Question about Miele CVA615 Espresso Machine
Brew unit missing
Need codes to find brew unit
  • 10 Answers
SOURCE: Brew unit in Miele coffee system CVA615 block
It sounds like the connector or wiring that links the LCD display board on the door to the main PCB inside the coffe maker has become loose or damaged.
This would cause the text displayed to become scrambled.
Its a 26 way connector that is labelled JP16 (on the next model up) and is next to a large IC.
Posted on Jan 02, 2008
dahaka
  • 347 Answers
SOURCE: brew unit stuck
Hi molly girl.
You can try to clean your Brewunit. Most of the times when that message appears, it means the brewunit is dirty
You can have more info in the manual if you dont have it:
http://www.miele.co.uk/Resources/OperatingInstructions/CVA%20620.pdf
Posted on Jan 11, 2008
SOURCE: miele brew unit jammed and brewunit block is being displayed
There is a third solution. The brewunit drive motor has three contact switches that indicate home, preset (loading grounds, I assume) and make espresso. The problem is the three contact switches are all on one circuit, so the microprocessor knows a limit switch has been reached, but it doesn't know which one. The programming obviously assumes the limit switches are reached in the correct sequence. In my case, the microprocessor thought the brew unit was in home position when it was in the make espresso position. Miele technical support recognized this immediately, so it is a common problem. The solution is to remove the top panel of the unit, unplug the unit, unplug JP34 on the microprocessor board (four wires, red/yellow/brown/black, in the middle back edge of the microprocessor board). Plug in the unit, put it in maintenance mode, and press and hold the medium coffee button for several seconds. This will move the drive motor past the current limit switch. Plug JP34 back in, plug in the machine, and put it in maintenance mode. Press and hold the large coffee button for a second or two, maximum. Open the machine, and look at the brew unit drive male gear in the main machine as compared to the brew unit female gear. It will take several tries to get the male/female gears to match so you can plug in the brew unit. Once this is done, and the brew unit snaps in place correctly, place the machine in maintenance mode one more time and press and hold the Medium Coffee button to reset the microprocessor with the limit switches. You should be back in business!
Posted on Jul 16, 2008
Master_Tech
  • 770 Answers
SOURCE: brew unit missing
post your email i will send you the guide that shows you how to properly install the brew head
Posted on Aug 20, 2008
  • 4 Answers
SOURCE: Getting Fault 73 for my CVA 4070 at start-up.
I have had the same fault 73. Miele is coming out to replace the drive and the brew unit. SHould be a $700 repair. Thank God for warranties. I'll et you know the end result once repairs are complete.
Posted on Mar 17, 2010
Brew unit miss
Hi
Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed (food grade only), so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Apr 21, 2011 | Saeco Royal Professional Espresso Machine
Brew unit missing
Hi
Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Aug 27, 2010 | Saeco Magic Comfort Plus Espresso Machine
The display my machine says "Brew unite miss" what it means? How can I fix this?
Hi Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Feb 12, 2010 | Saeco Royal Professional Espresso Machine
W/o manual I have a brew unit miss message?
Hi
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Jan 03, 2010 | Saeco Royal Professional Espresso Machine
Steady Brew Group Light: Old Saeco Magic deluxe
Dec 08, 2009 | Saeco Magic De Luxe Espresso Machine
Machine is stuck in rinse cycle and brewunit
Take the brew unit out again, and try to twist the rotational mechanism so that the little arrows in the front of the axis align. This should allow you to insert the unit.
On insertion, you might also need to push the little handle on the front of the brew unit to allow the coffee trough to fit.
Oct 11, 2009 | Gaggia Titanium Espresso Machine
It say brew unit missing
The brew unit missing switch is inside the slot at top back wall where the top of the brew unit puts an angled piece of plastic into the slot. The piece is a slope like a nose so it gently pushes the switch as you instert the brew unit. See if the brew unit reaches this slot on the wall. If it doesn't the brew unit most likely jammed up and was removed while the gears were not in home position. Now the gears are not allowing the brew unit to return fully inserted.
If you're handy you can call Miele tech support and request they walk you through steps to diagnose this. They will discover if the gear is out of home position or not. If it is not and the switch is in contact with the brew unit you may be in luck, the swith is cheap. But if the electronics no longer reads the switch signal it's 800 bucks to replace. Good luck!
Oct 07, 2009 | Miele CVA615 Espresso Machine
Cleanded brew unit as instructed - brew unit miss error
check small switch behind brew unit in machine maybe your brew unit dont touch switch.
Aug 30, 2009 | Saeco Royal Digital Plus Coffee...
Brew unit missing
Make sure the unit is seated properly, if any part flew off or out, it can be replaced at www.partsguru.com
Oct 13, 2008 | Saeco Magic Comfort Plus Espresso Machine
Brew unit missing
May 30, 2008 | Miele CVA615 Espresso Machine
Miele CVA615 Espresso Machine Logo
20 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
