect tubing
remove old valve and unplug the 2 wire connections and the 2 outlet hoses
The two outlet hoses were what was considered a Y hose..cut off semi clear plastic tubing a inch back where the 2 semi clear plastic tubes merge and become only 1
pull one of the plastic nuts off of the Y tube
slip it onto the end of the newly cut single tube
slip single tube into outlet threaded outlet of new valve and tighten that plastic nut
connect the 2 wire plugs onto new valve
remount to back of refrig
attatch house water supply to metal fitting that has/had protective rubber cap over it (oh of course remove procetive rubber cap and discard it)
turn water supply back on
it may up to 4 hrs for water to flow to icemaker so best to test by dispensing water through freezer door
Good luck,any questions or problems please reply and i'll help you,
Gene
Aug 12, 2011 | Amana 22.6 cu. ft. Side-By-Side...
My 2001 ford escort zx2 has a vacumn leak in the pvc elbow it also was kicking back an engine lean code. it runs but idle runs like it is trying to die when stopped. i've replaced the 02 sensor, plugs,...
for sure its the pcv elbows and hose.
you can only get the part from the dealer and they do not sell the elbows seperatly.you will need to get the whole hose.
they are 30 dollars from the dealer .you get the tube with new elbows on both ends.
its on the driver side under the hood and goes under the thermostat housing.
it is very easy to confuse it with the water heater hose.
the pcv tube connects to the pcv valve then routes back to the bottom of the intake tubes.both elbows are heat burt and torn open.
you will have to replace this new part and for sure all your check engine lights will stop as this air is getting by the mass sensor and not accounting for it in the fuel delivery there for showing a lean mix.a vaccum leak will let unaccounted air in the system and the computer will not deliver fuel for this air .not enough fuel is a lean burn.i just did one on this car 2 days ago.take off the intake tubes so you can reach down in there to take off the old .
let me know if it helps.
512 704-6925
joel mitchell
Aug 28, 2009 | 2001 Ford Escort ZX2
Water leak from ice maker
The fill line internal to the freezer is likely frozen up from the elbow inward.. When the icemaker calls for fill...pressure builds up on the plastic tubing causing it to pop out of the elbow. Check the tube inside the freezer by removing icemaker and running a long thin screwdriver or a rigid wire up into the tube until you feel ice or the plastic elbow outside.
Clear ice, if present, by squeezing hot water in from freezer side with turkey baster until cleared and water comes out back.
Aug 21, 2009 | Amana Refrigerators
WATER LINE 90 DEGREE ELBOW LEAKING FRONT LEFT
Did you actually break the elbow? you may be able to cut the tubing back and get a new surface for the elbow to push back into. if not a 5/16" push in connector is what you need you may be able to find this at a water condition store such as culligan.
Feb 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Installing new inlet valve
mike most water valves not are easy to repl the dispencer li and ice maker line are just push in all the way and they lock in place and to remove the all you do is push the ring around and they get relase. now the main line that supplies water that one you have to screw right you need new connectors.
Sep 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Amana ic6 ice maker
sounds like your ice maker is working properly and that maybe you pinched the water line when you reinstalled it back into the elbow.. is the elbow clear of any ice build up or foreighn matter that would restrict the flow of water into the ice mold tray? If so..that's your problem.. ( thaw it out or melt it and then you should be OK) Hope that helps..
Aug 18, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Connection for continuous discharge
There unit should have come with a small plastic tube. One end should have a thread connecion for hose hook-up. There should be an opening on the back of the unit that you push the tube through to connect with a little elbow tube inside the unit. You should be able to see the elbow connector from the front of the unit by removing the water bucket. Just push the plastic tube in from the back until it fits snuggly over or into the elbow tube and replace the water bucket. Run the connected hose to your sump pump.
Jul 16, 2008 | Dehumidifiers
Leaking icemaker
It sounds like your water valve is occasionally get stuck open and over filling the icemaker.
Oct 29, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
202 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
