Question about ECS Computers & Internet
Disk read error press ctr+del to restart - ECS Computers & Internet
    Problem Solver:
  • 12 Answers
SATA connector cable faulty or not plugged in properly or power not available for harddrive, or read-write heads of HDD broken or damaged. If this is the case, replace HDD. tests can start by using another harddrive with working operating system, or by unplugging both power and data cables to drive, as well as the data cable from board. be sure to power off the computer
Posted on Oct 14, 2014
colliewob
  • 781 Answers
SOURCE: read cd error..
are your cd cables in the back plugged in correctly
broad cable should have the stripe side nnearest to 4 pin power plug
and if on the same cable as hard drive the cd should be set to slave
st the plug end will be a 6/8 pin jumper set up ensure the jumper is on the one marked SL
If on seperate cabble should be set on the one marked MA
Posted on Jul 27, 2008
preachw996
  • 1179 Answers
SOURCE: reading error
What type of HDD is this? IDE; SATA; or SATA II? The problem probably is that you are trying to use a SATA drive with a SATA II board. They are not backwards compatible. Hope this helps.
Posted on Dec 21, 2008
hasbensystem
  • 63 Answers
SOURCE: ''Unable to read from disk or disk error, press ctrl+alt+del to...
Try new hard drive. Its faster than messing with all this.
Posted on Dec 23, 2008
  • 2386 Answers
SOURCE: hai all when switch on my pc, a message
your boot sequence is changed, put the hard disk to first boot in setup menu, or the hard disk gone bad.
Posted on Feb 24, 2009
acdr
  • 1913 Answers
SOURCE: A Disk Read Error Press
hi
yhour hardisk is notr detected properly
Posted on Mar 25, 2009
I am getting a disk read error occurred. Press ctr-alt-del. what can i do to fix this
Your computer cannot read your copy of Windows from your 'C:' disk-drive.
You need to purchase a replacement disk-drive, and re-install Windows onto the new disk-drive.
I hope that you have a good backup of all your files!
Mar 30, 2011 | Acer Aspire One PC Notebook
"A disk read error occurred. Please click ctr +
You have as it states, a disc read error which means you have errors on the hard drive.
As soon as you get into your system run CHKDSK/F, that will attempt to restore the damaged files.
Make backups and look for a replacement hard drive.
Hope that helps.
Feb 16, 2011 | Acer Aspire One PC Notebook
I just power-on my computer now, and I have this message: BOOTMGR is compressed Press Ctr+Alt+Del to restart. However, pressing Ctr+Alt+Del does not solve the problem as the message keep coming up. I...
try going to the recovery console on you install disk
type in the command FIXMBR OR FIXBOOTMGR, OR TRY...LIST...
and see if there is a more specific command
Good luck
Oct 15, 2010 | Computers & Internet
My laptop wont start.
your operating system was corrupted you need to re-install or repair install your O.S...
Oct 12, 2009 | Acer Computers & Internet
Disk error
Replace the HDD at service center. Seems to be bad disk.
Sep 16, 2009 | CMB T43 750 Notebook
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
Start up problem
hi steve,
can you get into the BIOS?
if so, would u make sure the boot orders are following:
1st. boot from hard drive,
2nd, cd rom
3rd, floppy,
4th, network adaptor?
save changes and try restart.
i hope you do have OS installed.
if not change 2nd part to 1st, and 1st to 2nd.
i have gotten the same error with my laptop. my computer was trying to load window from network, through network adapter.
hope this information helps.
Dec 21, 2007 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Computers & Internet Logo
56 people viewed this question
Top ECS Computers & Internet Experts
David
David
mitch_3020
mitch_3020
Steven Wander
Steven Wander
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
