Question about Nokia E75 Cell Phone
Lock code when open swith on you can see""lock code""
Intermittant key fob in volkswagon cc
put the key in contact,switch contact on,
push the remote while contact is on,and ket is in
all should work now
if not,
key in door lock,swith to open,while holding in open pos push remote,
Mar 22, 2014 | 2010 Volkswagen CC
I have forgot lock code of 5233 can u plz help me
Just master reset your mobile by pressing call key,callend key camers keyand switch onoff key at the same time,note: this process will reset your phone so make the back up of phonebefore swith off.and remove the memory card.first swith off the phone and do this process
Apr 17, 2013 | Nokia 5233 Mobile Phone
Reginal code for model dv450
Hello Guin,
The region code hack for DV454 works perfectly on LG DV450:
1: Press "Open" button on the player
2: Press "pause" button on the remote
3: Press "3" "1" "4" "1" "5" "9" button on the remote
4: You can check on the TV screen as now you can set your region code.
5. Press "0" button on the remote to select "Multiregion".
6. Press "pause" button on the remote.
7. Swith Off the player and wait for a few sec.
8. Swith On the player and it works.
Oct 18, 2011 | LG Televison & Video
I cant remember the lock code for n79
press and hold these keys *+3+green button and during press and hold u should press power button and switch off ur cell after that adopt same procedure while u want to swith on ur cell press and hold these combination keys untill u seen nokia logos ur lock code will be default
Sep 11, 2010 | Nokia N79 Cellular Phone
I accidentally put ON the phone code and i forgot the code
try hard reset..that will be remove all and that phone password
Hard reset is better for solved that problem..
First swith off you phone,after swith off,click *,3 and green key(call key)---->hold,
After to hold that key,now click power key to swith on --->*,3 and call key must hold...
Try it :)
Jun 02, 2010 | Nokia N95 Cellular Phone
STEREO LOCKED
you need to wait 24hrs (radio swithed on)to see if you can re-enter the propper code if not a local i.c.e/radio shop should be able to bypass the code system.
Mar 01, 2010 | 2008 Ford Focus SE Sedan
Unlock motorola v710 cell phone
MYSELF ALSO FACED THE SAME PROBLEM. SO I GOT THE UNLOCK CODE FROM UNLOCK CODE
NOW MY MOBILE IS WORKING GOOD.
Mar 28, 2009 | Motorola Mobility V710
Lid swith
Open the top of the unit by placing a putty knife beween the top and the front panel about two inches in. There is a spring lock that you need to push in, then lift the top. Once you lift the top, you will see the lid switch. Remove and replace. Let me know if you need further help. Jim
Nov 28, 2007 | Maytag Performa PAV2200
Nokia E75 Cell Phone Logo
18 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
