Question about Samsung BIXOLON® SRP-770II Thermal Label Printer
WONT PRINT ALL THE LABELS
I am using a POS system to print, but it wont print all the label quantities sent to the printer.
  • 12 Answers
SOURCE: Envelopes and labeles
Go the "print" dialog and select "settings". Ensure that the paper size, margins and orientation are not set for 8.5x11.  You did not mention the software you are using to print the envelopes/labels so this is the only guess I can give.   I have seen software that made me have to override the settings before.
Posted on Oct 15, 2007
SOURCE: Label Printing
On the subject of <a href="http://www.selfadhesivelabels.com/label-printing.html">label printing</a>, i actually get all my labels printed by a british labels company for a really low price. If anyone is at all interested then it may be worth taking a look at their website as they do all types of label printing.
Posted on May 02, 2008
SOURCE: flaking ink
no funciona no se ya esta conectada pero dise que conecte el microfono
Posted on Oct 17, 2008
SOURCE: Can't print labels
I found out that each time you print from the manual load tray, i.e. letters and labels, once you have the paper in the manual load tray press print and then press the demo button to start the manual feed. I hope this helps.
Posted on Dec 24, 2008
  • 134 Answers
SOURCE: Hi, I hope you can help me with a problem I have
You have to change the paper settings on the properties tab before you print. This way the fuser will know to increase the heat and fuse the toner to the thicker paper.
Posted on Apr 15, 2010
Easycoder C4 Printer wont print
See if this can help:
epsfiles.intermec.com/eps.../1-960572-01%20UG%20EC%20C4.pdf
May 26, 2014 | Intermec Easycoder C4 Therm Label Printer...
The Monarch 9403 does not print out multiples of labels continuously, it stops between each single label. Can you help? Cheers Debbie
Debbie,
I may need a little more information.
If you are using a 3rd part software application like that from Loftware, you may need to create your labels in such a manner that the print module prints strips of labels, and in the quantity that you need. Then the printer should produce the quantity each time you go to print.
If you are using a 3rd party driver, like that from Seagull Scientific, then you need to tell it to print that quantity, just like you would when printing something on your inkjet printer.
If you are sending the printer's native language directly to the printer, there is something called the format header. It looks something like this:
{B,1,N,1|
The second 1, is the quantity of labels. So if you want it to print 5, you need to change it to something like...
{B,1,N,5|
If neither of these make sense, please provide some additional details so that I may provide further assistance.
Jun 25, 2010 | Paxar Monarch 9403 Thermal Printer
TEC B472 won't print full qty of labels
What is the software used?
Normally the printer will decrement or increment its counters when the correct instructions are sent, If it is the pc that sends the labels then your problem is due to the pc.
Otherwise if the count is internal then external electromagnetic noises may cause this sort of phenomenon.
If it's on a parallel port, then your problem may comme from the vibrations of the printer. The init signal on this port is very near to a gnd pin and with the vibrations this causes a reset of the printer.
Last problem may come from a firmware deterioration. All depends cpu either the firmware is Eprom or Rom.
Jun 29, 2009 | Toshiba TEC B-472 Thermal Label Printer
Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
Apr 21, 2009 | Zebra Z4Mplus Label Printer
Zebra LP2443 thermal label printer wont print
Hi Buck,
What type of labels are you using?
Cheers
Bob
Jan 12, 2009 | Zebra LP 2443 Thermal Label Printer
Printer problem
I called CAM Commerce Solutions, the retail POS software we use, and they were able to fix my problem. I was missing another component of the print program that only CAM Commerce has.
Dec 17, 2008 | Zebra Eltron TLP 2742 Thermal Label...
Wont print
Check to make sure you have direct thermal labels. You can test this by scratching your fingernail across the label quickly. You should see a black line. This printer uses the same paper as a ups or fedex label. test a ups of fedex label with the fingernail test. Does it look the same? or call Andrew @ 908-725-1699
Jun 17, 2008 | Zebra LP 2844 Thermal Printer
Printing addresses on labels
did set the parameters in the system before printing labels you can make a new printer control in printers section to only be label printed with the same printer you use
when you goto print click on the new print control that you have set for labels this way your software wont get the big confusion of paper or labels
May 07, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Samsung BIXOLON® SRP-770II Thermal Label Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
