Question about Lexmark C Office Equipment & Supplies
C748 error 976:0
Service Network Software
2 Suggested Answers
SOURCE: lexmark 540n 976:0 service network software
Had the same probelm. Resolved it by disabling AutoIP feature in Network Settings. Also set hard IP without DHCP.
Posted on Feb 28, 2010
How do i fix error 976.0 on lexmark ms410dn
A 976.xx error can be caused by IPv6 (i.e., internet protocol version 6) compatibility issues. It is possible to resolve this issue by disabling IPv6 in the Network Menu.
Jul 07, 2014 | Lexmark MS410DN Laser Printer - Monochrome...
What is foneGEAR (00976) Wireless Headset charging voltage
The charger that came with my 976 headset is 5.3 volts at 250 ma on 60 cycle 115 volts. Hope this helps. 3's
Grampa
PS the manual can be found here:
http://www.manualslib.com/manual/251101/Fonegear-976.html#manual
Oct 13, 2011 | foneGEAR (00976) Wireless Headset
900 service rip software
The 900 error usually indicates a software or communications problem. If the 900 error occurs only when the printer is receiving information from a network or computer, you should contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer.
To check the base printer
Turn off the printer and disconnect every cable, except for the power cord.
Turn on the printer and see if the error returns.
If the error does not return, try to print a test page from the Test Menu.
If the test page prints correctly, the printer
May 05, 2011 | Lexmark Optra T610 Laser Printer
How to fix message error 900.00 service RIP software on Lexmark c 530 dn
Does the error pop up when the printer is booting up, receiving information via network, connected via usb, or connected via parallel cable? It could be two problem. If it would post during printing, then it could be cause by a software or network problem. Test the printer in a standalone mode without any usb or network connection, if the error would post upon power up and without any network connection or usb connection then its a hardware problem. If it's a hardware problem, it would require a service call.
May 10, 2010 | Lexmark C530dn Laser Printer
MUTIPLE LEXMARK PRINTERS RUNNING ALL GETTING 976:0 SRV NET ERROR CODES
this network error being created in multiple units would be caused by a couple of things one is that you had a stormy day , and electrical storm or a power surge that has corrupted the nvram chips on the network cards they will need to be replaced. it is always a good idea to install surge protectors on your electronics
Feb 10, 2010 | Lexmark Optra T616 Laser Printer
Lexmark 540n 976:0 service network software
Feb 03, 2010 | Lexmark C540N PROD SPECS TBD Printer
My blackberry curve 8900 has a white screen saying app error 523? then reset
Hi, The BlackBerry smartphone displays the JVM 523 error message: For BlackBerry smartphones running BlackBerry Device Software version 4.1, this error may occur if a third-party browser channel icon has a HyperText Transfer Protocol (HTTP) redirect. OR When a locked BlackBerry smartphone with content protection enabled receives a Multimedia Messaging Service (MMS) message, this error may occur. This error only occurs with the Today themes in BlackBerry Device Software version 4.2.2. Download and install the latest version of BlackBerry Device Software on the BlackBerry smartphone by following these steps: Download the latest version of BlackBerry Device Software from your wireless service provider's web site. Install BlackBerry Device Software on your BlackBerry smartphone. BlackBerry Device Software version 4.1 (only) If you are running BlackBerry Device Software version 4.1, you need to complete the following steps: Complete one of the following, depending on the network on which the BlackBerry smartphone is operating: · For BlackBerry smartphones operating on a Code Division Multiple Access (CDMA) network, contact your service provider and have the BlackBerry Internet Service Browsing deactivated. · For BlackBerry smartphones operating on a Global System for Mobile Communications (GSM), remove the Subscriber Identity Module (SIM) card from the BlackBerry smartphone. Perform a hard reset on the BlackBerry smartphone. Turn the wireless transceiver off. Click the Browser icon. Expand the Browser Channels folder. Highlight a third-party browser push channel. Display the menu and click Delete Channel. Repeat steps 7 and 8 for each third-party browser push channel. Complete one of the following, depending on the network on which the BlackBerry smartphone is operating: · For BlackBerry smartphones operating on a CDMA network, contact your wireless service provider and have the BlackBerry Internet Service Browsing activated. · For BlackBerry smartphones operating on a GSM network, reinsert the SIM card. Turn on the wireless transceiver. Register the BlackBerry smartphone on the wireless network. Subscribe to the third-party browser push channels again. BlackBerry Device Software version 4.2.2 Change the theme on the BlackBerry smartphone to one other than the Today theme by completing the following steps: From the Home screen on the BlackBerry smartphone, select Options. Select Theme. Select any theme that is not the Today theme. Display the menu and select Activate. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 27, 2009 | RIM BlackBerry Pearl 8100
What is the JUM Error 523 on the Blackberry Storm? It sometimes pops up and makes the screen white and it displays "JUM Error 523." You can then click "continue" and it seems okay, but I want to make sure...
For BlackBerry smartphones running BlackBerry® Device Software version 4.1, this error may occur if a third-party browser channel icon has a HyperText Transfer Protocol (HTTP) redirect.
OR
Download and install the latest version of BlackBerry® Device Software on the BlackBerry smartphone by following these steps:
  1. Download the latest version of BlackBerry Device Software from your wireless service provider's web site.
  2. Install BlackBerry Device Software on your BlackBerry smartphone.
  1. Complete one of the following, depending on the network on which the BlackBerry smartphone is operating:
    • For BlackBerry smartphones operating on a Code Division Multiple Access (CDMA) network, contact your service provider and have the BlackBerry Internet Service Browsing deactivated.
    • For BlackBerry smartphones operating on a Global System for Mobile Communications® (GSM®), remove the Subscriber Identity Module (SIM) card from the BlackBerry smartphone.
  2. Perform a hard reset on the BlackBerry smartphone.
  3. Turn the wireless transceiver off.
  4. Click the Browser icon.
  5. Expand the Browser Channels folder.
  6. Highlight a third-party browser push channel.
  7. Display the menu and click Delete Channel.
  8. Repeat steps 7 and 8 for each third-party browser push channel.
  9. Complete one of the following, depending on the network on which the BlackBerry smartphone is operating:
    • For BlackBerry smartphones operating on a CDMA network, contact your wireless service provider and have the BlackBerry Internet Service Browsing activated.
    • For BlackBerry smartphones operating on a GSM network, reinsert the SIM card.
  10. Turn on the wireless transceiver.
  11. Register the BlackBerry smartphone on the wireless network.
  12. Subscribe to the third-party browser push channels again.
  1. From the Home screen on the BlackBerry smartphone, select Options.
  2. Select Theme.
  3. Select any theme that is not the Today theme.
  4. Display the menu and select Activate.
Nov 13, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
How to fix error 427
VPN error that says "secure VPN Connection Terminated by Peer. Reason 427: Unknown error occured at peer. " This error occur about 30 sec to 1 min after connection has been made. My users are not letting the system sit idle. What could be causing the problem I am using VPN Client 4.6.
Aug 06, 2009 | Computers & Internet
88 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
