Question about Ryobi RCS3535CA Petrol Chainsaw 35cc 35cm/14" bar
How to remove and replace ryobi 38cc petrol chainsaw spark plug
How to remove and replace spark plug
  • 42 Answers
SOURCE: Ryobi 18" petrol chainsaw won't start
my guess is that you have a crack or a hole in one of your fuel lines. this is very common in chainsaws and weed eaters because they are used very little and sit for a long time. try checking this and repair if necessary. let me know if this works.
Posted on Mar 08, 2009
dontbother10
  • 2220 Answers
SOURCE: ryobi 40cc chainsaw
Have you checked for spark? Sounds as though your ignition module has quit.
Remove the plug, connect a jumper wire between the threaded part of the plug and the cooling fins, Switch the ignition on, take it into a dark room and pull the starter. You should see a spark at the tip of the plug. HTH
Lou
Posted on Sep 17, 2009
  • 4088 Answers
SOURCE: my ryobi 40cc chainsaw wont start, spark at plug
'No compression' usually means serious mechanical problems with the piston/rings, but if this unit has a compression release, then it may be 'set' which reduces compression considerably until the engine fires. Try putting some fuel mix into the cylinder head spark plug hole and reinstall the plug. If it runs for a few seconds, then look into the fuel delivery system (did the compression increase?). Check that the carburetor is bolted tightly to the engine and the fuel lines are intact. Make sure the choke will close all the way and the throttle opens all the way. Make sure that the primer bulb fills with fuel after several pumps. Assuming that the engine ran properly for the people that 'reconditioned' the saw, this unit should not be giving you problems like this.
Posted on Dec 31, 2009
dontbother10
  • 2220 Answers
SOURCE: Ryobi Chainsaw won't turn. removed pull cord
Starter Handle difficult to pull:
1. Remove the starter cover.
· Inspect the flywheel and crankshaft under the starter cover. Are the woodruff key slots on the crack shaft and flywheel aligned and the key intact? If not; Please consider taking the saw to a good local saw seller/mechanic for a written diagnosis before authorizing any repair, if yes continue.
· Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if not repair the starter.
2. Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
· Leave the ignition off, set the valve and pull the starter.
· Pull gently to release the valve. Is there a difference in the effort required?
· If yes continue with 3, if no repair or replace the decompression valve.
3. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including but not limited to; leaky intake connections at the engine or carburetor; leaky crankcase seals; cracked fuel delivery lines; running on gasoline containing no 2-cycle oil.
· Disconnect the spark plug wire and remove the plug. Remove the muffler (clean it and the spark arrestor before reinstalling), hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Please Note: Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 01, 2010
  • 1514 Answers
SOURCE: my Ryobi petrol RCS 3540c
Check that the chain is on the right way around. The cutting edge of the teeth on the chain, at the bottom of the bar should face towards you and away from you on the top. It's most likely that the chain is facing the wrong way. If you don't know how to fit a chain look at the video on http://www.ehow.co.uk/video_4419336_replace-chainsaw-chain.htm
If that's not the problem then the chain is blunt and needs to be sharpened badly. You can sharpen it, with a special file which can be got from chainsaw dealers, or take it to a garden tool hire centre and have it sharpened professionally. It has to be sharpened professionally from time to time anyway to keep it cutting straight so if it's that blunt I'd recommend you get done professionally now.
The smoke if it's coming from the chain is caused by overheating from trying to cut with the chain which is too blunt or turned the wrong way. If the smoke is coming from the engine check your fuel. You should have petrol mixed with 2 stroke oil. The saw manual will give the ratio of 2 stroke oil to petrol. If you use too much oil or if it's not 2 stroke it will cause smoke from the engine. Also if you use cheap oil it can cause smoke. It's best to use good quality oil like husqvarna or stihl 2 stroke. These also protect the saw better than the cheap brands you get at car service stations which are really only meant for boats which are water cooled.
Posted on Jan 20, 2011
Testimonial: "Thankyou, I'll check that. It's only about a year old and hardly used so possibly not blunt but chain problems."
Poulan chainsaw not getting any spark???
you might have a broken wire to the spark plug. Use a meter to check continuity on the wire.
Aug 08, 2014 | Poulan 16" 38cc Gas Chain Saw P3816
Clutch
Remove the spark plug and stuff a rope that will NOT shed particles in the combustion chamber. This will keep the piston from full travel allowing you to remove the nut to replace the clutch.
Nov 05, 2013 | Poulan 16" 38cc Gas Chain Saw P3816
I have a poulan pp3816 pro 38cc that leaks gas out the muffler
Its either well flooded, or the carb needle is leaking, remove the spark plug, with the ignition switch off crank the engine to evacuate any fuel left in the cylinder, leave the machine for a couple of hours, re fit the plug and try to start useing no choke, if it still does not start, remove the spark plug again, rest it on top of the cylinder ( away from the spark plug hole ) crank the engine and check for a spark, if it has a good spark and the plug is soaked with fuel it could be a carb needle leaking, remove the carb, remove the metering cover held with four screws, replace the rubber tipped needle.
Jun 21, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a ryobi chainsaw that floods even if I dont prime it at all when trying to start it.. Before I go to start it the air cleaner is soaked with petrol and when I remove the spark plug it is wet.On...
Ideally saws should be stored in cool conditions out of the sun to prevent pressure building up and with the tank lower than the engine.
Drain the tank also and run the engine dry, as when the fuel evaporates, it leaves a varnish residue which coats the small pasageways in the carburettor.
It is possible that the fuel pump diaphragm in the carburettor is punctured and this is allowing fuel to seep into the saw
Apr 23, 2011 | Ryobi Garden
I have a gardentec 38cc petrol chainsaw which wont start
What kind of saw. How old? New Spark Plug? How old is the gas inside it? Is the air filter dirty? When you try to start it does it turn easy or is it a little stubborn or won't turn at all?
Mar 29, 2011 | Garden
Hi Please can you confirm what fuel the Ryobi rg6700k generator takes?
Hi. I've been looking online and there's no information about this model. However this is how to tell which fuel it uses. If it has a spark-plug it burns petrol. Diesel engines don't have spark-plugs they use glow plugs which are different. Spark-plugs have a spark gap which the spark jumps across while glow plugs do not.
If it has a separate place for putting oil, and a dipstick for checking the oil level, then the fuel is petrol only. If it doesn't have a place for oil then the fuel is petrol mixed with 2 stroke oil. I hope this answers your question.
Jan 19, 2011 | Garden
I can't start Spear and Jackson 38cc Chainsaw
Remove the spark plug and test for blue, snappy spark. If nothing, try a new plug set for 0.020" gap. If still nothing, remove the cover from the flywheel side to expose the ignition module. Remove the ignition switch wire from the module and try for spark again--if ok, check for a grounded ignition switch or the wire itself. If still nothing, replace the ignition module. Use a thin business card for a pole gap between the module and the flywheel magnets. Allow the module poles to contact the magnets, then tighten the screws. Rotate the flywheel to remove the card. If you got spark in the first test, then place some fuel mix in the plug hole and try to start. You should get several pops. If ok, then work on the fuel system. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. If the machine is fairly old, you should check the condition of the lower chamber diaphragm in the carburetor--it may have become hard or cracked. Hope some of this helps!
Jun 30, 2010 | Garden
New Ryobi petrol c/saw wont start.
If it is brand new, sounds like you should return it for the retailer to have repaired.
Dec 05, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Mar 08, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi RCS3535CA Petrol Chainsaw 35cc 35cm/14" bar Logo
44 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
