Question about GE Energy Star WCVH6260F Front Load Washer
Water level How much water should be in the tub during a normal load? I used to notice water level would come up part way in the door window. Now it seems that there is barely enough water to get the clothes wet, and no water at all standing in the inner tub. Also, sometimes there is still a small amount of detergent in the dispenser when the rinse cycle starts so it is not even running enough water to completely wash all of the detergent out of the dispenser. How does the washer sense the amount of water needed for a load?
  • 1 more comment
  • kevinbeeler Nov 05, 2007
    Actually, I may have been wrong to say there is no water at all standing in the inner tub. Today I hit the pause button half way through the wash cycle and opened the door to check the water lever. There was about 3 or 4 inches of water in the bottom of the inner tub under the clothes. Is this normal??
    if(typeof(dstb)!= "undefined"){ dstb();}
  • Anonymous Mar 23, 2014
    there is no spin between the wash and the rinse. Also the amount of water used during rinse is much less than the amount of water used during a wash.
  • Anonymous Mar 28, 2014
    I START MY WASHER TO WASH A HEAVY LOAD AND JUST A LITTER BIT OF WATER WILL COME IN THE TUB
    Scholar:
  • 146 Answers
The level of water in the drum is controlled by a pressure switch. This switch is attatched to the drum via an air tube which pushes air into the pressure switch as the machine fills with water. There could be a blockage in the pressure chamber attatched to the drum or the pressure switch is faulty.
Posted on Oct 31, 2007
Lint, and debris not going to filter
Generally speaking grass clipping etc will stay in tub on a hi efficiency washer. That's why the water level is very low also-high efficiency,low water use. Most LG washers have an extra water button to add a small level of water per wash.
Jan 16, 2018 | LG SteamWasher WM2650H 27" Front-Load...
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
This is for an LW7503W2B washer. We have water on the floor during agitate with large loads. The water is comming over the edge of the tub. I have noticed the tub rotates in what I would call a slow...
I had the same problem. You need a brake kit. it holds the drum still while in the agitate mode. the centrifical force of the water during that slow spin is causing the water to spill over the top of your drum. easy and cheap fix.
Oct 18, 2010 | Amana ALW780QA
The washer always seems to have water trapped someplace...when I turn the drum after a load has finished I can hear the water moving around. Now I've noticed a sour smell. Also sometimes at the end of a...
There is a solution inside the inner tub cover that helps serve as a balancing aid during the spin cycle. It is a normal sound on the washer. There is not a problem.
Jul 21, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Fdb1050rec1 frigidaire dishwasher door leak
I think you most likely have a basin Float water level sensor that is no working correctly, the door seal is not water proof, if the water level gets over the lip of the basin it will leak on the floor.
May 01, 2017 | Frigidaire Dishwashers
There is no water visible during the wash or rinse cycles
hi there,
may i know exactly the unit that you have
Mar 14, 2009 | Washing Machines
Water Remaining in Gasket Around Door
normal problem all front loads all brands.. leave door open as much as possible.. to clean fill tub with hot water pour in 2 cups chlorine bleach use rag in solution wipe gasket out as good as possible allow washer to run normal cycle ..do as routine when ever odor is first noticed leaving door open will allow most of water to evaporate
Nov 19, 2008 | Kenmore Elite 45986 Front Load Washer
Another flood. GE washer
The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
Nov 08, 2007 | GE WDSR2080D Top Load Washer
Washer tub slowly fills with water
Is your problem a SLOW FILL problem, or a problem with WATER DRIPPING FROM THE RUBBER DOOR SEAL - or BOTH? If you have a slow fill problem, this is generally caused by a bad fill valve, which can be attributed to hard water deposits or well water mineral deposits. Sometimes the fill valve can be removed, cleaned and reinstalled, but most of the time a new fill valve is required. If you are experiencing water leaking from the rubber door seal (bellow), it may be time to replace it. Sometimes the seal can develop a wrinkle or crease where it meets the glass, which can cause leaks. Water dripping from the door when you open after washing a load is normal. Water dripping during a load is NOT. The bellow may also have started to rip or tear inside the door which may not be noticeable until you pull the folds of the bellow back and look underneath it. I hope this helps.
Jan 17, 2007 | Kenmore Elite 45986 Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
341 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
