Question about Memorex Audio Players & Recorders
When I turn on, only four dashes show on display. was woprking fine, had to change batteries, then the four dashes came up. (batteries are new)discman d 11
Disc was cutting off, changed batteries, but would not play. Four dashes appear on readout. disc will not play. changed batteries again, with same result.
t00nz
  • 4738 Answers
SOURCE: Canon Powershot A540 - Change Batteries when Batteries Fully Charged
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Posted on May 28, 2008
SOURCE: Disc loads but I get four dashes showing on DVD window
plis help me
Posted on Oct 25, 2008
SOURCE: Magnavox Jogproof Personal CD Player - says HOLD
there is a switch that locks all controls
Posted on Mar 01, 2009
cheap to fix
  • 404 Answers
SOURCE: Laptop Screen Appeared Split Into Four Windows
that usualy happens when the screen has been replaced and it is not compatible with the laptop (is the screen blured too?)
can you see the same on an external screen?
Posted on Mar 02, 2009
SOURCE: program play prohibited
This can happen if you have the "repeat" function turned on on your DVD player.
Posted on Apr 21, 2009
How can I make my led show mph sense it only shows kilm sense the battery was replaced?
you have to go back to factory settings and change it from there
May 06, 2014 | Cars & Trucks
Phone line doesn't ring
First, lets get rid of the static. Try Feature #86. This will turn off background music. When a music source is not attached you get static.
Enter programming by using Feature XXX66344 password 266344. The display should show "Terminals&Sets" press the top right button with an indicator in the display. The display should show "Show set: ____ enter the extension number that you want to check or program. The display will show ***:name. Press the top right button three times. The display will show Show Line:____ with options to Scan or List. If you select Scan it will show the lines assigned to that phone. If you select List it will start with the first line in your phone system showing one of four states 1- Unassigned, 2- Ring Only, 3- Appear&Ring, 4- Appear only. Change the selection on the line by using the CHNG soft button. This is where line assignments are changed from the four states for each extension.
The only other thing that will keep an extension from ringing is "Do Not Disturb" or DND. Feature 85 and #85 will turn this feature on and Off.
Jan 31, 2014 | NorStar Meridian M7310 Phone
I got few dash lights off and I want to replace them or the whole panel.Could you tell me what is the way to change it please?
its in the FSM. and at alldata.com (get an account and read it)
lots of steps. and guessing invites broken plastic parts. or worse.
newer cars are like this,, not fun, or easy...
1: defeat air bags, per FSM, or die......
2: the panel is configured via the BCM./PCM
3: the CAN buss , MARRIES, the display to the BCM.
do not mess up , or the dash display will never be right again.!!
its uses a factory scan tool to run the diagnostics and Marry the dash.
here is one paragraph to get you up to speed. (RTM OR FAIL)
do not accidentally get it Un-married. dig? Replaces or power glitched.
Certain indicators in this instrument cluster are automatically configured. This feature allows those indicators to be activated or deactivated for compatibility with certain optional equipment. If the problem being diagnosed involves improper illumination of the cruise indicator, the electronic throttle control indicator, the tow/haul indicator, the service four-wheel drive indicator, the four-wheel drive low indicator, the four-wheel drive lock indicator, the transmission overtemp indicator, the security indicator or the gear selector indicator, disconnect and isolate the battery negative cable. After about five minutes, reconnect the battery negative cable and turn the ignition switch to the On position. The instrument cluster should automatically relearn the equipment in the vehicle and properly configure the configurable indicators accordingly.
btw:1: some cars have radio codes the op guide tells us. get the codes first before disconnecting any battery from any car.
or its bricked to.
Nov 07, 2013 | 2006 Jeep Grand Cherokee
Hello I am Trilochan Dash. I have supercomp UPS 600 VA My ups is work When there is electricity supply but fails when power cut off or fluctuate. my ups is 3 year old i have not replaced the battery...
Hello Trilochan dash, Your UPS probably must work after changing UPS battery... your battery some how damaged. So change it. Your Ups must work fine.. I think condition of ur UPS some how may be O.K. So change ur battery of ur UPS with a new one.. Try to change EXIDE battery, I found that this battery works fine and have longer lifecycle
May 13, 2011 | Computers & Internet
I have a 1998 bmw 5 series and nothing works
Does all the dash lighs light up?
This happed to me in my 318i, car sat for 3 months and it turned out to be the starter moter seized up.
Aug 24, 2009 | 1990 BMW 5 Series
2004 Lexus Ls 430 Low tire
My 2004 Lexus LS 430 has had the light come on several times, even after changing all four tires. There are no tire pressure sensors on my four tires. I was told the car computes tire rotations and since a low pressure tire takes more rotations than a fully inflated tire, the computer puts up a message on the dash.
To reset/turn off the message, put the emergency brake on, start the car and reach below the dash to the right side of your steering column until you feel two buttons in a depressed area under the dash. One button turns on /off your smart key and the other will turn off your tire low pressure message. Depress and hold until the message on your dash goes out and you are good to go. I know this works, I just reset mine a few minutes ago.
Mar 18, 2009 | 2005 Lexus Ls 430
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
