Question about GE 97985 Mouse
Mouse not moving
The computer says my device is working properly but it is not moving at all.
Mouse does not always go where you put it - maybe if you do it over and over or turn off the computer and start again it will work. It should respond as you move it the way it used to. What should I do? Is...
Well first of all you can check out the below steps -
1. Sometimes there can be no discernible cause for wireless mouse not working properly. One should attempt using the mouse with a different computer to check if there is something wrong with the mouse or not.
2. Sometimes, when there is an object lying between the receiver and the mouse, the wireless mouse may stop working. Such items could be cell phones, remotes, cameras, radios, wireless routers, desktop fans, large metal cases, or other such devices. Move these devices out of the way to fix the problem.
Anyway first we strongly suggest you to use your mouse with some other computer and check where is the problem.......
You can also follow the below link for more information -
http://support.microsoft.com/kb/838398
Please post comments for further help or information.....
Good Luck!!
Thanks
Apr 16, 2010 | Dell U0636 Mouse
I have an hp wireless mouse, and it doesn´t work!! Tried everything...
Wireless device like the mouse needs a wireless connectivity to a computer like a bluetooth or a wireless receiver. Make sure that your mouse batteries are all working and the wireless receiver is properly plug into the USB(Universal Serial Bus) port of the computer. The wireless receiver don't need battery so you don't have to worry about it. The two both have a push button, press both buttons to activate the connection. Wireless connections has limit in distance so make sure that you are not too far away from the receiver while using the mouse and that is 9 feet or 2.7 meters so keep that in mind. When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Hope this could help you a lot..:-) Thanks..
Dec 27, 2009 | HP Wireless Optical Mouse
My son did something to my computer and now the mouse does not move the cursor. How can I fix this? I have XP.
1) Is it wireless? Check batteries/re-synchronize.
2) Check the plug/connector at the mouse port on the back of the computer-loose/unplugged?
3) Broken mouse? Try plugging in a different mouse-one you know works.(New optical mice are relatively inexpensive-$10 or so)
If nothing above helps, use ARROW keys, TAB button and ENTER button to move around, and do the following:
go to windows START(lower left corner)
go to system
go to device manager
Now find your device MOUSE (yellow triangle indicates error)
Open your mouse ("Mice and other pointing devices")
On the first Tab GENERAL, it should say if the device is working properly or not.
You can DISABLE the mouse on the second Tab DRIVER, see if he disabled it. (You can enable it.)
Hope this helps.
Dec 15, 2009 | Microsoft Office Professional 2007 Full...
How do you change the wireless mouse from one computer to another?
A wireless mouse or keyboard relies on a feature in the computer itself to communicate with these devices. Unless the computer you're moving the wireless mouse to can communicate with wireless devices or also came with the same or similar mouse, you may be unsuccessful in your attempts to get it to work. Moving both the wireless mouse and the "card" out of one desktop computer to another should work if you want to go to that much trouble.
Nov 26, 2009 | Computers & Internet
Sir, usb mouse is working properly but in,
if the usb mouse is working properly then there may be a problem on the button click of the mouse or, there are viruses on your computer that modified the registry in which you wont be able to do a click on your system . try it on another computer, if it works then there may be mechanical problems on your mouse. Pm me if it works or not. Thank you .
Aug 07, 2009 | Compaq Presario Notebook
Mouse wont work
check your device manager and see if there is a problem there
to get there go to
start/control panel/performance maintance/system/hardware/device manager/mice. click the + on mice then right mouse properties and make sure the device is working properly and that it is enabled. then go to update driver and see if it will update
good luck
May 20, 2009 | Dell E228WFP Monitor
MY COMPUTER FREEZES UP WHEN ITS TURNED ON IT STAYS ON THE FIRST SCREEN AND YOU CANT MOVE THE MOUSE TO PUT IN THE PASSWORD
try to find out the status of device in device manager.
this may be due to driver not installed of the touchpad.
try to reinstall the driver properly.
Apr 19, 2009 | Computers & Internet
I just bought a new computer and during games, when I move the mouse, sometimes it doesn't respond well, it will lag out, and move slowly at times. It's a new mouse and I even checked other ones but they...
1.Try cleaning the bottom of the mouse.
2.Is it a USB based mouse? Check the USB hub\devices to make sure the drivers are installed properly. Try using the mouse on different port.
3. Your mouse might be driver specific, so the default mouse drivers might not work with the one your using. If they are you'll need to download the ones they need.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!! yuva
Mar 23, 2009 | Computers & Internet
A4Tech R7 problem
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
if that doesn't work try
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the software program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Dec 31, 2008 | A4tech R7-10 Mouse
GE Wireless Mini Mouse 97985
Press the link button on the receiver the indicator light should start blinking. Then within two seconds press the link button on the bottom of the mouse, the indicator light should quit blinking. After re-linking the devices move the mouse to see if it moves the cursor. If the cursor does not move, then move the mouse and see if the indicator light on the receiver blinks. If the device does not blink then try re-linking the devices again.
Jan 31, 2008 | GE 97985 Mouse
GE 97985 Mouse Logo
18 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
brian soufane
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
