Question about 1996 Ford Explorer 2-door/Explorer Sport Ballistic Custom Seat Covers
Brake Caliper loose
Caliper top not staying fit to the brake house. do I replace the house or the caliper?
    Problem Solver:
  • 22 Answers
There is a clip for caliper which holds it....you might have lost it or forgot to place it.....clip is important to hold the pads....place it and it will not give rattling sound....
Hope it helps
Regards
Asad
Posted on Jan 21, 2015
  • 28 Answers
If you are saying the threads are stripped on the hose or caliber itself...if just the hose replace it if the caliber replace both. Not expensive and fairly easy to change...most have two mounting bolts..you will need to bleed the brakes after replacing them..good luck
What size allen wrench do i need for the front brake calipers
For front brake pads replacement you only need usually wrench set, inclusive 7 mm allen key also. But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!!
Instructions for front brake pads replacement.
For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow:
1. Do not disconnect the brake hose from the caliper, and do not allow the caliper to hang by the brake hose!
2. Remove top and bottom caps (on back side of the caliper) for access to guide pins, then unbolt and remove them from the brake carrier. Remove the caliper.
3. Now you must thoroughly clean the brake calipers (free of grease).
4. Remove outer brake pad from brake carrier.
5. Pull inner brake pad out of brake caliper piston.
6. Check up the brake fluid level on the reservor, and emptying if neccessary!
7. Push piston back into brake caliper housing.
8. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exist, must point in direction of brake disc rotation when vehicle is moving forward).
9. Install outer brake pad into brake carrier.
10. Bolt brake caliper housing to brake carrier using two guide pins. Tightening torque is 25 Nm.
11. Install both caps.
12. Insert retaining spring into brake caliper housing.
Important note: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!!
Check brake fluid level and top up as neccessary!
Sep 03, 2011 | 1994 Audi 100
Tip
How to replace AUDI front brake disc
Atention!!!
Don't disconnect any brake line from caliper!
Don't disconnect any ABS sensor!
For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow: 1. Do not disconnect the brake hose from the caliper, and do not allow the caliper to hang by the brake hose! 2. Remove top and bottom caps (on back side of the caliper) for access to guide pins, then unbolt and remove them from the brake carrier. Remove the caliper. 3. Now you must thoroughly clean the brake calipers (free of grease). 4. Remove outer brake pad from brake carrier. 5. Pull inner brake pad out of brake caliper piston. 6. Remove brake carrier from wheel bearing housing (two ribbed bolts). 125 Nm 7. Remove brake disc from wheel hub. 8. Install brake carrier on wheel bearing housing. Tightening torque for two ribbed bolts = 125 Nm. 9. Check up the brake fluid level on the reservor, and emptying if neccessary! 10. Push piston back into brake caliper housing. 11. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exist, must point in direction of brake disc rotation when vehicle is moving forward). 12. Install outer brake pad into brake carrier. 13. Bolt brake caliper housing to brake carrier using two guide pins. Tightening torque is 25 Nm. 14. Install both caps. 15. Insert retaining spring into brake caliper housing. Important: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!! Check brake fluid level and top up if neccessary!!!
on Dec 18, 2009 | Audi A4 Cars & Trucks
Tip
How to replace Audi brake pads
For front brake pads replacement you need only usually wrench set, inclusive 7 mm allen key also. But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!! For front brake pads. First you must verify yours front brake disc diameter: 280 mm or 288 mm. (On my car y have 288 mm). After that you can buy the brake pads (with wear sensor). For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow: 1. Do not disconnect the brake hose from the caliper, and do not allow the caliper to hang by the brake hose! 2. Remove top and bottom caps (on back side of the caliper) for access to guide pins, then unbolt and remove them from the brake carrier. Remove the caliper. 3. Now you must thoroughly clean the brake calipers (free of grease). 4. Remove outer brake pad from brake carrier. 5. Pull inner brake pad out of brake caliper piston. 6. Check up the brake fluid level on the reservor, and emptying if neccessary! 7. Push piston back into brake caliper housing. 8. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exist, must point in direction of brake disc rotation when vehicle is moving forward). 9. Install outer brake pad into brake carrier. 10. Bolt brake caliper housing to brake carrier using two guide pins. Tightening torque is 25 Nm. 11. Install both caps. 12. Insert retaining spring into brake caliper housing. Important: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!! Check brake fluid level and top up if neccessary!!!
on Dec 05, 2009 | Audi A4 Cars & Trucks
Remving caliper pins on 2000 vw jetta and caliper
For front brake pads. You should buy the brake pads (with wear sensor). For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow:
Jun 26, 2011 | 2000 Volkswagen Jetta TDI
How do i get the calippers of to get old pads out and new ones in
Apr 13, 2011 | Volkswagen Polo Cars & Trucks
I want to change my front brake pads How do I remove the old ones
Apr 12, 2011 | Volkswagen Polo Cars & Trucks
Step by step instructions on how to replace front break pads on a 2003 VW Passat
For front brake pads. First you must verify yours front brake disc diameter: 280 mm or 288 mm. After that you can buy the brake pads (with wear sensor). For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow:
Mar 10, 2011 | Volkswagen Passat Cars & Trucks
Change brake pads
Sep 30, 2010 | Audi A6 Cars & Trucks
Anything special about changing front pads on audi a3? I've done honda, acura and toyota's.
For front brake pads replacement you need only usually wrench set, inclusive 7 mm allen key also. But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!! For front brake pads. For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow: 1. Do not disconnect the brake hose from the caliper, and do not allow the caliper to hang by the brake hose! 2. Remove top and bottom caps (on back side of the caliper) for access to guide pins, then unbolt and remove them from the brake carrier. Remove the caliper. 3. Now you must thoroughly clean the brake calipers (free of grease). 4. Remove outer brake pad from brake carrier. 5. Pull inner brake pad out of brake caliper piston. 6. Check up the brake fluid level on the reservor, and emptying if neccessary! 7. Push piston back into brake caliper housing. 8. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exist, must point in direction of brake disc rotation when vehicle is moving forward). 9. Install outer brake pad into brake carrier. 10. Bolt brake caliper housing to brake carrier using two guide pins. Tightening torque is 25 Nm. 11. Install both caps. 12. Insert retaining spring into brake caliper housing. Important: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!! Check brake fluid level and top up if neccessary!!!
Aug 25, 2010 | 2007 Audi A3
WHAT TOOLS ARE NEEDE TO REPLACE AUDI A3 SPORTSBACK FRONT BRAKE PADS
For front brake pads replacement you need only usually wrench set, inclusive 7 mm allen key also. But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!! For front brake pads. You must buy the brake pads with wear sensor. For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow:
8. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exists, must point in direction of brake disc rotation when vehicle is moving forward).
Feb 14, 2010 | 2006 Audi A3
1996 Ford Explorer 2-door/Explorer Sport Ballistic Custom Seat Covers Logo
51 people viewed this question
Top Coverking Vehicle Parts & Accessories Experts
David Harrelson
David Harrelson
Lawrence Oravetz
Nicola Conroy
Are you a Coverking Vehicle Part and Accessory Expert? Answer questions, earn points and help others
