Question about Canon PIXMA MP280 Photo Inkjet All-in-One Printer, Copy/Print/Scan
My picture is too dark i want to make lighter
When i print picture its too dark how can make it lighter? what is the correct settings?
SONY DIGTIAL
You never should use the picture you see on the monitor of the camera. Not one camera has a calibrated screen. And the brightness is changed very easy in the setup menu.
To test if your camera shoots good pictures, select AUTO on the mode dial. Shoot some pictures and look on the PC or just print them.
Your camera has so many settings, that over rule the brightness when you switch to it, like + and - 2 EV setting. But when you chose for A, P, S, or M, the pictures can be to dark or to bright, if you dial in the wrong settings. So don't evaluate the pictures on the monitor. Only use the histogram on your camera to see if you have a correct, to dark or to light picture.
Jan 06, 2014 | Panasonic Lumix DMC-TZ3 Digital Camera
Turns on dark and then gets lighter
ic circuit is the problem, see TV Tech.
Nov 09, 2013 | RCA F32650 32" TV
My Printer Prints Out Too Dark
go into printer properties and change the setting....you probably are using an after-market cartridge...they are notorious for being too dark....even if that is not the case, go to printer properties and change the setting....if there is no slide bar for heavy to light, then clik on toner saver, it should print lighter than it does now
Apr 27, 2012 | Samsung SCX 4600 multifunction Laser...
My camera over exposes everything - the shutter stays open for about 2-3 seconds. except when on video settings. No matter what I set it at nothing changes.
Looking down at the top of the camera, check the left knob. This is the exposure compensation dial. Adjust it to "0". If set one way or the other, it will make pictures darker or lighter. This comes in handy when the image has a lot of dark or bright areas - moving this dial will allow you to make the bright areas darker or the dark areas lighter when you camera's light meter is setting the exposure in a way you do not want.
If still having trouble, make sure the right knob (Mode) is not set to M or Manual. Switch it to Program or Auto and try taking a picture again. You might even want to set the outer knob (ISO) to AUTO as well to reduce the chances of an incorrect setting. If it now works as expected, but you want to shoot in M, you will need to learn how to use the meter to select the correct combination of aperture (f stop), shutter speed and ISO to obtain the desired results.
Oh, experiment with the exposure compensation knob when you have a chance, learn how it can help correct overly dark / bright scenes. Good luck!
Feb 14, 2012 | Canon PowerShot G10 Digital Camera
How can i make my pictures lighter. they are too dark
look at control panel printer properties of the printer ur printing to. See if there is a setting for
"picture quality" you may be able to adjust from there. If not depends on the picture editing software that ur using most all have "contrast" "brightness" slide bars that will alter picture viewing and printing
Feb 15, 2011 | Office Equipment & Supplies
Blue lines at the bottom of a coloured pictue I copied
try cleaning the print-heads from printers menu
you probably have a goggled print-head
Apr 27, 2010 | Lexmark X5150 All-In-One InkJet Printer
I dropped my DSC S650
the ccd imagery sensor is bad.will have to be replaced to work correctly.
May 12, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Dark pictures
You did not say what sensitivity setting you had the camera set at- the higher the sensitivity the lighter the picture. Actually- all the image information is there so all that needs to be done is to edit the image lighter in a graphics editing program[You did say whether or not you import images to a computer] Come back back with more info on what you do with the images.
Apr 27, 2007 | Olympus Camedia C-3020 Zoom Digital Camera
Canon PIXMA MP280 Photo Inkjet All-in-One Printer, Copy/Print/Scan Logo
old marine
old marine
