Question about Black & Decker 14" Hd Chop Saw
Brushes access
Sparks coming off brush
#1 Check your brushes & brush springs - you will have to remove the switch handle completely to access both brushes
#2 Visual of the armature - is it black / burnt or does it have raised segments?
Most likely it will need an armature if it has run for any length of time with bad brushes.
The armature comes out the front of the motor housing so you need to remove the gearcase to access it. Armature 2610003331 for Bosch Power Tool eReplacement Parts Carbon Brush Set
Mar 25, 2014 | Bosch Factory - Reconditioned 7/8" SDS -...
Need to lkow were the brushes are located in the alternator of a 91 fire bird
on the backside of the alternator there is a little access door that you need to unscrew, the brushes will be inside there. It's the only area on the alternator where you can get access to inside.
Sep 24, 2012 | Cars & Trucks
My brush has stopped spinning and not sure how to access the belt
please specify which brush you are referring to and its usage
Aug 29, 2012 | Cars & Trucks
How to replace the brushes in a Dremel 395 Type 2?
I figured it out. Use a small std slot screwdriver (not a jewelers or hobby screwdriver, more like the smallest standard screwdriver in your regular tool kit). My Type 2 Model 395 has a couple small tabs. Put the blade of the screwdriver on one of the tabs (shaft of screwdriver perpendicular to the tool) and press downward (not too hard) and toward you (if right handed). The plastic tabbed cover should rotate in towards the tool. That's the brush holder and you are rotating it 180 degrees so that the brush comes to the top. It will take a couple of "bites" of the screwdriver to rotate it fully. Be careful b/c the brush is under spring tension and if you rotate it w/o care it will shoot out (my first one did). Anyway, you should see a carbon brush with a slight arc cut in it if you have any brush left. Hopefully, you have little or no brush and a spring. Then it's easy to replace (my brushes were OK and just re-seating them and my tool was OK). Note that the 90930 brushes sold at most hardware stores won't fit. They are for the Types 3,4, and 5 model 395 (and other dremel models). You need the 90929 brushes for the Type 2. My camera is klutzy. If you can't get it, let me know and I'll try to post a picture or video.
Jan 22, 2012 | Dremel Variable - Speed Multipro Rotary...
Trying to organise changing brushes in Tricity Bendix AW 1400. I'm in Scotland, daughter and machine in England! Does top or back come off machine to allow access and is motor fairly accessible for...
Washing machine motors are usually induction motors and do not have brushes? Anyway, the back comes off and that normally gives access to the screws that hold the top on, but the motor is normally located at the bottom of the machine.
Feb 14, 2011 | Tricity Bendix AW1400W Front Load Washer
Changing the belt
Always make sure your machine is unplugged from the outlet before replacing the belt.
Newer Oreck uprights have an access plate on the right hand side of the base (as you're looking at it from the front). Remove the one screw from the access plate and slide it forward. Snake the new belt around the brush roll pulley and then strrrrrrretch it back to the motor shaft. Replace the access plate.
If your model does not have an access plate; turn the machine upside down, Remove all screws. Lift the bottom plate off. Observe the position of the brush roll ends, One side of each end cap will have several notches cut into it,this is the 'new' side, the other side is smooth, this is the 'old' side. You can reposition the brush roll the the 'old' side if your bristles appear worn down.
With the brush roll still removed; place one end of the belt over the motor shaft first, place the other side of the belt around the brush roll pulley and stretch the brush roll forward until it is back in place.
Spin the brush roll by hand before replacing the cover to ensure the belt is not pinched.
Replace to cover.
May 16, 2010 | Oreck XL Ultra Bagged Upright Vacuum
HI; How do i change the brushes in an electric
Motors with carbon brush can be detected due to the two brush access at two opposite sides. Open this up,
and you can already change the carbon brush.
However, if your motor doesn't brush access, the probability is your motor is a capacitor motor. Replacing
the capacitors will restore your motor proper speed.
Oct 27, 2009 | Coleman Powermate 4 Gallon Air Compressor
Got a hobart mixer model h600-t cutting off and kicking breaker,it runs sometimes for about 5 min. when the ladys are mixing bread,checked amps,not under a load
If you can access the brushes you may want to inspect them. If anything but the carbon brush is touchiing thhe armature. It with trip a breaker.. Unplug it before accessing the brushes < -- my disclaimer :)
Oct 27, 2009 | Hobart H600 Stand Mixer
The brushes on my new healthy home vacuum wont rotate when the machine is turned on how do i access the belt location
If you turn the vacuum over so you can see the brush roll, there is a brush cover that is held on by (4) screws. Remove those screws and the base plate cover will come off. With the base plate cover off you can access the roller brush an belt. If you need a replacement belt you can get it here:
http://www.vacbelts.com/bissell-healthy-home-belt.htm
Oct 23, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Dirtlifter Powerbrush does not turn
Make the machine safe from the power source first
When you remove the belt access door you are looking at the pump belt,
To gain access to the brush belt you must turn the machine over and remove the brush at the bottom of the machine.
there are two screw in the red retainers at each side of the brush, remove the screws and the retainers and the pivot arms ,you should see the brush belt and the pump
Jun 07, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Black & Decker 14" Hd Chop Saw Logo
26 people viewed this question
Top Black & Decker Saws Experts
Jason
Mike Carew
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
