Question about HEWLETT-PACKARD HP EliteBook 8440P Business Notebook
Frozen cursor cursor has frozen and wont move
My acer 15.6inch the cursor is frozen wont move
Which mouse are you using? Is it the integrated mouse or the USB mouse?
If you are using the USB mouse, then try checking if it's plugged in correctly.
If it's your integrated mouse, then restart the computer and when it's up. Try moving your mouse. Restarting it usually does the trick.
If restarting it won't fix the problem, then restart and boot to safe mode. While restarting, tap F8 until you see the options to boot to safe mode. Highlight safe mode by using the arrow keys and hit enter. When you are in safe mode, try moving your mouse. Works or not - update the mouse driver. You can use RadarSync. If no go, then you might need to do a system restore. If worse comes worst, do a complete operating system reinstallation.
I hope this helps!
David
Mar 25, 2013 | Computers & Internet
My cursor is frozen and wont move what should i do???
Restart the computer if it stays like that for longer than a minute.
May 10, 2011 | ASUS Eee PC 1000HE Netbook
Laptop cursor is frozen and will not move. Computer is brand new. How do I fix it?
double click the top left corner of the touch pad (there should be a yellow light that is illuminated when the cursor is frozen or locked).
Dec 25, 2010 | HP Computers & Internet
Cursor frozen will not move
Cursor not move or frozen.very interesting.Problem operating systems or system unite.Service it and install new windows.
Dec 04, 2009 | Acer Computers & Internet
Cursor is frozen on the lap top
try using your external mouse to reinstall the touchpad driver. in almost all cases i've seen of this it has fixed the problem.
hope this helps
Jan 16, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Toshiba laptop frozen screen
Try restarting the computer.
Jan 06, 2009 | Computers & Internet
Frozen cursor on new emachine laptop
Before you plan to return make sure you have done some or all of this things first:
1. Did you reboot after you installed the Enterprise 2007 ?
2. Did you make sure that if its a USB mouse that it is securely connected to the USB port ?
3. Were you able to move your mouse without any problem at all before the software installation ?
4. Have you had this problem before the installation of Enterprise 2007 ?
5. Have you done all your software and windows updates ?
6. Will the mouse work when booting into Safe Mode ( pressing F8 during re-boot before Windows Vista loads) If it does then your softwares need to be updated.
7. Did you check you device manager to see that theres no yellow exclamation anywhere in the Mice and othert pointing devices or under the USB controller section?
8. Is there a legacy USB port to be activated on your computer BIOS ?
If the installation caused your mouse to be frozen then try and uninstall the Enterprise 2007 by using your keyboard and tab to the programs uninstall.
If your mouse still doesn't move after doing all of the above things
then try another new USB mouse. Sometimes you may have to wait for several seconds (even up to a minute for new usb mouse detection) before the USB mouse cursor will move. If the second new USB mouse still wont work then return it to where you bought it as it could be faulty usb connector
Dec 28, 2008 | Computers & Internet
T20 cursor frozen
Computer mouse help and information A mouse is a hardware device which allows the user to control a cursor to manipulate data .... CH000981, The wheel on my mouse is not working properly.
How to navigate Windows using a keyboard. Not only does this help users who do not have access to a mouse, it can also save you a great deal of time when working with text documents.
E-mail CHID: 6268 This feature enables you to move a mouse cursor or use mous buttons using ... also possible that your keyboard could be bad, causing the keys not to work.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | IBM ThinkPad T20 Notebook
HEWLETT-PACKARD HP EliteBook 8440P Business Notebook Logo
18 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
