Question about Briggs & Stratton Garden
Craftsman fuse location
Cant find fuse
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 23 Answers
A model number would help alot.....it should be under seat and start usually with a 917 -----number. Sears has a website that is nice....enter your model number there and you can pull up a electrical parts and wiring breakdown. That being said a popular place for alot of standard sears tractor mowers is located on the right hand side under the gas tank....clipped to the metal edging. Check the web site at sears parts and enter your model.
Posted on Aug 05, 2015
Fuse for igntion were its located
    Riding Lawn Mower Fuse Replacement - Craftsman Lawn ...
    ? 1:51
    https://www.youtube.com/watch?v=rjFz8l8hoGk
    Aug 22, 2014 - Uploaded by RepairClinic.com
    ... instructions for replacing the fuse on a Craftsman riding lawn mower. ... Mower Starter Solenoid Replacement - Craftsman Riding Lawn ...
    14 HP Murray Mower 42813x92B Blowing the Fuse - YouTube
    ? 4:37
    https://www.youtube.com/watch?v=J8l1Ew40G7g
    Feb 14, 2013 - Uploaded by RogerASkiVideo
    Photographic guide to troubleshooting a Murray riding mower that keeps blowing the 15 amp fuse. images for Lawn Mowers ignition fuse
Dec 19, 2015 | Garden
Where is the fuse for craftman lawn tractor model 917 289210 located
The fuse is on right side engine from back of engine to right panel.
Sep 20, 2014 | Craftsman Garden
Where is the fuse box on gt 5000 craftsman lawn mower?
If you think your riding lawn mower has blown a fuse, trying to locate that fuse may be the most challenging step in replacing it. While different lawn mower manufacturers have located the fuse holder in different areas of the lawn mower, the best place to start looking is near the mower's battery, according to Sears.
Some manufacturers have made it easy to find the fuse holder. Simply lift the hood. The fuse holder is molded into the metal right inside the hood, near the battery. (See photo at Ref. 3, p. 53) If the battery is located beneath the seat, you may find the fuse holder located beneath the rear fender. Other manufacturers make it more challenging, placing the fuse inside an electrical box, located behind the mower's upper air baffle. (Ref. 4, p. 28) Fuses can also be located on or close to the edge of the mower's electrical panel, above the solenoid.
If you check these locations and still cannot find the fuse holder, check your operator's manual for a diagram of the electrical system, which should display the fuse's location. If you no longer have your manual, it may be available online through the manufacturer's website. Should you be unable to find a manual, call a local lawn mower dealership or lawn mower repair shop and ask for assistance in locating the fuse in your exact model.
Jun 27, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Fuses location for craftsman 26 hp 54" deck mower
Replace start fuse on right side of motor by oil drain plug.
May 04, 2013 | Craftsman 26 Hp 54" Deck Yard Tractor
Craftsman Briggs and Stratton 675 series Mower fuse location
Is battery powered, did you try calling sears tech center for further info ?
i have found them to be very helpfull with mower problems.
Sep 12, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Fuse location
they are flat fuse holders the tape to the harness follow it from the switch you will find them
Sep 03, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
26hp kohler craftsman wont start. just quit running yesterday. battery is good...plugs good. no clicking noise or lights, etc.
hey i think there is a 20a fuse open which would describe your problem. on the discharge side there is a auto style 20a fuse closest to the steering cowl the bracket that hold the starter relay is were the fuse is. you cant see the fuse but on the bottom of the bracket you will see a little clip pull that clip down and the fuse is attached to that. if the fuse is open that why it wont start. thats were im at now on my problem now the fun part whats causing it to open. hope this helped
Aug 16, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
I have a Craftsman LT 1000 riding mower that just quit running. Won't turn over or anything. Manual suggests checking fuse as one of the options. Only problem is, I can't find the fuse! Manual says it is...
Start with the easiest thing first !
1) jump start the battery from you automobile, or install a charger for an hour. This will tell you wether you battery or connections are good.
If it started with the jump, before you replace a battery:
2) clean the cable ends and make sure cable hardware to battery posts are good and clean.
If it started with the jump, then you know the fuses are good.
If it did not start with the jump or cleaned and charged battery,
3) check the in-line fuse. Located between the key switch and the solenoid, in the wiring harness, normally behind the firewall behind the engine, or in front of the dash close to the fuel tank (if the battery is under the seat)
4) some Sears tractors use a 'relay' also located on the firewall.
Note: for now, let's see how this works. Let me know if you need further assistance. It can get more complicated, but let's keep it simple for now. rwvanlue
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 12, 2009 | Craftsman Garden
Garden Logo
61 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
