Question about Sewing Machines
Skipping stitches Maching skipping stitches
  • 26 Answers
SOURCE: needle thread does not pick up bobbin thread it
clean it using a can of air to make sure there is not any fabric or dust caught in the under area. the needle could be bent slighly just replace it.
these are the two things I look for when this happens with my machine. needle is the one most offten causing the problem.
Posted on Mar 08, 2009
SOURCE: skipping stitches
Rule of thumb: Fast needle, slow hands. This should help. GiGi
Posted on Mar 15, 2009
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
WonderTech
  • 268 Answers
SOURCE: skipping stitches and knotting up underneath.
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
Hope this helps.
Posted on Sep 23, 2009
RickE1
  • 202 Answers
SOURCE: BSR skips stitches
Hi, I am a Bernina tech and can tell you what the problem is. The problem is that the spring on your BSR is weak. Bernina has an upgrade to adding a heavier spring that solves this problem. The older lighter springs on the BSR is shiny. The newer heavier updated spring is dark. Ask your dealer/tech to change this spring to a new one or give you a newer updated BSR. Also be sure they updated the BSR to the latest firmware.
Rick
Posted on Oct 08, 2009
Testimonial: "Thanks, this was very helpful!"
Why does the stitches skip when I'm sewing?
Needle old or bent, incorrect size. Incorrect thread for material, packed with lint. The sewing foot is not on correctly or the needle is not pushed in high enough. Old thread. Hope this helps.
Aug 19, 2017 | Sewing Machines
Skipped stitches
Skipped stitches could result from several different origins. First, easiest, and least expensive thing, try a brand new needle. However, if it is failing to pick up the bobbin thread all together, then it is probably out of time (search for sewing machine timing or take it for service).
Here are other suggestions for intermittent skipping:
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Basic Maintenance Tension Skipped Stitches
http://www.sewingreviews.org/what-to-do-when-your-machine-starts-skipping-stitches
Jan 03, 2017 | Sewing Machines
Skipping stitches
Feb 19, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
10 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
