Question about Zanussi 18 in. DCS14W Free-standing Dishwasher
As soon as I switch on my Zanussi ZDF 221 Dishwasher it buzzes and nothoing else happens. Any ideas?
I get a buzzing noise when I switch on, but nothing else happens
5 Suggested Answers
Trifect7
  • 57 Answers
SOURCE: dishwasher zanussi zsf 6128
Either it's not getting enough water to flip over to the next part of it's cycle (unlikely) or the water float gauge is not working properly.
When the dishwasher is cool, look for the float inside the dishwasher --usually a small plastic dome or cylinder mounted inside at the tub's base, near the front. When you move most types of floats up and down, you can hear them click because they trip a lever (they are spring loaded). Lift out the float mechanism and clean around the float tube; many floats must be disconnected from below--to do this you'll have to remove the lower access panel. Rinse off the float, then replace it in the tube and be sure it moves up and down freely.
If you're experienced with minor repair work shut off the hot water valve to the appliance. Locate the water intake valve, behind the dishwasher's bottom front panel, disassemble the valve to reveal the screen, clean debris from the screen, and reassemble. If the screen doesn't appear to be blocked, call a repairperson (they will probably need to replace the water intake valve).
If none of this helps, call a repair person. Any of several parts, including water inlet valve, pressure switch, and the timer or selector switch, may be faulty.
Posted on Mar 02, 2008
joe_lishman
  • 192 Answers
SOURCE: Hi, my zanussi zdf221 dishwasher wont work, it
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Posted on Jan 17, 2010
  • 901 Answers
SOURCE: Dishwasher power there but wont fill up with water
The slight buzz is coming from the water inlet valve solinoid. It's OK.
But check whether water is getting into the inlet tube of the washer. Check the filter at the rear of the dish washer body wher the inlet tube from your water tap is connected.
Posted on Apr 05, 2010
  • 713 Answers
SOURCE: i have a Zanussi ZDF 231 dishwasher...it keeps
your belt on dish wash is bad replace belt.
Posted on Feb 18, 2011
What is code.30
Zanussi ZDF 511 User Manual
anti flood device is activated,call for service
Mar 31, 2015 | Electrolux Genuine ZANUSSI ZDF511...
Dishlex dx 203 buzzer
solenoids that control water flow (taps) buzz when failing Check out the water in solenoid.
May 26, 2013 | Dishwashers
Noisy Dishwasher
it is a capacitor to start the motor for the next cycle. I think it is inside the door. you may have to call a tech.
May 19, 2013 | Whirlpool GU2300XTVQ Builtin Dishwasher
Dishwasher power there but wont fill up with water makes a slight buzz sound any ideas please ?? It's a Zanussi zdt6252 by the way..
Apr 05, 2010 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Machine is not washing, spinning or draining
has someone interfered with the inlet tap. The buzzing is normally a sign that the appliance is trying to take water but tap is off.
Mar 29, 2010 | Zanussi ZWF14070 Front Load Washer
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
Zanussi built-in oven ZDF 866W socket blows when turned on
sounds as if a wire to the fsd is shorting when oven turned on.
Sep 28, 2009 | Ovens
Our Nautilus dishwasher won't turn on. I can hear a buzzing noise, but nothing is happening. Does anyone now what I should do?
The same thing happens with my dishwasher. I have made it work by doing the following. When you start up the cycle, turn the dial to just a tick before "start." If you hear the buzzing, but no water is running, unlock and then lock the dishwasher door again. This usually gets it running. If it's still not running water, unlock, advance the dial a little bit, and lock again. This should work. You need to be around for the early parts of the dishwashing cycle because this machine tends to stop up and buzz without running water until it gets past "short wash." Every time this happens, do the same thing, unlock and lock, and advance the dial a little when necessary. Once you get past "short wash," it should complete the wash without intervention.
Feb 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Buzzing plenum heater
is the fan relay going bad it is located normally inside control box behind panel where wiring enters unit
Jan 04, 2009 | Heating & Cooling
Zanussi 18 in. DCS14W Free-standing Dishwasher Logo
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
